Member postings for Neville Chase
Here is a list of all the postings Neville Chase has made in our forums. Click on a thread name to jump to the thread.
Thread: Wera hand-tools
04/10/2023 09:13:20
I only have the Wera 6004 Joker Self-Setting Spanner 4-Pieces Set bought on Amazon for A$249.00. It's ok but is now cheaper at A$180.00. Also bought the 19-24mm separately but it was a piece of junk so sent it back. I really think there is cheaper stuff of better quality out there. Will not be buying any more Wera. If you really want Wera then check Amazon as they quite often have discounts on Wera.
Edited By Neville Chase on 04/10/2023 09:16:06
Thread: bizarre behaviour from spray can
23/09/2023 10:30:50
Pickup tube dislodged?
Thread: Malicious website ?
18/05/2023 08:55:25
I consider Norton a virus.
Thread: Questions regarding Proxxon pd 230 lathe Chuck mounting/Spindle
03/05/2023 11:10:48
I am not sure if this is a legitimate website or not.
https://twinnermodel-com.translate.goog/products/4006274240308?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=en-US&_x_tr_pto=wapp
30/03/2023 00:23:10
Re-posting this link as it has more info on the 24036 -
https://www.naradiprofesional.cz/206109-proxxon-24036-sklicidlo-4-celist-pd-250-e
Edited By Neville Chase on 30/03/2023 00:24:44
30/03/2023 00:15:01
The three jaw 24028 fits the Toyo very well so I am assuming the 24030 should have the correct register and PCD as well. I did get a 24036 but yet to work out how to adapt that, but it should not be too difficult. If you find more than one 24030 available let me know as I would prefer that over the 24036.
Thanks
Nev.
29/03/2023 09:17:49
Good luck finding a 24030 Proxxon Chuck anywhere now. Even the 24028 three jaw seems to be unavailable now. Maybe with an adapter plate the 24036 can be made to fit. It's register is 40mm with I think a PCD of 34mm.
Thread: Toyo ML-1 bearings
21/06/2022 07:45:50
Would anyone here have the bearing numbers for the Toyo ML-1?
Thanks
Nev.
Thread: Proxxon Chuck PCD
17/06/2022 11:20:33
Got the chuck today and very happy with it. Just so everyone knows the register depth is 5.8mm and mounting holes are 4mm.
Nev.
12/06/2022 08:40:28
Posted by Graham Meek on 11/06/2022 19:41:13:
Hi Neville,
I have sent you a PM, you may be able to help me.
Gray,
Replied to PM.
Nev.
09/06/2022 07:52:57
I've ordered the Proxxon chuck from Amazon. Plan is to make a back plate for it.
07/06/2022 10:43:17
If the PCD was 35mm I could probably make a disc 40mm x 22mm to press into the rear of the chuck. I do make things difficult for myself.
07/06/2022 10:39:22
Mounting register for the Proxxon Chuck is 40mm and PCD is 34mm. Toyo spindle is a register of 22mm and a PCD 0f 35mm. That's going to be a challenge.
05/06/2022 09:14:14
I've emailed a couple of places that stock this chuck about dimensions, such as PCD and diameter of mount holes. If the PCD is 35mm I would be very happy.
04/06/2022 11:20:12
Found some info on the chuck here -
03/06/2022 09:21:01
Thanks Robyn.
Had seen the reviews and was a bit worried about quality. I did buy a Proxxon PD-230E 3 jaw for my Toyo ML-1 lathe recently and that is very good. Fits the Toyo perfectly. Left my run too late for a PD-230/E four jaw as they are now out of stock everywhere I have looked. Was hoping to adapt the PD-250E to the Toyo if I could.
02/06/2022 09:56:24
Chronos and Axminster do have the same chuck I linked to on Amazon, but both more expensive than the Amazon one. Axminster not in stock but available to order. Chronos looks like it's in stock. Will contact Chronos for more info on the chuck dimensions.
01/06/2022 11:11:03
Posted by John Hinkley on 01/06/2022 10:24:05:
Chronos are advertising them as in stock, as are Axminster. Might be worth a phone call or email? I am assuming from your description that the lathe in question is PD400.
The chuck is for a PD230/E.
01/06/2022 09:58:31
This is the chuck -
https://www.amazon.com.au/PROXXON-24036-Jaw-Chuck-250/dp/B011RIM3NA/ref=sr_1_2?crid=170BIZ8PGJ6MQ&keywords=Proxxon+chuck&qid=1653983698&sprefix=proxxon+chuck%2Caps%2C255&sr=8-2
01/06/2022 08:29:59
Posted by bernard towers on 31/05/2022 21:44:44:
Can’t you just measure the pod? And as for the register it’s not the size that matters it’s the FIT!
If I had something to measure I would have done that. I want to see if I can adapt this chuck to another machine, which is why I am asking.
