Vic | 21/02/2022 22:43:34 |
3453 forum posts 23 photos | A friend of mine is having some difficulty with the inverter on a lathe causing occasional signal drop out between a video camera and projector. It’s assumed this is through the mains wiring. Is there some kind of filtering device that could be placed between the mains socket and the camera to prevent this? TIA. |
Tony Pratt 1 | 21/02/2022 22:58:37 |
2319 forum posts 13 photos | Look at Clough42 on YouTube 3 years ago on this very subject Tony |
Pete Rimmer | 21/02/2022 22:59:46 |
1486 forum posts 105 photos | Yep, VFD input filter commonly available and not even that expensive. It's wired between the supply and the inverter drive. |
David Jupp | 22/02/2022 07:55:26 |
978 forum posts 26 photos | Quality of the VFD/motor installation may be a factor. To work well, input filter should be mounted on same metal backplane that the inverter is mounted on. A filter may not fix things if there are other issues with the installation. |
Andrew Johnston | 22/02/2022 08:12:46 |
![]() 7061 forum posts 719 photos | I'm not sure why it is assumed that the problem is due to conducted emissions down the mains? It's possibly more likely that the issue is due to radiated emissions. Is the cable from the VFD to the motor shielded? If so, is the shield grounded at one end or both ends? Does the problem occur when the VFD is on, but in standby, or only when the motor is being powered? How often does the comms dropout occur and how long is each dropout? As stated above mains filters are readily available, and are a good thing to fit, even though they may not solve the current problem. Andrew
PETER ROACH | 22/02/2022 09:31:59 |
50 forum posts 25 photos | Simple solution is turn the inverter off. Engineered solution is to put inverter in a grounded box with correct front end filter for it. Incorrect filter could further tune noise, rather than attenuate. Mount as close to motor as possible and screen cables, grounding at one end only so as not to create loops, back to initial star ground point. If you have a pendant, screen the wire to than also. Check any LED lights for emissions also with a radio. |
Neil Lickfold | 22/02/2022 09:33:11 |
1025 forum posts 204 photos | I tested tonight 2 different VFD's to see if they interfere with the TV and they did not. Mine do have a built in filter to the mains supply. Also all my shop and house wiring is going through the new breakers with the earth leakage things.. Either called ELCB (older models) or an RCD (the newer one.  Neil |
Vic | 22/02/2022 11:35:50 |
3453 forum posts 23 photos | Posted by Tony Pratt 1 on 21/02/2022 22:58:37:
Look at Clough42 on YouTube 3 years ago on this very subject Tony That’s very helpful Tony, thank you. I will pass on the link. Apparently the lathe and camera remain in fairly close proximity. The problem is somewhat reduced but not eliminated if the two items are physically plugged as far away as possible from each other.
David Jupp | 22/02/2022 12:51:56 |
978 forum posts 26 photos | Regarding connection of cable screens to ground, and on grounding of all items - I suggest you follow recommendations of the VFD manufacturer. Whether to ground one or both ends of the cable screen will get you at least 3 different opinions... |
Martin Johnson 1 | 22/02/2022 12:56:10 |
320 forum posts 1 photos | I recently upgraded to a cheap ebay inverter package on my lathe and while I was on the job I installed a small power supply for my Arc Euro digi bar readout. Inverter works fine, digi bar works fine until the lathe is switched on. It seems interference wipes the settings on the digi bar readout. If I use a battery supply to the digi bar all is fine, so I infer the problem is mains borne. Have operated for some months on batteries to the digi bar now. Must get that round tewit. Martin |
old mart | 22/02/2022 15:31:22 |
4655 forum posts 304 photos | When I bought a Scneider VFD for the museum's Tom Senior light vertical, I had the advantage of being able to print out the quickstart guide from The Inverter Supermarket. Following this was easy and I paid strict attention to the screening of all the wiring, including remote controls and having a fully earthed metal box to house the inverter. This was in a different enviroment from a home installation and the strict adherance to the rules was necessary. So far it has caused no interference to mobile phones, radios or wifi, including 433Mhz remote controls. |
Vic | 22/02/2022 19:10:48 |
3453 forum posts 23 photos | I’ve just seen this in the lathe manual. “If a filter is required to reduce EMI install it as close as possible to the AC drive. EMI can also be reduced by lowering the carrier frequency. When using a GFC (Ground Fault Circuit Interrupter), select a current sensor with sensitivity of 200 mA, and not less than 0.1 second detection time to avoid nuisance tripping.” This seems to be saying: “We know our inverter causes EMI but we’ve decided not to deal with the issue”. |
Robert Atkinson 2 | 22/02/2022 19:46:38 |
![]() 1891 forum posts 37 photos | If it is aood quality drive by a well known manufacturer, follow their installation recommnedtions. Install the inverter in a metallic enclosure Lacing advice from drive manufacturer dround the shield/armour at the "wall" of the metallic box enclosing the drive. Metallic cable glands designed for this are available. keep it insulated at he motor end (use a plastic strain relief) and ground the motor housing with the fourth core in the cable. Use screened cabble for ny control pendant or similar. That's mid-level good practice. Robert G8RPI. |
Vic | 22/02/2022 19:59:06 |
3453 forum posts 23 photos | The lathe and associated inverter are as supplied by the retailer. The inverter is already in a metal box mounted at the back of the lathe. The inverter is possibly a Delta S1 (shown in the manual) but I’ve not actually seen it. |
Robert Atkinson 2 | 22/02/2022 20:06:15 |
![]() 1891 forum posts 37 photos | Go back to the vendor of the lathe and ask them to fix it or provide details of the EMC qualification. Robert G8RPI. |
Vic | 22/02/2022 20:20:39 |
3453 forum posts 23 photos | Posted by Robert Atkinson 2 on 22/02/2022 20:06:15:
Go back to the vendor of the lathe and ask them to fix it or provide details of the EMC qualification. Robert G8RPI. The lathe is over ten years old and the issue has only surfaced since the video camera was replaced. |
Andrew Johnston | 22/02/2022 20:34:41 |
![]() 7061 forum posts 719 photos | Posted by Vic on 22/02/2022 19:10:48:
Industrially the VFD is considered to be a component, which is used within a larger installation. The need for EMI filters will be considered taking into account the whole installation. That may mean a VFD has it's own filter, or a filter is shared, or one isn't needed. Consequently most VFDs do not have a built-in filter. EMI might be lowered by reducing carrier frequency, but it's not usually clear cut. The carrier frequency determines how far apart the harmonics are spaced. How far the harmonics extend, at a significant amplitude, is determined by the speed of the waveform edges, which probably won't change much with changes in carrier frequency. Andrew |
old mart | 22/02/2022 21:02:43 |
4655 forum posts 304 photos | I was worried about the leakage current from the filter causing the rcd's to trip, they are lower than domestic ones, but so far there has been no problem. |
Howard Lewis | 23/02/2022 06:23:50 |
7227 forum posts 21 photos | It is possible to buy power sockets with built in suppression. My VFD is fed from a double 13A suppressed socket, and no problems with interference to domestic TV or internet have been noticed. Howard |
PETER ROACH | 23/02/2022 08:24:56 |
50 forum posts 25 photos | Howard, 13A suppressed sockets are designed to suppress incoming spikes to IT equipment, not to reduce outgoing noise. They are typically based around a device that shorts to ground if a high voltage spike is seen. Even if they were, at the socket is not the ideal location since the cable from socket to VFD would still radiate any conducted from the VFD. If you need any additional filtering it needs to be as close to the source as possible, entry to the enclosure and chosen so that it attenuated the noise and not as a resonant with any existing front end filters in the VFD. Peter |
