john steel 1 | 11/12/2021 11:43:25 |
![]() 28 forum posts 13 photos | I have a Warco Major milling machine and have just bought a set of chuck/collets from Lycorish for £55.29. My problem is when I put the dial gauge on the shaft it has a run out of half a thou very good, but when I move it down to the tool and the nut the gauge goes hay wire there is so much wobble I have cleaned the collet inserts and tried different tools which are brand new but it’s still the same what am I doing wrong Please help as I am new to milling. |
Emgee | 11/12/2021 11:56:51 |
2610 forum posts 312 photos | If you made sure everything was clean before fitting the chuck to the spindle and you find run-out after that check the inside bore where the collet fits for runout, if that's as good as the spindle then the problem is with the collets. You may be able to return the collets and/or the lot for a refund. Emgee |
Pete Rimmer | 11/12/2021 12:01:30 |
1486 forum posts 105 photos | If the collets are ER type you have to load the collet into the nut before you put them into the chuck. The face of the collet should sit at or very close to the face of the nut. If it doesn't, you probably don't have the collet fitted correctly. |
john steel 1 | 11/12/2021 12:05:41 |
![]() 28 forum posts 13 photos | Iycorish 9Pcs Er32 Spring Collets Set 2/4/6/8/10/12/16/18/20Mm + 1Pcs Mt3 M12 Er32 Collet Chuck Morse Taper Holder Collet Power Tool Set |
SillyOldDuffer | 11/12/2021 12:31:26 |
10668 forum posts 2415 photos | Posted by Pete Rimmer on 11/12/2021 12:01:30:
If the collets are ER type you have to load the collet into the nut before you put them into the chuck. The face of the collet should sit at or very close to the face of the nut. If it doesn't, you probably don't have the collet fitted correctly. +1, well worth double checking. Not clicking ER collets into the chuck properly is a common beginner booby trap. How to do it isn't immediately obvious. You can guess how I know. Click on this ArcEuroTrade link for pictures and description. Fingers crossed that's the problem - easy fix. Dave
john steel 1 | 11/12/2021 13:28:25 |
![]() 28 forum posts 13 photos | Thank you everone and Dave and Pete now I have the collets installed correctly there is a big improvement I have 20thou on the nut and 40thou on the tool is this OK could probably impove the tool with different ones |
Speedy Builder5 | 11/12/2021 14:14:12 |
2878 forum posts 248 photos | I hope you don't mean 20 - 40 thousandths of an inch !! a thousandth is 0.001". (a hair diameter is approx 0.003" to 0.007" Did you mean 0.0002" - 0.0004" ? ie: 2 - 4 ten thousandths of an inch perhaps ? What are you using to measure, a DTI - have a look on the dial to see what the divisions are. Bob |
not done it yet | 11/12/2021 14:23:18 |
7517 forum posts 20 photos | What are you using to measure, a DTI Don’t use a dti - use a dial gauge. One only indicates a change, the other actually measures the change. |
Bill Phinn | 11/12/2021 15:18:27 |
1076 forum posts 129 photos | Posted by not done it yet on 11/12/2021 14:23:18:
Don’t use a dti - use a dial gauge. One only indicates a change, the other actually measures the change. Unless you're using terminology in a way I'm unfamiliar with, I'm mystified by that claim. Can you explain further? |
Speedy Builder5 | 11/12/2021 15:38:00 |
2878 forum posts 248 photos | Bill, Not done it yet is being a little precise and could be more helpful if he had explained the difference. I believe that a DTI is a finger gauge which Generally has a smaller movement that a Dial Gauge. That said, all the DTIs that I have seen are graduated and equally acceptable for measuring distance within their range. For John's application, I would consider a DTI or Dial Gauge to be quite acceptable. Bob |
john steel 1 | 11/12/2021 15:44:24 |
![]() 28 forum posts 13 photos | Sorry its a new dial gauge and I forgot its metric so its Fluctuating in thous 0.020 ether side of zero |
john steel 1 | 11/12/2021 16:18:19 |
![]() 28 forum posts 13 photos | With the new metric gauge its 0.20mm ether side of zero think the old gauge is no good |
Bill Phinn | 11/12/2021 16:39:28 |
1076 forum posts 129 photos | Posted by Speedy Builder5 on 11/12/2021 15:38:00:
Bill, Not done it yet is being a little precise and could be more helpful if he had explained the difference. I believe that a DTI is a finger gauge which Generally has a smaller movement that a Dial Gauge. That said, all the DTIs that I have seen are graduated and equally acceptable for measuring distance within their range. Thanks for the confirmation, Bob.
Posted by john steel 1 on 11/12/2021 15:44:24:
Posted by john steel 1 on 11/12/2021 16:18:19:
With the new metric gauge its 0.20mm ether side of zero think the old gauge is no good 0.020mm would be very acceptable, John; 0.2mm wouldn't. |
John Baron | 11/12/2021 19:47:51 |
![]() 520 forum posts 194 photos | Hi John, Guys, Check the insides of your collets very carefully ! This is what most of mine were like. I used a Stanley knife blade and a stone to clean the swarf remains up. After that I could easily get a couple of tenths of a thou or better.
