How hard is gauge plate?
pgrbff06/03/2022 15:17:19
261 forum posts
31 photos
I'm waiting for some gauge plate to arrive from the UK.
I have to drill and tap 4 through holes in a 1/4" strip, 10x24 UNC and 1/4".
I only have plug taps and hope they will be OK, but having never heard of gauge plate I have no idea how hard it is. Like stainless steel? Less hard?
SillyOldDuffer06/03/2022 15:25:46
10668 forum posts
2415 photos
It's delivered soft in annealed condition and is easily machined.
Gauge plate is usually hardened after being machined into a part. Typical instructions here. The plate is O1 or something very like it. Being a tool-steel, it can be made hard enough to bounce a file off.
Speedy Builder506/03/2022 15:46:06
2878 forum posts
248 photos
Drill your holes oversized to reduce load on the tap, use new, sharp taps. Use cutting oil and you should be OK.
Baz06/03/2022 15:46:40
1033 forum posts
Nice sharp drills and you will be OK. Nowhere near as bad as stainless.
pgrbff06/03/2022 16:30:29
261 forum posts
31 photos
Thanks for the replies.
Andrew Johnston06/03/2022 16:31:48
7061 forum posts
719 photos
In the fully tempered state gauge plate is between 15 and 20Rc, so not particularly hard. However, you will struggle with plug taps only, unless you go for a shallow thread engagement. I expect you will need rather less than 50%. It would be sensible to use a taper tap. New ones, from Drill Service, are around a fiver.
pgrbff06/03/2022 16:35:31
261 forum posts
31 photos
They may only cost a fiver but I'm in Italy and it cost me nearly £20 in taxes and charges and postage to buy 2 £6 taps from the UK. Total cost £32
bernard towers06/03/2022 17:25:03
1221 forum posts
161 photos
surely there are tool suppliers in Italy/?
noel shelley06/03/2022 18:32:42
2308 forum posts
33 photos
You will struggle to make a thread with only plug taps ! If you use a larger drill you will reduce the engagement to a point the thread may well strip with little load. Good luck. Noel.
Baz06/03/2022 18:43:02
1033 forum posts
Isn’t there anyone in Italy who could grind a lead on one of your taps for you?
Mark Rand06/03/2022 19:54:39
1505 forum posts
56 photos
For the next project, it might be worth getting taper or second cut taps. They'll do a full thread in a through hole if the tap can use its whole length and they can be converted into second or plug taps by grinding part of the end off.
Note also:- UK has taper, second and plug taps, US has taper, plug and bottoming tapse. disgust
pgrbff07/03/2022 07:41:47
261 forum posts
31 photos
Posted by bernard towers on 06/03/2022 17:25:03:
For what are typically American sizes at a reasonable cost?
There doesn't seem to be a hobby market here. I recently tried to buy a spare for a Mitutoyo gauge, which cost 2 euro. The supplier didn't take orders less than 50 euro and I had to have a VAT number.
pgrbff07/03/2022 07:45:12
261 forum posts
31 photos
Posted by Baz on 06/03/2022 18:43:02:
I'm sure there is somewhere. Finding them is the problem and feeling confident they know what they are doing.
I've been trying to get a piece of cast iron repaired for the last year. Everyone says they can do it, mostly tractor repair workshops, but I'm not convinced and none of them gives me the confidence they will succeed. They just say they will try.
pgrbff07/03/2022 07:48:20
261 forum posts
31 photos
Posted by Mark Rand on 06/03/2022 19:54:39:
What exactly is a tap plug? I understand it has a more agressive longer taper?
In the past, I would have bought a full set but it is just not economical to do so anymore and I hate buying cheaper unknown quality from China.
pgrbff07/03/2022 07:50:47
261 forum posts
31 photos
I tried to err on the slight oversize with the drills. 3.85mm and 5.1mm.
Michael Gilligan07/03/2022 07:55:39
23121 forum posts
1360 photos
Posted by pgrbff on 07/03/2022 07:41:47:
There doesn't seem to be a hobby market here. […]
This ebay Seller looks promising : **LINK**
https://www.ebay.co.uk/str/milancentral
… I have given the U.K. ‘Shop’ but presumably they also list on ebay.it
[ despite actually being based in Hong Kong ]
Edited By Michael Gilligan on 07/03/2022 08:03:15
pgrbff07/03/2022 08:01:43
261 forum posts
31 photos
Posted by Michael Gilligan on 07/03/2022 07:55:39:
… I have given the U.K. ‘Shop’ but presumably they also list on ebay,it
I have seen them before. Hong Kong based.
Michael Gilligan07/03/2022 08:05:48
23121 forum posts
1360 photos
Sometimes you just have to go with the market:
https://www.ebay.co.uk/itm/363635079100?
pgrbff07/03/2022 08:17:32
261 forum posts
31 photos
I did find them when I was searching.
Normally I'll buy used UK manufactured as I probably will only use them once. But buying from China is the same as buying from the UK. I still have to pay extortionate handling charges, often 18 euro or £15, plus VAT.
The 2 taps I bought from the UK which weigh a few grams, cost £10 standard airmail. I know businesses have to make money but the postage cost was probably close to a fiver.
Michael Gilligan07/03/2022 08:46:34
23121 forum posts
1360 photos
Sorry for wasting your time … I will stop trying to help you.
