Boxford Shaper Vertical feed
peak406/07/2022 14:51:23
2207 forum posts
210 photos
A different query this time for the Boxford Shaper.
Does anybody have one with the vertical feed option please; mine is horizontal only.
I was intending to purchase the two parts needed to add the facility to mine, a ratchet wheel and drive gear, but alas Boxford are out of stock.
They were also unable to provide any diagrams, as apparently they were lost in a fire some time ago.
I'm after a tooth count, thickness, and diameter of the vertical ratchet wheel, and the drive gear which sits adjacent and is pinned to it.
Many Thanks
Bill
bernard towers06/07/2022 17:46:40
1221 forum posts
161 photos
b76093fc-4831-4202-9f2f-605151d0fb8a.jpeg8a797671-a4f4-42f6-ba2d-2bff08842781.jpeg648ceecc-d08c-4201-807c-8d788753ec51.jpeg4d9948c1-ff32-4abd-bedc-7c1995fb33f4.jpegI think that you only need two gears and piece of shaft to match dia of other two shafts.3182e456-1a38-496f-aa2d-10944a386b07.jpeg
Saxalby06/07/2022 17:46:46
187 forum posts
33 photos
I have the vertical feed on mine. Will take some measurements tomorrow, unless some else beats me to it.
Barry
bernard towers06/07/2022 17:49:22
1221 forum posts
161 photos
hope the pics tell the story, the gear with a plain section is moved from cross shaft to vertical shaft using the same rachet mech to operate both.
DC31k06/07/2022 18:10:26
1186 forum posts
11 photos
Posted by bernard towers on 06/07/2022 17:49:22:
Please could you clarify if the picture is of a Boxford shaper. If so, it differs to both the mark I and mark II versions shown at lathes.co.uk.
bernard towers06/07/2022 18:33:57
1221 forum posts
161 photos
I think you'll find that most English shapers were made in the same factory and badged.
DC31k06/07/2022 19:26:49
1186 forum posts
11 photos
Posted by bernard towers on 06/07/2022 18:33:57:
Thanks for the reply. Your observation is noted, but it does not answer the request. Would you kindly confirm or not that the pictures are of a Boxford.
Saxalby06/07/2022 19:31:30
187 forum posts
33 photos
The feed mechanism looks nothing like my Mk2 Boxford.
Barry
peak406/07/2022 20:24:17
2207 forum posts
210 photos
Posted by Saxalby on 06/07/2022 19:31:30:
Barry
Thanks Barry, that looks the same as mine, barring the colour; mine is blue as per the photo(s) on Tony's site.
The lower gear on the vertical feed shaft, obscured from view in your photo, is present; I'm missing the left hand gear and the ratchet wheel in the centre from the upper shaft.
The Boxford Spares site is handy, in that it includes copies of the original blueprints.
https://www.boxford-software.com/spares/SHSaddle.html
I'm short on items 8&9.
I appreciate that the ratchet wheel will be the same diameter as the one I already have, but the number of notches may be different, to get the correct feed rate for the vertical drive chain; it's hard to tell from the diagram but it looks like your photo shows it as about the same.
Next one is the number of teeth on the left hand drive wheel.
Cheers
Bill
peak406/07/2022 20:31:20
2207 forum posts
210 photos
Posted by DC31k on 06/07/2022 19:26:49:
I think Bernard's machine might be an Elliott/Alba, as the ratchet mechanism looks similar, and the ways are rectangular, rather than the dovetails on the Boxford.
Bill
Saxalby07/07/2022 12:47:55
187 forum posts
33 photos
Have just had a look at mine.
The two ratchet wheels are identical, size and tooth count.
The gear on the left is 26 tooth and 1.4 inches dia., so that makes it 20DP gear.
And almost certainly 14.5 PA
Reds Barry
Edited By Saxalby on 07/07/2022 12:49:18
peak407/07/2022 15:39:02
2207 forum posts
210 photos
Posted by Saxalby on 07/07/2022 12:47:55:
Reds Barry
Thanks Barry, much appreciated.> I think that makes it a standard Myford gear, cheap enough not to need to try making it; maybe just need to change the bore size.
A little project for when the nights start drawing in, and I'm awaiting the return of some Ducati bits.
Bill
Edited By peak4 on 07/07/2022 15:45:41
peak402/08/2022 23:47:05
2207 forum posts
210 photos
Reds Barry
Thanks again for your assistance on that one.
I went to order a 26 tooth gear from RDG, and found they had some dirty ones going cheap, so not worth me buying a gear cutter for the one job.
It fits and meshes nicely.
Fortunately I had a lump of 50mm EN8 in stock, so made up a duplicate 40 tooth ratchet wheel, and the machine now has vertical feed.
Dividing head set up on the Centec, showing the riser block in use for horizontal milling.
Seems to work well enough, and convenient at 40 tooth so no holes to count.
The completed assembly; the bit of bar was just for lining things up.
There's a few more photos in the album.
https://www.model-engineer.co.uk/albums/member_album.asp?a=57071
Bill
Edited By peak4 on 02/08/2022 23:49:13
Craig Brown03/08/2022 07:09:11
110 forum posts
57 photos
Thanks for the info and pictures.....this is a job I would like to do in the future
mgnbuk03/08/2022 07:54:20
1394 forum posts
103 photos
+1
Rusty gear ordered from RDG.
Nigel B.
Craig Brown03/08/2022 08:32:23
110 forum posts
57 photos
Posted by mgnbuk on 03/08/2022 07:54:20:
+1
Nigel B.
Have you got a link for the gear as all I could find was a 26T Myford change gear unless this is what is being referred to?
Thanks, Craig
mgnbuk03/08/2022 08:57:38
1394 forum posts
103 photos
https://www.ebay.co.uk/itm/144246875011?var=443551918233
is the one I have bought Craig. It is a Myford change gear.
Perhaps peak4 could confirm this what he used - but there cannot be many "shop soiled" 26 tooth gears suitable for a Myford sold by RDG on Ebay.
Nigel B
peak403/08/2022 10:35:42
2207 forum posts
210 photos
Posted by mgnbuk on 03/08/2022 08:57:38:
Nigel B
Yes, a Myford change gear; sorry. I intended to mention it in the post; I did when posting the photos on Flickr & Faceache.
Shop soiled Change Gear
Bill
Robin03/08/2022 11:07:01
678 forum posts
I'm just doing one, the tricky bit is cutting 40 x 1/16" grooves in the ratchet, you really need a shaper for that.
I broke my only 1/16" end mill and had to do them 2mm.
The gear is the same as the one it meshes with. I gave it a sintered bronze bushing.
It goes up and down like anything. The vertical drive shaft has a steel gear taper pinned on the end. Be sure to remove the bronze gear behind before knocking the pin out. Angst surprise
Have you found a supplier for 3/32" x 1 1/2" taper pins? I got some 1" from EKP but I need bigger.
Robin
Craig Brown03/08/2022 13:24:29
110 forum posts
57 photos
Posted by peak4 on 03/08/2022 10:35:42:
Nigel B
Bill
Thanks both, have now found it and ordered one
