Myford Super 7 gib screws
Ivy16/03/2022 13:07:57
77 forum posts
Can someone put a photo of the Myford Super 7 saddle adjusting gib screws please?
I need all four and the ML7 ones are available but different. Super 7 ones not available from Myford so I bought some from another place and they seem to be ordinary ML7 type although advertised as Super 7.
I don't have the old ones to see how they differ
I always get good info and help here so thanks for reading.
Swarf, Mostly!16/03/2022 13:29:30
753 forum posts
80 photos
Hi there, Ivy,
I can't answer your query directly. However, if you go on the Myford web-site, they have the illustrated parts lists (aka 'exploded diagrams' ) for all the major assemblies of both the ML7 and the Super 7. They are (last time I looked ) down-loadable.
Best regards,
Swarf, Mostly!
Ivy16/03/2022 13:34:48
77 forum posts
Thanks Swarf, but I already looked there and the pictures are not at all clear
Mike Crossfield16/03/2022 13:43:32
286 forum posts
36 photos
Lathespares stock saddle gib adjusting screws for certain Super7 models, and there are pictures on their website.
https://www.lathespares.co.uk/myford-super-7-saddle-adjusting-screw
hth
Mije
Ivy16/03/2022 13:52:30
77 forum posts
Posted by Mike Crossfield on 16/03/2022 13:43:32:
hth
Mije
That is "the other place" I mentioned.
I don't want too take it up with them until I am sure of what's what.
Grindstone Cowboy16/03/2022 14:31:20
1160 forum posts
73 photos
Well, there's really only two ways they can be wrong, either length or thread (or both). If they screw in and they are long enough to take the lock-nut with a bit extra, then they'll be fine.
Rob
DiogenesII16/03/2022 14:52:14
859 forum posts
268 photos
FWIW (as an ML owner) I think it depends on your machine - there's at least two types of screw, an 'early' one with a round end, and a 'late' one which used dog-points to locate the gib..
..but I'm a bit out of my province with S7s.. ..if no-one else comes along, tell us whether the gib-strip has 'divots' for location, or whether there are through holes or a rebate...
Ivy16/03/2022 15:00:10
77 forum posts
Posted by Grindstone Cowboy on 16/03/2022 14:31:20:
Rob
Rob, here is the problem.
The ones I have are threaded on the outside end only for about a 1/2 inch or so, this means that the thread does not meet the female thread in the saddle. The saddle screw holes are counter bored too deep. So I think the correct ones must be threaded the full length or nearly full.
The reason I need to see the correct factory fitted ones is so I can compare with what was sold to me as "Super 7" screws. Their sales description maybe wrong or I have a perculiar Myford.
Ivy16/03/2022 15:36:15
77 forum posts
Posted by DiogenesII on 16/03/2022 14:52:14:
The gib has one through hole for the third from left screw to locate into and hold the gib in place. I don't have access to the machine until tonight.
Grindstone Cowboy16/03/2022 15:49:09
1160 forum posts
73 photos
See your point. If you turn them around, will they screw in successfully - which will at least prove they have the correct thread (2BA IIRC). But if the whole length of the thread is taken up by the counterbore before it engages, then definitely the wrong screws OR a modified lathe. I can't think why the holes would need to be counterbored?
Rob
ChrisLH16/03/2022 16:26:07
111 forum posts
7 photos
My S7 is rather old which might make a difference (SK 2142) but here are the dimensions of the screws I have extracted from the second and third holes, both the same.
Overall length 1.875
0.250 BSF threaded length 0.650
Slotted for flat blade screwdriver on the threaded end
Plain end approximately spherical
Grindstone Cowboy16/03/2022 16:38:38
1160 forum posts
73 photos
Chris, just as a matter of interest, are the holes in your S7 counterbored?
Thanks, Rob
speelwerk16/03/2022 16:48:57
464 forum posts
Not from the UK but these seems the ones you are looking for, Niko. **LINK**
John Purdy16/03/2022 16:53:18
431 forum posts
252 photos
Ivy
On my S7, serial # SK127323 mfg 1976, the screws are all 1/4 BSF threaded full length, screwdriver slotted end. Lengths as follows left to right: 2.750 round point, 2 910 dog point, and 2.750 round point. The holes in the saddle are counter bored .275 dia. by 1.950 deep.  Hope this helps.
Edited By John Purdy on 16/03/2022 17:09:42
DiogenesII16/03/2022 17:03:34
859 forum posts
268 photos
In the only copy of the S7 manual that I have (PXF), it shows three screws; so it probably ain't that one; it uses screws A9183 (2 off), and A9184 (1 off).. ..I think it's these screws you got from L/spares
ON the basis that you have four screws, I think your model is the Non-PXF one -
Myford Ltd supply a parts drawing of the Non-PXF carriage which shows four screws;
(K53) Part No A7760 Saddle Gib Adjusting Screw, 3 off
(K58) Part No A 7424/1 Gib Strip Adjusting Screw, 1 off
Hexagon Lock Nut (1/4" BSF), 4 off
Copy of dawing here
Myford Ltd - Super 7 Carriage Assembly Non Power Cross Feed
..it still doesn't help much with comparison, I couldn't even find a picture of these screws under either part number..
Edited By DiogenesII on 16/03/2022 17:04:38
Edited By DiogenesII on 16/03/2022 17:05:17
Ivy16/03/2022 17:06:51
77 forum posts
Well it looks like mine should be like the ones in speelwerks link and John Purdy has.
Chris H has the ones I bought by mistake, but these are the same as the ML7 I think.
As always model-engineer has helped me again.
Thank you all.
ChrisLH16/03/2022 17:32:06
111 forum posts
7 photos
Rob,
No, the holes are not countersunk.
John,
Surprising that later screws are so much longer than older ones.
speelwerk16/03/2022 18:22:49
464 forum posts
They are longer because the later S7 has power cross feed therefore the apron is wider to accommodate the gears for it. Niko.
Ivy16/03/2022 18:47:21
77 forum posts
My lathe is 1962/63 and needs the same as John Purdy's 1976 lathe.
Mine must have had a replacement saddle at some point.
John Purdy16/03/2022 18:52:49
431 forum posts
252 photos
I should have said my lathe is a S7B with power cross feed. As Speelwerk says the saddle and the apron are different from the earlier non power cross feed model, thus the screws will be different.
