Change gear use?
Neil A | 25/09/2022 21:28:22 |
160 forum posts | During a sort out of my shed I can across a can of Dry Moly Lubricant Spray made by Ambersil. I have used this in the past on worm gear applications and I wondered if anyone had used it for the teeth of change gears on a lathe instead of thick oil or grease? The data sheet gives open gears as one example of its use, it also states that it will prevent scuffing and reduce friction. It sounds ideal for change gears but I have never seen it mentioned in any of the lathe handbooks or any forums. Does anyone have any views on its use, I'm just interested to know. Neil |
Nigel Graham 2 | 25/09/2022 22:03:36 |
3293 forum posts 112 photos | Well, all lubricants are supposed to prevent scuffing and reduce friction! Manufacturers' claims are sometimes optimistic ("WD" actually stands for "Water Dispersant", not "Worm Drives" ) but if you've found this lubricant satisfactory on worm-gears I'd think it safe on change-wheels. I would though suggest being quite thorough with it, because it might not be carried from tooth to tooth as readily as conventional oil. |
Michael Gilligan | 26/09/2022 05:09:37 |
![]() 23121 forum posts 1360 photos | Neil, I can’t see it doing any harm: https://www.farnell.com/datasheets/494125.pdf but it seems awfully extravagant, at about £20 a can . As my Liverpudlian friends used to say: … Like using a Rolls Royce to kill a pig. MichaelG. . P.S. __ The safety data-sheet seems to be all about the hazards that come with it being in spray cans https://tech-beac.com/sites/default/files/support-document/MSDS-AMBERSIL-DRY-MOLY-400%20ml_0.pdf Edited By Michael Gilligan on 26/09/2022 05:22:26 |
Michael Gilligan | 26/09/2022 05:41:56 |
![]() 23121 forum posts 1360 photos | [ Sanity Check ] Molybdenum Disulphide is good stuff … as a dry powder, it is also relatively cheap: **LINK** https://lowerfriction.com/dry-solid-lubricant-powders/molybdenum-disulfide-mos2-powder/ How did mankind get into the state of insanity where tiny quantities are sold in expensive and hazardous packages MichaelG. |
Martin Kyte | 26/09/2022 09:20:38 |
![]() 3445 forum posts 62 photos | Posted by Michael Gilligan on 26/09/2022 05:41:56:
[ Sanity Check ] Molybdenum Disulphide is good stuff … as a dry powder, it is also relatively cheap: **LINK** https://lowerfriction.com/dry-solid-lubricant-powders/molybdenum-disulfide-mos2-powder/ How did mankind get into the state of insanity where tiny quantities are sold in expensive and hazardous packages MichaelG. I don't know, I have a 1 lb tin of it courtesy of the USAF. They chucked a load out as lifetime expired! I also acquired several large dural billets via the same logic. regards Marin |
Graham Meek | 26/09/2022 10:33:22 |
714 forum posts 414 photos | Back in the 1980's Myford used to supply a Rocol product, (I think it was MOS, or MS), which was similar to the spray on sort that you have. I have been using for many years Molykote GN paste, comes in a tube and I apply it with an artists broad paint brush to my change wheels. It does stay put once applied and does not fly everywhere which is what tends to happen with some greases. Regards Gray, |
not done it yet | 26/09/2022 13:33:46 |
7517 forum posts 20 photos | I use oil on the change gears. Anything that might stick to them, and cause wear, is either thrown or washed off. I don’t really want grinding paste between my gears. |
old mart | 27/09/2022 14:20:12 |
4655 forum posts 304 photos | Sounds good to me, just be careful not to get the stuff on yourself, moly is dirty black stuff. |
bernard towers | 27/09/2022 14:36:02 |
1221 forum posts 161 photos | Surely if you want to lubricate gears use an ep oil and if it flys off you have put too much on. I have something that clears that up it’s called a rag! |
Harry Wilkes | 27/09/2022 15:23:23 |
![]() 1613 forum posts 72 photos | I used it a lot back when I was working on part's of plant where I didn't want any contamination from the lubricant, but I never used it on gears H |
SillyOldDuffer | 27/09/2022 16:39:00 |
10668 forum posts 2415 photos | Posted by Martin Kyte on 26/09/2022 09:20:38:
[ Sanity Check ] Molybdenum Disulphide is good stuff ...MichaelG. ...I have a 1 lb tin of it courtesy of the USAF. They chucked a load out as lifetime expired! ... Molybdenum Disulphide goes off by oxidising in air. The decay isn't serious enough to worry a light-duty requirement like lubricating change gears, but even mildly cruddy lubricants are best avoided in aircraft! I guess the USAF's 'use by' date assumes the worst case scenario, such as a can being repeatedly shipped between hot and cold airbases in an unpressurised aircraft, causing the can to breath much more air than it would in a shed. Dave
Martin Kyte | 27/09/2022 18:26:09 |
![]() 3445 forum posts 62 photos | Posted by SillyOldDuffer on 27/09/2022 16:39:00:
These were unopened tins. Good for slideways. Martin |
David Noble | 27/09/2022 20:54:06 |
![]() 402 forum posts 37 photos | . As my Liverpudlian friends used to say: … Like using a Rolls Royce to kill a pig. MichaelG.
Michael, Once again you nearly made me spill my tea. David |
Graham Stoppani | 28/09/2022 06:58:20 |
![]() 157 forum posts 29 photos | Posted by Martin Kyte on 27/09/2022 18:26:09:
These were unopened tins. Good for slideways. Martin I was MD of a chemical manufacturing company supplying the aerospace industry amongst others. Most of our products, if left unopened in their containers, had an indefinite shelf life. However, some of our customers insisted we gave our products a use-by date. We were happy to comply. In some cases where product had reached its use by date we would, at the customers request, remove it from their site and replace it with new product. They would be charged for the removal and for the new product. Rather than sending the old product to landfill we would either revalidate and repackage it ready for sale once more or rework it with the next batch of product. As an accountant by trade I was rather fond of use by dates... Graham |
Michael Gilligan | 28/09/2022 07:43:53 |
![]() 23121 forum posts 1360 photos | Posted by Graham Stoppani on 28/09/2022 06:58:20: […] As an accountant by trade I was rather fond of use by dates... Graham . |
SillyOldDuffer | 28/09/2022 11:32:02 |
10668 forum posts 2415 photos | Posted by Graham Stoppani on 28/09/2022 06:58:20:
These were unopened tins. Good for slideways. Martin I was MD of a chemical manufacturing company supplying the aerospace industry amongst others. Most of our products, if left unopened in their containers, had an indefinite shelf life. However, some of our customers insisted we gave our products a use-by date. We were happy to comply. In some cases where product had reached its use by date we would, at the customers request, remove it from their site and replace it with new product. They would be charged for the removal and for the new product. Rather than sending the old product to landfill we would either revalidate and repackage it ready for sale once more or rework it with the next batch of product. As an accountant by trade I was rather fond of use by dates... Graham An accountant might well see it that way, but the historically the military have had severe problems with suppliers not understanding how their product might be treated in peace-time and no idea about the way stores are abused in war-time! For that reason, the military often call for triple layer packaging or more, with full labelling inside each layer identifying the part by name and stock number, plus relevant information about date packed, shelf-life, hazards etc etc. The packaging may also have a shelf life! Ridiculously extreme by most civilians standards, but it's not done for civilians. The idea is to make sure the guys being shot at aren't let down by duff spares, whether damaged in transit, poorly stored or by old-age. As this is extremely difficult to get right I strongly suggest it's best for suppliers to meet requirements set by the customer's engineer. Possibly he made a mistake, more likely he knows much more about the product and how it might be used than the supplier. Martin commented: These were unopened tins, which is fine and dandy except sealed tins leak! Not much, but enough to be a problem if the customer has identified it as an issue. As I said, I don't think using degraded Molybdenum Disulphide on a lathe would matter at all. I just note that as an inorganic chemical, Molybdenum Disulphide isn't completely stable. Unlike Common Salt it doesn't have an almost unlimited shelf-life. I think the main problem with use-by dates is they never explain the underlying assumptions. Products stored in favourable conditions often last much longer than the use by date, whilst the same product stored unfavourably is likely to go off rather quickly. But we aren't told what favourable and unfavourable are. So use by dates are guidance rather than exact times, and the value of the guidance depends on our circumstances. Dave
Graham Meek | 28/09/2022 13:10:14 |
714 forum posts 414 photos | I made a mistake with the Rocol reference earlier. Having found an old tube of the grease in the workshop yesterday, the correct reference is MTS 1000. Molykote GN which I mentioned earlier was one of the many greases used to service the Radiotherapy machines or Linear Accelerators which were in the Oncology Workshops care. Being used in close proximity to the beam it never showed any signs of degradation, or drying out. It was never thrown about by the various gears it was used on. Hence why I started using the same thing on my lathe changewheels. Regards Gray,
Neil A | 14/10/2022 14:51:51 |
160 forum posts | I was interested to see the comments on the use of the dry moly spray, I'm not sure that at the current price I would buy another can, but you never know. The only thing that has stopped me actually using it on the change gears is the thought of degreasing all those teeth before being able to spraying it on. It needs a clean surface for it to be able to stick successfully. I might have a go at the gears that are used for the fine feed and see how long it lasts, probably a long term test, otherwise the can will most likely stay on the shelf. Thanks to everyone for the input, being retired, this forum is now the only place that I have to bounce my thoughts off others and get their opinions. Neil |
Bazyle | 14/10/2022 17:12:50 |
![]() 6956 forum posts 229 photos | Posted by SillyOldDuffer on 27/09/2022 16:39:00:
Molybdenum Disulphide goes off by oxidising in air. I'm kind of wondering if the end product includes sulphuric acid....... |
Michael Gilligan | 14/10/2022 17:33:44 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 27/09/2022 16:39:00: Molybdenum Disulphide goes off by oxidising in air.
. I’m not arguing, Dave … I don’t have the knowledge But if you’re sure of that, you might consider editing its page on Wikipedia: MichaelG. . Chemical reactions[edit]Molybdenum disulfide is stable in air and attacked only by aggressive reagents. |
