Steam raising blower
Bill Dawes09/01/2022 18:30:41
605 forum posts
Hi all, anyone know of a secret supplier of these, seem to be in short supply, just waiting for response of Polly and hope they might be able to help.
Assume as with most things in life they come from China.
Bill D.
Bill Dawes09/01/2022 18:32:55
605 forum posts
My last couple of posts lacking in checking of grammar/spelling, must do better.
Bill D.
Baz09/01/2022 19:34:19
1033 forum posts
Blackgates sell steam raising blowers, I think the last ones they had were ex military things and they would take up to 24 volts.
Bazyle09/01/2022 21:10:36
6956 forum posts
229 photos
A number of years ago our club got a batch of 24v ex services blowers (valve equipment cooling fans I suspect) but on 12 v they didn't have the oomphf to raise a fire. On 24v they lift the coal off the grate. Just a bit of a pain having to have more than the usual 12v battery.
Harry Wilkes09/01/2022 21:16:25
1613 forum posts
72 photos
I have a Blackgates one that I keep in my riding on trailer for my 3" Burrell, it will just about raise the fire. Depending the size off engine they do work OK but though I didn't purchase mine I think them expensive for what they are the one I use to raise stem is home made job with speed control, a fellow club member uses a cheap blower for inflatables mounted at 45 degs on a short chimney extension and it works ok on his 4" engine
H
noel shelley09/01/2022 21:58:20
2308 forum posts
33 photos
I have just made one out of an old gas boiler blower admittedly at the moment its 240v but all you need is a small 12v motor to adapt it. Almost any gas fitter would probably give you one. Noel.
Baz09/01/2022 22:18:39
1033 forum posts
Bazyle interesting what you say about the blowers, mine is marginal on 12v but a bit over the top on 24v, I thought it was just me being hopeless at lighting a fire. I am one of the only ones to use electric blowers in our club, everyone seems to prefer compressed air, all the steaming bays are plumbed in to a compressor in the workshop.
duncan webster10/01/2022 00:15:24
5307 forum posts
83 photos
There was an article in ME a bit back about switch mode power supplies to give variable up to 24v output from 12v input. You can buy suitable modules off ebay. I've got 2 of those ex military blowers. I agree not enough oomph to raise the fire on my locos on 12v but fine on 24. The second one drive my fairground organ. It's a bit noisy for that application, something quiet would be better. I think I got them from somewhere in Wales.
Edit: just checked his website looks like he's sold out, steam fittings barmouth
Edited By duncan webster on 10/01/2022 00:17:54
Edited By duncan webster on 10/01/2022 00:20:49
Paul Lousick10/01/2022 00:29:34
2276 forum posts
801 photos
Making your own blower is not difficult as shown below:
Model Engineer,  Vol 187, No 4163 describes the making of an electric steam raising blower.
And a Youtube video called "Make a Simple & Effective Miniature Locomotive Steam Raising Blower"
Edited By Paul Lousick on 10/01/2022 00:31:06
RMA10/01/2022 09:03:57
332 forum posts
4 photos
I use one of these 12v ex military blowers with no trouble at all on 5 inch and 3.5 inch locos, using a car battery at home or the club 12v supply. Maybe they do take a little longer, but I have nothing to compare it with. They do need frequent cleaning out though. I think the availability is now very limited.
Clive Brown 110/01/2022 09:27:36
1050 forum posts
56 photos
I found blowers hard to source so I made one.
The rotor is 2 brass discs with 8 radial blades, o/a diameter is 2.5", all silver soldered. There's no real need for a volute. The rotor shaft spins on small ball bearings. At the high speed that it rotates I .found balance fairly important. The motor is 12v. All items were either from the scrap box or Ebay.
Raises steam OK on my Allchin and Simplex.
Edited By Clive Brown 1 on 10/01/2022 09:28:10
Bill Dawes10/01/2022 22:11:25
605 forum posts
Well guys, as I have posted before, I should be embarrassed at buying a fan, I am a semi retired engineering manager at an industrial fan and blower company!!, albeit a few hundred kw larger than our steam raising ones.
Truth is I can't be bothered, a nice cast ally one better appeals to me, have limited time to make models let alone anything else.
Polly models are helping me on this.
Thanks for replies.
Bill D.
bernard towers10/01/2022 22:15:34
1221 forum posts
161 photos
Performance of your fans can vary a huge amount , motor revs / fan efficiency / fan diameter. My blower uses a fan from a Fokker airoplane fan oven at about 4 plus inches and is extremely efficient.
Jon Lawes11/01/2022 06:34:40
1078 forum posts
Posted by Bill Dawes on 10/01/2022 22:11:25:
...Truth is I can't be bothered, a nice cast ally one better appeals to me, have limited time to make models let alone anything else....
I don't think there is anything wrong with that Bill. I sometimes look at some of the ancillary parts we need to run a locomotive (such as riding trucks) and think "rather than making this I could be making something I WANT to make" and just buy one. I only tend to make things if they are unaffordable or the ones on the market are not fit for purpose. After all, most of us are doing this for fun!
Bill Dawes11/01/2022 10:17:40
605 forum posts
When i first started in this ME lark I bought copies of MEW as well as ME, seeing all those exciting projects for tools, jigs, fixtures etc, but I soon realised that I would be spending all my time making things to make things without actually making anything other than things to make things!!!
Riding trolley is my next step, see my other post on Phoenix.
Bill D.
Bill Dawes17/01/2022 22:45:49
605 forum posts
Ordered one off Polly today, thay have just put some into stock.
Anyone know how many watts/amps the motors are, Polly did not know, they just test them on a small battery but I need to work out what size battery I will need unless I can find an old car battery, hoping for something a bit lighter than that though.
Bill D.
Jon Lawes18/01/2022 21:49:39
1078 forum posts
The small batteries used in Emergency exit lights or computer UPS systems are ideal; half the size of a car battery but often have plenty of capacity even when thrown out for being past a certain age (they are lifed components). If you are anywhere near me in the SW of the UK I might even have a spare you can have.
noel shelley18/01/2022 22:22:48
2308 forum posts
33 photos
A 12v 7Ah gel cell will fit in your pocket about £20.00 You will need a charger for this type of battery. Noel
Bill Dawes19/01/2022 17:46:16
605 forum posts
Thanks for that Noel, am I correct in thinking that a gel battery requires a special charger? ie not a lead acid car battery charger.
Blower arrived today, excellent service from Polly.
Bill D.
Bill Dawes19/01/2022 17:46:17
605 forum posts
Bill D.
