Centec 2b
Sean Stimpson12/08/2022 17:25:05
31 forum posts
14 photos
Hi all I recently brought a Centec 2b local to me very cheap with a quill head
Didn’t realise the size of the swarf tray
2 questions
I need a new bellows for the z axis lead screw what do people use
also I use carbide end mills don’t have hss I find 1400 rpm a little slow for using the vertical head
do people change the motor to a more powerful 2 pole or play around with different size pulleys thanks in advance
peak412/08/2022 18:09:42
2207 forum posts
210 photos
Re the bellows, it's not very elegant, but I use a modified macadamia nut tin to provide a shield/mounting for the lower end and a corrugated shock absorber cover for the main bellows unit.
It seems to work fine.
I'm not sure I would want to run the main gearbox as fast as a two pole motor.
Maybe consider a second variable speed motor to replace/drive the rear V pulley on the vertical head.
Bill
duncan webster12/08/2022 18:17:10
5307 forum posts
83 photos
Vertical head gets pretty hot if you run for extended periods at 1400 rpm, I wouldn't want to run it any faster
peak412/08/2022 18:33:19
2207 forum posts
210 photos
Posted by duncan webster on 12/08/2022 18:17:10:
Yes fair point, and also worth considering removing the chuck, if on MT2 taper, whilst it's still warm, to save it jamming tight when it cools down.
Don't ask me how I know.
blush
Bill
not done it yet12/08/2022 18:47:38
7517 forum posts
20 photos
Too late by then. That will make no difference at all. Problem arose when a cold taper was inserted into a warm socket.
Gary Wooding13/08/2022 08:04:25
1074 forum posts
290 photos
On my 2B I kept the original 3ph motor, converted it to delta by splitting the star point, and run it with a VFD. This gives me a speed range from about 30-2800 rpm. I've not experienced problem using carbide tooling, and it makes tapping under power a doddle.
not done it yet13/08/2022 08:32:49
7517 forum posts
20 photos
Posted by Gary Wooding on 13/08/2022 08:04:25:
Almost exactly the same except I changed mine, from the (non-original) single phase fitted, to a 3 phase motor.
I’m not sure whether the vertical head rpm’s are the same as the horizontal output - I’ve simply never checked.🙂. I don’t thinkI’ve ever exceeded about 2000 (indicated rpm) on mine.
The power feed is operating perfectly adequately using the 3 phase motor and a 240V VFD.
I would not actually recommend a more powerful motor. The 2B was increased from 3/4HP to 1HP (over the 2A model). I am not aware if the gearbox internals were changed at all. If not, that is already a 33% increased rating. Mine can actually deliver about 1.2HP, but I am careful not to use all the power available. My Centec is a valuable asset and I don’t intend to try to destroy it by over-loading it!
Sean Stimpson13/08/2022 08:32:49
31 forum posts
14 photos
Is you Centec 2b motor a 2800 rpm motor as standard mine is only a 1400 rpm
duncan webster13/08/2022 18:02:42
5307 forum posts
83 photos
Posted by not done it yet on 13/08/2022 08:32:49:
I’m not sure whether the vertical head rpm’s are the same as the horizontal output - I’ve simply never checked.....
There is a 7:8 ratio between, can't remember which way
Dave Halford14/08/2022 20:38:43
2536 forum posts
24 photos
Centecs were available with 2800rpm motors. There has been a previous discussion on here.
