Proxxon Chuck PCD
Neville Chase31/05/2022 10:43:09
29 forum posts
Hi everyone. Can someone please tell me the PCD is of the Proxxon 24036 four jaw chuck? Also the dimensions of the register on the back would be very helpful.
Thanks
bernard towers31/05/2022 21:44:44
1221 forum posts
161 photos
Can’t you just measure the pod? And as for the register it’s not the size that matters it’s the FIT!
Michael Gilligan01/06/2022 00:44:45
23121 forum posts
1360 photos
Posted by bernard towers on 31/05/2022 21:44:44:
Very philosophical … but: being a mass-market device, one might reasonably assume that Proxxon has design tolerances for the parts [such that components are interchangeable]
Neville Chase01/06/2022 08:29:59
29 forum posts
If I had something to measure I would have done that. I want to see if I can adapt this chuck to another machine, which is why I am asking.
Neville Chase01/06/2022 09:58:31
29 forum posts
This is the chuck -
https://www.amazon.com.au/PROXXON-24036-Jaw-Chuck-250/dp/B011RIM3NA/ref=sr_1_2?crid=170BIZ8PGJ6MQ&keywords=Proxxon+chuck&qid=1653983698&sprefix=proxxon+chuck%2Caps%2C255&sr=8-2
John Hinkley01/06/2022 10:24:05
1545 forum posts
484 photos
Chronos are advertising them as in stock, as are Axminster. Might be worth a phone call or email? I am assuming from your description that the lathe in question is PD400.
JasonB01/06/2022 10:24:33
Watch this from about 18.20. looks like the register is 40mm and PCD 34mm
Neville Chase01/06/2022 11:11:03
29 forum posts
Posted by John Hinkley on 01/06/2022 10:24:05:
The chuck is for a PD230/E.
John Hinkley01/06/2022 11:57:07
1545 forum posts
484 photos
Neville,
That narrows the search down a bit. Nevertheless, the Chronos pointer was for the quoted 24036 chuck. Seems like Jason has come up trumps, again, though.
Neville Chase02/06/2022 09:56:24
29 forum posts
Chronos and Axminster do have the same chuck I linked to on Amazon, but both more expensive than the Amazon one. Axminster not in stock but available to order. Chronos looks like it's in stock. Will contact Chronos for more info on the chuck dimensions.
Robin Graham02/06/2022 23:05:44
1089 forum posts
345 photos
Hi Neville. From your opening post I assumed that you had some specific need to use the Proxxon chuck. As the thread has evolved it looks like you are planning to buy one, and I wonder why.
It may be that you are thinking that because Proxxon stuff is generally well made the 4-jaw will be a cut above the (much cheaper) Chinese/Indian offerings. That is not necessarily true. My first lathe was Proxxon PD400 which came with a really lovely Rohm 3-jaw - smooth and accurate. I ordered a 100mm 4-jaw (~£200) assuming it would be of similar quality. I received a Proxxon branded item which proved a real pain to use - very sticky with screws binding in the casting. The 4-jaw which came bundled with my Chinese lathe is far smoother. Looking at your Amazon link I see two reviews, one saying it's 'well manufactured and functions perfectly' and the other:
'The level of "precision" is just atrocious. There are no two jaws that would be of the same height. The machining is just sloppy with a lot of "apprentice marks" like burrs, uneven angles and discoloration from overheating. There is a lot of grinding dust and metal chips in the jaw screw threads. The starts of threads of the jaw screws are misshaped. The screws are binding in the head even without the jaws installed. Hopefully it all can be fixed but the chuck is absolutely not worth the money.'
My experience with the PD400 chuck wasn't as dire as that of second reviewer, but closer than that of the first.
Apologies if this isn't relevant to the decisions you are making Nevillle, just my two ha'porth (as we're going back to imperial).
Regards, Robin.
Edited By Robin Graham on 02/06/2022 23:10:28
Neville Chase03/06/2022 09:21:01
29 forum posts
Thanks Robyn.
Had seen the reviews and was a bit worried about quality. I did buy a Proxxon PD-230E 3 jaw for my Toyo ML-1 lathe recently and that is very good. Fits the Toyo perfectly. Left my run too late for a PD-230/E four jaw as they are now out of stock everywhere I have looked. Was hoping to adapt the PD-250E to the Toyo if I could.
Neville Chase04/06/2022 11:20:12
29 forum posts
Found some info on the chuck here -
https://www.naradiprofesional.cz/206109-proxxon-24036-sklicidlo-4-celist-pd-250-e
Michael Gilligan04/06/2022 16:13:41
23121 forum posts
1360 photos
Posted by Neville Chase on 04/06/2022 11:20:12:
DeepL translates the tabulated values as :
External Ø 79mm
Inner passage 20mm
height incl. jaws 35mm
So you’re not quite there yet … but it’s probably worth browsing that site for more info.
Neville Chase05/06/2022 09:14:14
29 forum posts
I've emailed a couple of places that stock this chuck about dimensions, such as PCD and diameter of mount holes. If the PCD is 35mm I would be very happy.
Neville Chase07/06/2022 10:39:22
29 forum posts
Mounting register for the Proxxon Chuck is 40mm and PCD is 34mm. Toyo spindle is a register of 22mm and a PCD 0f 35mm. That's going to be a challenge.
Neville Chase07/06/2022 10:43:17
29 forum posts
If the PCD was 35mm I could probably make a disc 40mm x 22mm to press into the rear of the chuck. I do make things difficult for myself.
Neville Chase09/06/2022 07:52:57
29 forum posts
I've ordered the Proxxon chuck from Amazon. Plan is to make a back plate for it.
Graham Meek11/06/2022 19:41:13
714 forum posts
414 photos
Hi Neville,
I have sent you a PM, you may be able to help me.
Gray,
Neville Chase12/06/2022 08:40:28
29 forum posts
Posted by Graham Meek on 11/06/2022 19:41:13:
Hi Neville,
Gray,
Replied to PM.
Nev.
