Mill Bolt Source?
Need to get one of these?
James Frankland06/06/2022 15:23:38
14 forum posts
5 photos
I was tramming in my Twin Mill\Drill and i overtightened the cam lock head bolt and broke it.
Where would be a good place to get one? Its 110mm 1/4 BSW 20G with about 50mm of threads.
Can anyone suggest somewhere? I assume it needs to be hardened bolt?
Many thanks.
James
Bolt
peak406/06/2022 15:58:27
2207 forum posts
210 photos
Looks a bit of a one-off with a head that size.
Could you get by with a ¼" UNC bolt? if so Spalding fasteners sell them
https://www.spaldingfasteners.co.uk/1-4-unc-grade-8-10-9-hex-head-part-threaded-bolts-yellow-zinc-plated/
Is the hex head on yours 7/16" 0.438" UNC or 0.445" BSW?
Bill
Nigel Graham 206/06/2022 16:07:49
3293 forum posts
112 photos
I'd think it tough rather than hardened - you want accidents to break that, not the more critical parts.
James Frankland06/06/2022 16:56:56
14 forum posts
5 photos
Hi Guys
Thanks. The head doesnt matter at all. Any old hex head will do. So yes, i can almost certainly use the spalding one.
Many thanks
James
Bazyle06/06/2022 17:20:04
6956 forum posts
229 photos
If one did make one's own, what would you use? EN4, EN24?
Emgee06/06/2022 17:43:23
2610 forum posts
312 photos
Posted by Bazyle on 06/06/2022 17:20:04:
I would use EN8 as have some in stock that would suit, also EN16T but don't think it necessary.
Emgee
Mark Rand06/06/2022 19:12:31
1505 forum posts
56 photos
EN16T is the stuff to use but If I made it, it'd come with a 3/4" AF head, because that's what I've got.. smiley
Edited By Mark Rand on 06/06/2022 19:14:19
Howard Lewis07/06/2022 09:35:50
7227 forum posts
21 photos
FWIW, Make one!
No need for a forging.
The drawbar on my milll has a hexagon head pinned to the 3/8 BSW drawbar proper and had survived my use for over 20 years.
Howaqrd
martin haysom07/06/2022 09:48:40
165 forum posts
the draw bar on my mill is a piece of threaded bar from the local tool shop with a nut brazed on the end
