Steve355 | 09/09/2022 00:07:33 |
321 forum posts 235 photos | Hi I noticed the other day that my Dore Westbury mk 1 spindle was loose vertically, so I took it to bits to investigate and tighten it up. While doing this I thought I’d check the runout before I put it back in. I have some 0.0001 clocks these days, which I didn’t have when I got it. I found that it was about 0.0025 which obviously far too much. I’ve tried with various amounts of tightening of the preload (?) nuts and it doesn’t seem to make much difference. I’ve tried measuring it at the (point where the spindle exits the quill?) and also with a test bar in the mt2 socket, same results. The spindle doesn’t have a very good finish (home made obviously). But I’m not in a position to remake it as it’s too long for my lathe. The bearings look ok but there is some unevenness and roughness when turned manually! Which seems to correlate with the runout, How do I tell if it’s the spindle or bearings at fault? The bearings are expensive and I don’t want to get new ones if that isn’t the cause, im getting a nice new surface plate next week, it would be good to know what measurements to take to check out the spindle, if anyone has any ideas. pic below thanks Steve |
Huub | 09/09/2022 00:33:08 |
220 forum posts 20 photos | Posted by Steve355 on 09/09/2022 00:07:33:
Hi The bearings look ok but there is some unevenness and roughness when turned manually! Which seems to correlate with the runout,How do I tell if it’s the spindle or bearings at fault? The bearings are expensive and I don’t want to get new ones if that isn’t the cause If "there is some unevenness and roughness when turned manually" and this is at a low preload, the bearings ar worn or damaged. You should measure the runout at the inside of the spindle taper. If that is not possible, then on the outside of the chuck taper. If you use a drill chuck (not a collet) than the runout of the drill chuck is probably more than the runout of the spindle.
Michael Gilligan | 09/09/2022 07:20:23 |
![]() 23121 forum posts 1360 photos | First … may we assume that you are measuring in Inches ? I agree with Huub’s analysis, but would also mention that if “The spindle doesn’t have a very good finish” then you may still be disappointed with the result of a bearing change. My ‘working hypothesis’ is that inherent runout in the spindle has abused the bearings. MichaelG. . P.S. ___ Have a look at the conversion illustrated on this 2016 thread: https://www.model-engineer.co.uk/forums/postings.asp?th=117936&p=2 Edited By Michael Gilligan on 09/09/2022 07:44:39 |
JasonB | 09/09/2022 07:30:14 |
![]() 25215 forum posts 3105 photos 1 articles | When you say "took it to bits" was that just removing the spindle or stripping the spindle and cleaning the bearings? If not a complete strip then that may be worth a try and at the same time inspect the bearings for damage if they look OK then regrease, adjust, run for a while and adjust again if needed and then take readings with the spindle in place. While apart you can also see if the builder got a better surface finish where the bearings fit. |
Neil Lickfold | 09/09/2022 08:39:44 |
1025 forum posts 204 photos | Mine had a lot of issues. The bearing end faces were not true to the run of the spindle barrel or bore. I have some pics of correcting the barrel. |
Steve355 | 09/09/2022 09:00:43 |
321 forum posts 235 photos | (of course it’s imperial, the Queen only died yesterday Well, eliminating the thust bearings altogether I stuck the spindle on some V blocks on a mag chuck, aligned with a parallel. On the nose, I again see the 0.003 runout…. On the bearing surface (which has a much better finish than other surfaces, Both bearing areas are exactly 0.999 diameter.) <0.0005 runout. Within expected tolerance. Unfortunately I think I have to conclude that when it was made, it was turned around, either in a chuck or between centres or something and wasn’t perfectly realigned. So I’m not sure there’s anything that can be done, the Morse taper is simply not aligned with the axis of the spindle. Spindle itself is running true. Any brilliant ideas very welcome.
Steve
Huub | 09/09/2022 09:13:05 |
220 forum posts 20 photos | I think the spindle is damaged during use because It is likely the bearing and spindle are machined in one fixation to avoid runout. You could repair the seating of the nose and/or the taper on the lathe!
Edited By Huub on 09/09/2022 09:15:28 |
not done it yet | 09/09/2022 09:27:55 |
7517 forum posts 20 photos | You should measure the runout at the inside of the spindle taper. If that is not possible, then on the outside of the chuck taper. As per Huub, above, measure the taper runout. A commercial blank 2MT arbor would suffice, for this. |
Steve355 | 09/09/2022 09:36:15 |
321 forum posts 235 photos | Posted by not done it yet on 09/09/2022 09:27:55:
You should measure the runout at the inside of the spindle taper. If that is not possible, then on the outside of the chuck taper. As per Huub, above, measure the taper runout. A commercial blank 2MT arbor would suffice, for this. That’s the first thing I did, with a MT2 test bar and also a MT2 jacobs taper adapter, and it’s the same. 0.003.
Edited By Steve355 on 09/09/2022 09:46:57 |
SillyOldDuffer | 09/09/2022 10:15:33 |
10668 forum posts 2415 photos | Does the mill cut metal satisfactorily or has this fault been found by measuring? I see measuring machines in the workshop as the second or third stage in a diagnostic process, never the first. After finding the machine doesn't cut as expected, measurement is a good way of isolating the fault, but only after trying more basic tests first. Unfortunately it's all too easy for amateurs to lead themselves up the garden path due to measurement errors. You can guess how I know! Trouble is accurate and reliable measurement is a difficult skill in itself. (Manufacturing is organised to check parts. In general they don't poke about with dials and micrometers as we have to.) Huub commented: If "there is some unevenness and roughness when turned manually" and this is at a low preload, the bearings are worn or damaged. I agree. Michael said: My ‘working hypothesis’ is that inherent runout in the spindle has abused the bearings. It's a good hypothesis that would account for the bearings premature demise, assuming of course that the mill wasn't worked hard during it's life. Steve suggests himself: Unfortunately I think I have to conclude that when it was made, it was turned around, either in a chuck or between centres or something and wasn’t perfectly realigned. Quite likely - as we know, Model Engineers often do their best with limited equipment and skills. And some of us make mistakes, such as not using the technique needed to avoid introducing runout! Hobby-end machines are what they are, so perhaps the root cause of this problem isn't worth fixing? I'm inclined to put up with minor faults until they stop me doing what I need to do. Assuming the mill was performing reasonably before runout was discovered, only because the machine is in bits, I'd fit new bearings and carry on. As a Dore-Westbury is likely to be at least 30 years old, it hasn't done too badly! For most hobby purposes it's not necessary to own top-quality equipment in perfect condition. In my workshop tools are 'good enough' if they do what I need, and I don't fuss about their imperfections! Dave Edited By SillyOldDuffer on 09/09/2022 10:16:11 |
Michael Gilligan | 09/09/2022 10:26:05 |
. Nice convincing demonstrations, Steve The ‘obvious but not trivially simple’ thing to do would be to re-finish the register and the socket in situ … use the spindle assembly as the headstock. MichaelG. |
Steve355 | 09/09/2022 10:43:54 |
321 forum posts 235 photos | Posted by Michael Gilligan on 09/09/2022 10:26:05:
. Nice convincing demonstrations, Steve The ‘obvious but not trivially simple’ thing to do would be to re-finish the register and the socket in situ … use the spindle assembly as the headstock. MichaelG. Michael, I can see how to do that…. But it has an MT2 taper (constantly used) and a myford thread (less used). Those are the bits that look tricky to me. I have an Mt2 reamer. It could be possible that if held rigidly enough it would “centre itself” and ream the taper centrally if advanced a little further than it currently is. But it feels like a bit of a long shot. |
Hopper | 09/09/2022 10:44:05 |
![]() 7881 forum posts 397 photos | Posted by Steve355 on 09/09/2022 00:07:33:
The bearings look ok but there is some unevenness and roughness when turned manually! Which seems to correlate with the runout, How do I tell if it’s the spindle or bearings at fault? The bearings are expensive and I don’t want to get new ones if that isn’t the cause, Regardless of runout, if clean and dry bearings have any feeling of unevenness or roughness, or noisiness, they need replacing. They must be immaculately clean and dry though. Wash in clean solvent and dry with compressed air. If the bearing roughness seems to coincide with the runout, that is quite likely your problem. |
Graham Meek | 09/09/2022 11:08:39 |
714 forum posts 414 photos | To prove if it is the bearings at fault rotate the spindle in a matched pair of vee blocks. The bearing registers resting on the vee block. If you get the same run-out it as was present in the assembled spindle and then it is not the bearings. Also put a clock in the centre between the bearing registers and see if there is a high spot. Mark the high spot with a felt pen. Move either side to see if the readings are the same or less. If the readings are the same magnitude then it will be safe to assume this portion is running out from manufacture. If the readings either side are occuring at the same point but are less then the spindle may well be bent. If the high spot in the centre is opposite the low point at the Spindle nose then this would confirm it. Hope these notes help, Regards Gray, Edited By Graham Meek on 09/09/2022 11:09:57 |
old mart | 09/09/2022 11:25:33 |
4655 forum posts 304 photos | I did notice in the videos that the lever of the indicator didn't seem to be tangential to the spindle, that would give the best figures. Could you also mark the high spots and do a third test on the MT tool in the spindle taper. It would be possible to have the journals built up with nickel plating or metal spray and then re machined true, the surfaces would have to be reduced in diameter by about 0.01" first. It might also be possible to find bearings with a slightly smaller bore, but that would depend mostly on how lucky you are. |
Martin Kyte | 09/09/2022 11:35:59 |
![]() 3445 forum posts 62 photos | Point 1. I'm not sure magnetic mounting is the ideal for this test. Point 2. Do you not just need to remachine the 2 Morse internal taper with the spindle running in it's own bearings? It has got to be spot on after that. All that said, it's not terrible and I would say the machine is perfectly useable as it is. regards Martin |
peak4 | 09/09/2022 11:43:53 |
![]() 2207 forum posts 210 photos | A couple of thoughts, on which I hope others will expand. |
Michael Gilligan | 09/09/2022 12:20:40 |
![]() 23121 forum posts 1360 photos | Posted by Steve355 on 09/09/2022 10:43:54:
. Nice convincing demonstrations, Steve The ‘obvious but not trivially simple’ thing to do would be to re-finish the register and the socket in situ … use the spindle assembly as the headstock. MichaelG. Michael, I can see how to do that…. But it has an MT2 taper (constantly used) and a myford thread (less used). Those are the bits that look tricky to me. I have an Mt2 reamer. It could be possible that if held rigidly enough it would “centre itself” and ream the taper centrally if advanced a little further than it currently is. But it feels like a bit of a long shot. . Boring or grinding would probably give a better chance of a good result. … pleased to see that others have come to the same general conclusion MichaelG. . P.S. __ You might find inspiration, encouragement, or even lust … here: http://anglo-swiss-tools.co.uk/gepy-centres-spindles/ [ start by understanding how it’s done properly … you can always work backwards from there ] Edited By Michael Gilligan on 09/09/2022 12:29:13 |
JasonB | 09/09/2022 12:29:32 |
![]() 25215 forum posts 3105 photos 1 articles | I'm with Old mart, the angle of the Dti lever does not look right, I tend to set the arm at right angles to the movement I'm trying to measure. Would be interesting to see what it measures with either the whole Dti horizontal or move the lever so it's horizontal. Edited By JasonB on 09/09/2022 12:29:49 |
Dave S | 10/09/2022 16:10:13 |
433 forum posts 95 photos | Whilst it needs to end up as mt2 (probably) it doesn’t have to be mt2 whilst fixing it. I would bore the spindle to a suitable cylindrical diameter (probably large end of mt2 ish) Then loctite or shrink fit a plug in and finally bore and ream that using the spindles own bearings. Probably worth replacing the bearings whilst your doing it - modern new bearings of reasonable quality are not expensive and are sufficiently accurate for the job.
Dave |
