With additions
OuBallie | 11/07/2022 15:47:39 |
![]() 1181 forum posts 669 photos | My third Hemingway kit since doing their Drawbar and later the ‘simple’ knurling tool 2015:
Michael Gilligan | 11/07/2022 16:36:14 |
![]() 23121 forum posts 1360 photos | Nice work, Geoff Keep surviving !! MichaelG. |
OuBallie | 11/07/2022 17:46:50 |
![]() 1181 forum posts 669 photos | Thanks Michael. Doing my best to do so. More photos: I had forgotten just how hard arc weld is as it soon blunted HSS so switched to TC and that produced a perfect finish. In place but needing the tool bit ground: Geoff - Hemingway kit number 4 soon |
Andrew Tinsley | 11/07/2022 18:08:22 |
1817 forum posts 2 photos | I was transferred to Papworth from Peterborough Hospital. Rush hour on the A1 and the two lines of cars simply widened the gap between them and the ambulance going down the middle with siren and lights flashing. The paramedic looked at the speed for me and said 90 mph! I didn't think I was a real emergency case, it turned out the ambulance crew were based at Papworth and it was a quick way to finish their shift! Andrew. |
Howard Lewis | 11/07/2022 19:34:03 |
7227 forum posts 21 photos | Hi Geoff! Hope that all is now well, and that the Austin 7 is now receiving attention again. That Flycutter looks to be some beast. Next, you'll be telling us how you slowed the mill to 20 rpm! The ngardens need rain jsy as we teperate folk need lower temperatures. Howard |
Ady1 | 12/07/2022 08:11:39 |
![]() 6137 forum posts 893 photos | I find that standard stick to 120 Amps can be quite soft and malleable If you want a hard weld then wire welding seems to be the way Looks like things could get pretty warm for you over the next few days, a cool drink under a shady tree with a copy of ME might be the way to go |
OuBallie | 12/07/2022 14:21:05 |
![]() 1181 forum posts 669 photos | Thanks for all the comments. Andrew, Howard, The very best move was fitting one to the drilling machine that transformed it as now easy to adjust speed to suit drill size. Ady1, Geoff - Just replaced battery in iPhone 6s, and a doddle. |
Bazyle | 12/07/2022 16:03:12 |
![]() 6956 forum posts 229 photos | Hard to see but what is the shape of the cutter? It looks the wrong way round ie not deepest edge outwards. |
OuBallie | 14/07/2022 10:16:23 |
![]() 1181 forum posts 669 photos | Bazyle, Used the bit to produce the square hole. Geoff - Trying not to melt |
not done it yet | 14/07/2022 10:20:14 |
7517 forum posts 20 photos | As far as cutter geometry is concerned it’s not really any different than facing on the lathe?🙂 Edited By not done it yet on 14/07/2022 10:20:27 |
OuBallie | 14/07/2022 10:32:06 |
![]() 1181 forum posts 669 photos | not done it yet, Ah easy to do then, thanks. Geoff |
Bazyle | 14/07/2022 14:59:12 |
![]() 6956 forum posts 229 photos | The thing to remember or get your head around is that the device is moving sideways not downwards. So it is the outer edge of the tool that meets the material first. You might make that bottom outer corner a sharp but fragile one which will leave lot of little grooves on the surface corresponding to your feed rate, or round it off as with a late tool. ( for future readers or foreigners it is currently circa 28-30C in the UK which we consider extremely hot although you might be reaching for a coat) |
Howard Lewis | 14/07/2022 21:16:29 |
7227 forum posts 21 photos | I made mine initially for a normal knife tool, and the (Mk4 or was it5? ) was for a diamond toolbit, like a tangential turning tool (When I can be sufficiently organised to put the bit in the the right way round. Seem to make full use of the 3 wrongs ones! ) Howard |
OuBallie | 15/07/2022 17:13:05 |
![]() 1181 forum posts 669 photos | Bazyle, Howard, Geoff - So much cooler today, ready for the furnace to come. |
Howard Lewis | 16/07/2022 11:52:34 |
7227 forum posts 21 photos | Geoff The tangential tool works so well in the lathe, it had to be worth a try as a flycutter, even if it sees little or no use. Might "Come in handy one day" Time to get out the fan! (Even the cats seem to like being wiped with a wet clo!h ) Howard Edited By Howard Lewis on 16/07/2022 11:53:31 |
OuBallie | 17/07/2022 11:14:06 |
![]() 1181 forum posts 669 photos | Howard, The hard weld blunted my tangential toolbit hence having to switch to TC. Geoff - Keep cool everyone. |
Howard Lewis | 17/07/2022 13:14:47 |
7227 forum posts 21 photos | Geoff, I've had the same problem with welds. And mine are so uneven that the interrupted cut chips the edge of the carbide. You can't win! But I got there in the end. Howard |
