Laser or water-jet cutter who hold stock of spring or tool steels
Matt N07/02/2022 10:16:32
11 forum posts
HI all,
I'm trying to find a laser or water-jet cutting service that holds stock of (2mm) spring and also (5 or 6mm) tool steels, or at least something higher yield than s355 which is the limit of what most seem to stock. Ideally, I don't want to have to buy a sheet of material to free issue.
Thanks in advance,
Matt
David George 108/02/2022 07:12:23
2110 forum posts
565 photos
Where are you based as it is difficult to suggest a cutting service without rough area.
David
JasonB08/02/2022 07:21:30
What size are the parts? You can get gauge plate upto 300mm wide 1 to 50mm thick which could well be cheaper than buying a 2 x 1m sheet. Subject to the minimum size they can place on the machine.
Most cutters will post small parts or use couriers if larger so location is unlikely to be an issue.
IanH08/02/2022 07:58:40
129 forum posts
72 photos
Give these guys a call **LINK** they cut some spring steel steering wheel spokes for me some time ago.
ian
Alain Foote08/02/2022 08:14:06
69 forum posts
10 photos
Try Model Engineers Laser **LINK**
Matt N08/02/2022 20:27:23
11 forum posts
Thanks for the business suggestions. Gauge plate would certainly do it, I'll compare prices.
Cheers
duncan webster08/02/2022 22:47:00
5307 forum posts
83 photos
Laser cut gauge plate will have rock hard edges due to heat affected zone, I'd stick to water jet or wire eroded
Edited By duncan webster on 08/02/2022 22:47:10
