Eric Cox | 23/05/2022 11:09:02 |
![]() 557 forum posts 38 photos | I have been cutting some slots in aluminium using a 1/4" end mill running at 2800 rpm and hand fed with a depth of 30 thou. The aluminium is sticking to the end mill and closing up the flutes. How do I over come this |
Ian Parkin | 23/05/2022 11:13:45 |
![]() 1174 forum posts 303 photos | Buy some wd40 in a 5litre container that comes with a hand sprayer..spray liberally on the cutter whilst machining..of course you can use the spray cans but the 5 litre route is cheap |
John Hinkley | 23/05/2022 11:18:06 |
![]() 1545 forum posts 484 photos | If not already, use some WD40 or paraffin for lubrication/cooling. Use a 2- or 3- flute end mill, if you're using a 4-flute one. Others will no doubt suggest an alteration to speeds and feeds as well. I use a single flute carbide cutter at 10,000rpm with a depth of cut of 1mm, but that's on a 3d router table with aluminium, with no coolant. John |
Craig Brown | 23/05/2022 11:21:39 |
110 forum posts 57 photos | When you say end mill are you using a 4 flute cutter? Slot drills (2 flute cutters) should be used for cutting slots. Along with a kerosene based lubricant as mentioned above |
Hopper | 23/05/2022 11:27:45 |
![]() 7881 forum posts 397 photos | What sort of aluminium? The "lower" grades can be nasty sticky stuff to machine and tend to clog cutters pretty well. Something like 6061 T6 will machine very nicely usually. Otherwise WD40 or kero as suggested. Maybe try dropping your rpm and see if that helps. |
Dave Halford | 23/05/2022 11:28:02 |
2536 forum posts 24 photos | Try 1000 rpm, the slower speed should reduce the heat and therefore the welding. Unless you have one of the less machinable grades of aluminium.
beaten to it. Edited By Dave Halford on 23/05/2022 11:28:35 |
Andrew Johnston | 23/05/2022 11:57:36 |
![]() 7061 forum posts 719 photos | I know the feeling: Can we assume that aluminium means an alloy? Pure aluminium is horrid to machine, bit like warm fudge. Summarising a few pointers: * Use 2 or 3 flute cutters * ideally use flood coolant or an occasional squirt of WD40 * If no coolant or WD40 can be used then a finish cut climb milling gives a much better finish * Highly polished carbide cutters are available, specifically for aluminium * Maximise depth of cut and minimise stepover, tends to give long thin swarf that is less likely to clog the flutes - Edit: for slotting one is stuck with full width cutting, flood coolant is the proper answer. Unless the swarf is continuously cleared not only will it tend to clog but will be recut which doesn't do the cutter any good * On aluminium alloys I run fast, several thousand rpm and high feedrates so one gets thicker swarf rather than fine which is more likely to clog the flutes. For example slotting 22mm deep on 6082 with a 3-flute 6mm carbide cutter parameters were 2500rpm, feedrate 400mm/min and stepdown 5.5mm per pass. Of course I was using flood coolant, primarily to clear the swarf rather than provide cooling. Andrew |
Andrew Entwistle | 23/05/2022 14:13:33 |
![]() 120 forum posts 218 photos | Since moving to cheap polished carbide 1/8" single flute cutters @3000rpm+ I have been able to leave the CNC unattended cutting soft aluminium to depths of 18mm, without the need for air jet/WD40/Paraffin/IPA to prevent clogging of cutters. I don't know if this success would scale up to 6mm/1/4" cutters though. Andrew. |
John Haine | 23/05/2022 14:40:14 |
5563 forum posts 322 photos | On the CNC I tend to use 5000+ rpm even with 6mm cutters on 6061 Ali. I believe that cutting action basically involves the metal softening at the tool edge, if run fast it gets softer and has a chance to flow off before sticking. This is using 2 or 3 flute mills, preferably the ones made for aluminium. I don't use coolant but do have an air jet to clear the chips away. |
Howard Lewis | 23/05/2022 16:58:33 |
7227 forum posts 21 photos | Aluminium does tend to weld to the cutter. As suggested, reduce the speed. That should reduce temperatures at the cutting edge. And for Aluminium, paraffin (kerosene) is the usual lubricant, with WD40 or its lookalikes as alternatives For an end mill, the feed rate should be no more than 0.002"/ tooth, so at 1,000 rpm and a 4 flute cutter, so less than 8" per minute. On then other hand, don't let the cutter idle over the work, to rub and generate heat. HTH Howard.. |
Elliot Hirst | 23/05/2022 19:24:48 |
13 forum posts 8 photos | Our local tooling engineer was known in the factory as “Mr Pledge”. He sprayed cutters with furniture polish containing silicone. Cutting results were good and factory smelled pleasantly of lavender. |
Eric Cox | 24/05/2022 09:59:44 |
![]() 557 forum posts 38 photos | I dropped the speed down to 1000 rpm.and it worked fine, |
mark costello 1 | 24/05/2022 20:41:47 |
![]() 800 forum posts 16 photos | If You'all go to boot sales, buy up any cheap cans of spray on penetrant You can find. It all works on Aluminum. |
Dennis Pataki | 24/05/2022 21:59:21 |
16 forum posts | One old time lubricant for machining aluminum was a 50/50 mixture of kerosene and lard oil. |
Bill Pudney | 25/05/2022 00:40:03 |
622 forum posts 24 photos | I may as well contribute, I don't like using WD40 except for removing water , so I use kerosene (paraffin) and a really sharp cutter, polished if possible, and run it at as fast as I can on my little Sieg X2 , a max of about 3,000 rpm. I know a lot of people like WD40, but I found it leaves a waxy deposit all over everything. Some people may like that I suppose. cheers Bill |
Bill Pudney | 25/05/2022 10:23:20 |
622 forum posts 24 photos | I mean't to add.....don't use cheap/soft al.alloy. Use only the harder grades like 6061, 6082, 2024, 2014, 7075 everything at T6 or better. The soft alloys, like those bought in a hardware shop are rubbish, it's just a waste of time. cheers Bill |
