Member postings for Ivy
Here is a list of all the postings Ivy has made in our forums. Click on a thread name to jump to the thread.
Thread: Scaping bearings
30/05/2022 15:37:35
Posted by old mart on 30/05/2022 13:42:49:
I would steer clear of white metal and use bronze if I was making bearings for a lathe. They would need provision for lubrication and if the top half has a hole for oil, then an oil groove in the bore would be easy to produce. You can produce a helical groove in the bores of both bearing shells with a ball end cutter in a Dremel or similar. Not a stone for fear of leaving abrasive particals. A groove about 1/16" wide and 1/32" deep would be more than adequate starting at the oil hole and stopping just before the outside edge. Some split bearing shells have the grooves in an "X" running from the oil hole and continuing at the split line to the other shell half. My choice would be leaded gunmetal, it makes nice nuts and probably good bearings as well. Perhaps somebody could have a better bronze alloy to recommend for bearing material.
Old Mart, I was thinking of something from page 48 of the M-Machine catalogue? What do you think?
Although I am getting way ahead of my self at the moment. I was looking for advice on feasibility first.
www.m-machine-metals.co.uk/downloads/metals catalogue.pdf
Thanks again for your contribution.
Ivy.
30/05/2022 11:34:56
Nigel B.
Thank you for taking the time to share your experience.
I have several workshop practice books although I do sometimes find a demonstration can be worth several written articles quite often.
Ivy.
29/05/2022 07:52:23
There is real danger in getting engineering advice off YouTube
Trouble is as an amateur hobbyist with no more than CSE metalwork for experience and no access to real world help I watch lots of youtube and read forums if I get stuck on something. The alternative is to give up.
Someone mentioned Blondie, I think she is great, may not be text book or 100% in everything she does but always says, "this is how I did it", mistakes and all and that is a great help. This old Tony and Doubleboost are great entertainment too.
Edited By Ivy on 29/05/2022 07:54:43
28/05/2022 20:03:21
SillyOldDuffer / Dave.
I understand what you mean about some youtubers and I don't automatically assume the worst or best in people that's one of the reasons I asked here. Some don't communicate very well or at all, some are brilliant at editing, with all the doubt that adds and some make excellent teachers for the likes of me.
I acknowledged the bad comparison I made with the IC engines but unfortunately that took over and started to come across as a, "I know more about engines than you" competition. And I also know from other forums (motorcycle related and predominately American} that they can be very cliquey if you don't blindly follow the script.
My requirements are very crude by some standards and although Old Mart is the only person to offer an alternative to scraping I am sure his method will serve me more than well enough for the rest of my life. Fortunately I have another lathe that turns out good work by my standards so nothing ventured nothing gained.
28/05/2022 10:48:48
A chap on youtube eh?
I didn't want to name him without his knowledge. There are lots of youtubers that really know their stuff and are happy to show it and discuss.
You can always trust the internet!!!
Isn't this the same internet?
28/05/2022 09:33:19
As I am not likely to be machining parts for Red Bull Racing or the aerospace industry any time soon and this lathe runs at maximum speed of 640 RPM I am going with Old Marts method.
I am experienced in engine repair and assembly but machining is just a hobby that I am not so good at.
Due to my stupid comparison the engine side of the discussion has really taken over and that was not really my concern but thanks for all the contributions.
27/05/2022 21:05:58
Posted by old mart on 27/05/2022 21:00:23:
Ivy, if your spindle is getting reground, the bearings could be produced at the same time with bores between 0.0005" and 0.001" bigger and then cut in half afterwards. They would have to be made with the same outside dimensions as the old ones. The better the finish in the bores the less running in they would need. Because the S & B model A bearings are adjustable, (the third type in my earlier post) they can be run until the headstock only gets warm after 20 minutes running at top speed. With shims you could gradually tighten the caps until the bearings got above warm and then go back to the earlier shim thickness. The proceedure will take a lot of time and patience but your lathe will be as new in the spindle department. I would recommend one of the bronze types for the bearings. If there is provision for oil grooves the bearings will last longer. Also there will need to be provision for the thrust taken if using a centre in the tailstock or drilling.
Thanks Old Mart. We are on the same wavelength.
27/05/2022 21:03:38
Posted by not done it yet on 27/05/2022 20:21:46:
bearing sizes are available to buy and fit and forget.
These are denoted as precision bearing shells, not rough cast (or turned) items which are required to be dressed to the shaft - particularly where the underlying mounting may not be perfect.
You may have not noticed that your kwaka shafts/bearings are continuosly pressure fed with oil (not a simple drip feed and total loss system like the bearings with which you are comparing. Indeed the precision plain bearings in engines generally require about 5psi (~1/3Bar) to maintain a lubrication film between shaft and bearing, to avoid rapid destruction of the very thinly constructed bearing white metal deposited onto the shell backing material.
You would not be able scrape those precision shells because the white metal is only a few thousandths of an inch thick! That construction, using far less material (particularly the expensive white metal component), superseded much thicker besrings that were adjustable (to an extent) by shim removal between the bearing halves as wear took place. Precision shell bearings are not adjustable, and when worn out often require the shaft surface to be precision ground to a different undersize to accept a new set of bearings that match the shaft size precisely.
Additionally, engine crank-case bearings (particularly those with intermediate main bearings) have to be very well aligned to avoid uneven wear (or early failure). This is a standard level of precision engineering, these days, and is far better than older designs which, while being modern in their day, was far from the precision of modern equipment.
Yes, I understand automotive engine assembly and bearings very well.
I made a poor comparison with the bike engine.
I still don't really get why if a bearing is made to the spindle it will be used with it needs "scraping in".
27/05/2022 19:10:52
Posted by old mart on 27/05/2022 18:47:05:
I would fit the bearings and after making sure they were not tight, just run them for a short while with plenty of lubrication. Then dismantle and look for tight areas and scrape then lightly and repeat. The design varies a great deal, from clamped and shimmed bearing halves, tapered designs which can be adjusted by axial means and also parallel surfaces which have bushes made like er collets which can be closed down by axial adjustment. Each style needs slightly different approaches. There are certainly no traces of scraping in the spindle and bushes of the Smart & Brown model A lathe. Any scraping like bedways get would be detrimental to a rotating bearing, only the rings of tighter contact require attention.
I was thinking along the same lines as you. I also saw a chap on youtube who fitted new bearings to his Myford ML7 and said no scraping was needed, he showed the results of the change including running temperature at the bearing caps. I am confident he knows what he is doing.
I would like to get a spindle reground on the bearing journals and make new bearings for it but I am not at all confident about scraping, I've never done anything like that.
It's not a Myford, but the same arrangement as an ML7. Split, parallel bearings shimmed for clearance.
Edited By Ivy on 27/05/2022 19:11:42
27/05/2022 18:05:47
Posted by Howard Lewis on 27/05/2022 17:35:29:
Low speed drip fed bearings and high speed, pressure fed bearings is not am good comparison.
The IC engine bearings are fed with a copious supply of oil under pressure and easily build up a dynamic wedge of oil.
The headstock bearings of a Myford are drip fed and run at comparatively low speed, and are probably designed for much smaller clearances. (A high speed IC engine will be designed for circa 0.002 - 0.004" 0.05 - 0.1 mm clearance, to allow a good flow of oil, to provide cooling as well as lubrication).
The purpose of blueing and scraping will be to maximise the area riding on the dynamic wedge of oil; possibly boundary lubrication only a few molecules of oil thick.
A headstock with automotive clearances would be classed a badly worn machine tool..
Thank you Howard, that's answer makes a great deal of sense.
27/05/2022 17:35:15
Posted by mgnbuk on 27/05/2022 17:25:56:
As an example I have a Kawasaki engine that runs at 10,000 RPM all day long, the bearing sizes are available to buy and fit and forget.
But if you look at the factory rebuild manual, it will tell you how to select the correct size bearing shells from a table - look up the crank & housing dimensions (often coded on the parts with coloured dots or simliar) and it will give you the correct bearing to use to get the desired clearance. Mass produced engine components are graded during production & assembly from the graded parts to get the required running clearances is easily assured.
Not so with a one-off or low volume application, hence the need to "check and adjust" by a suitably trained fitter. A true "fitter" is not just an assembly monkey - they make parts fit together as the designer intended..
Nigel B.
Yes, I know. But if a bearing is made to the shaft that's the same thing isn't it?
The different sized bearings you mention are different in size by "oil film thickness".
27/05/2022 17:24:05
Posted by HOWARDT on 27/05/2022 16:19:43:
Scraping is done on larger bearing halves to break the surface and create pockets for some oil retention. A smooth bearing surface and a smooth shaft which are both perfectly round will not leave room for oil between the surfaces causing excess wear and heat build up.
Oil grooves retain oil.
27/05/2022 17:22:06
Posted by Robert Butler on 27/05/2022 16:17:22:
Ivy
Fit and alignment are critical.
Robert Butler
Can you elaborate?
27/05/2022 17:21:42
Posted by Dave Halford on 27/05/2022 16:15:55:
Isn't this more to do with poured white metal bearings from a 100 years ago?
Possibly, but is it still needed with modern machining?
27/05/2022 16:05:28
I hope this does not start an argument.
I expect people have different opinions on this. So here goes.
Is it really necessary to scrape new headstock bearings? The reason I ask is because on IC engines with plain bearing cranks the bearings are obviously not scraped and the RPM and stresses are surely much higher than my old lathe headstock.
As an example I have a Kawasaki engine that runs at 10,000 RPM all day long, the bearing sizes are available to buy and fit and forget. I have rebuilt these engines with no reliability issues, or vibrations or noises. Any runout would cause sever vibration at these RPMs.
What do you think.
Ivy.
Thread: Myford Super 7 gib screws
17/03/2022 15:23:40
SillyOldDuffer,
The lathe came to me in a semi dismantled state and a few fasteners were lost, these gib screws are the only specialised screws missing, everything else is normal industry standard.
It came from a commercial workshop but is in otherwise very good order bar the paint. In fact at todays prices for Myford parts and accessories (that discussion is for another day) I did very well here.
17/03/2022 12:37:40
Alan, thanks for coming into the discussion.
What you say about Myford (Beeston) not making random changes is what I have always thought and must respect your experience.
I think the counter bores must be a later modification by a previous owner. Although I can't imagine why.
Anyway I have ordered some 1/4 BSF studding to hold everything in place temporarily and then I can make something more satisfactory.
Thanks again all.
16/03/2022 19:09:34
Posted by John Purdy on 16/03/2022 18:52:49:
I should have said my lathe is a S7B with power cross feed. As Speelwerk says the saddle and the apron are different from the earlier non power cross feed model, thus the screws will be different.
This is giving me brain ache now.
The screws I need are the same as yours, but I need four not three and my lathe is not power cross feed.
I didn't think Myford were into making random changes on a whim, but maybe they were.
16/03/2022 18:47:21
My lathe is 1962/63 and needs the same as John Purdy's 1976 lathe.
Mine must have had a replacement saddle at some point.
16/03/2022 17:06:51
Well it looks like mine should be like the ones in speelwerks link and John Purdy has.
Chris H has the ones I bought by mistake, but these are the same as the ML7 I think.
As always model-engineer has helped me again.
Thank you all.
