Thread locking inside boilers
John Billard 124/01/2022 13:02:37
111 forum posts
What is the best sealant to use these days for screwed joints within a 5" gauge boiler when subsequent access might be "difficult".
Best wishes
John B
Former Member24/01/2022 13:22:14
1085 forum posts
1085 forum posts
Former Member24/01/2022 13:22:15
1085 forum posts
KWIL24/01/2022 15:03:51
3681 forum posts
70 photos
br,
It must be something you do, does not happen to me!
Grindstone Cowboy24/01/2022 15:58:49
1160 forum posts
73 photos
Not saying it's the cause of multiple posts, but I sometimes double-click where I should single-click.
And to (partly) answer John B's original question, I'm afraid I've never built a boiler. However, I have had success with this for other sealing requirements, and I'm sure I read somewhere that it's suitable for steam. Doubt whether it has any thread-locking capabilities, though.
Rob
Links to https://rectorseal.com/rectorseal-tru-blu-group/
John Rutzen25/01/2022 08:42:48
411 forum posts
22 photos
Hi, I think Loctite is ok with steam for say screwing a thread into a boiler to hold on a support bracket but it does lose it's strength as I found out. I had screwed my regulator rod into the cam it used to operate the device and sealed it with loctite. I steamed up and wondered why the loco wouldn't move - the thread had unlocked itself! So I don't know of any thread sealant which will do anything other than seal inside a boiler.
John Billard 125/01/2022 11:50:26
111 forum posts
Thanks for the replies. I am just interested in sealing threads at the moment e.g.main steam pipe in to the regulator and oil pipes etc into unions/bushes.
Farmer para 287 uses Boss White but this was 1964.
John B
Paul Lousick25/01/2022 12:16:14
2276 forum posts
801 photos
I used graphite sealant on the studs that screw into the barrel on my boiler. Graphite based compound is the traditional sealant for threaded and flanged connections on steam engines.
old mart25/01/2022 12:21:30
4655 forum posts
304 photos
Google Loctite thread sealants to get the exact specifications.                   https://www.turtle.com/ASSETS/DOCUMENTS/ITEMS/EN/Loctite_21472_Catalog.pdf
Edited By old mart on 25/01/2022 12:24:09
John Purdy25/01/2022 18:14:29
431 forum posts
252 photos
I have used Loctite PST high temperature  thread sealant #567 on my boiler fittings (internal and external), for many years and have never had a problem. Its a white paste in a tube, Loctite part #56747. It doesn't set hard so fittings can be easily removed in the future. According to the spec sheet its strength reduces to 55% of initial strength after 1000 hours exposure at 250C (482F). That's equivalent to a boiler pressure of about 550 PSI.
Edited By John Purdy on 25/01/2022 18:20:19
Edited By John Purdy on 25/01/2022 18:51:58
