Thomas Gregory 1 | 10/12/2021 12:37:03 |
15 forum posts 8 photos | I need some 2"1/2 x 1/2 flat mild steel which I need to bore a hole and put a radius on the flat corners (if that makes sense) using the lathe. I see lots of EN3B about but is there anything else that may be suitable? M-Machine sell EN8 and EN32B but searching looks like there's a lot of issues machining these? Edited By Thomas Gregory 1 on 10/12/2021 12:55:47 |
JasonB | 10/12/2021 13:02:18 |
![]() 25215 forum posts 3105 photos 1 articles | EN3B is not a problem to machine and should cut easily and give a good finish, I use it a lot on my fabricated engines. |
Thomas Gregory 1 | 10/12/2021 13:36:49 |
15 forum posts 8 photos | Just what I wanted to hear, thanks. |
Bo'sun | 10/12/2021 14:46:08 |
754 forum posts 2 photos | While vaguely relating to this thread, has anyone come across a "succinct" comparison chart of commonly used steels in model engineering with EN numbers, properties, machinability, etc, and cross reference to current specification numbers. |
Thor 🇳🇴 | 10/12/2021 16:14:59 |
![]() 1766 forum posts 46 photos | Posted by Bo'sun on 10/12/2021 14:46:08:
While vaguely relating to this thread, has anyone come across a "succinct" comparison chart of commonly used steels in model engineering with EN numbers, properties, machinability, etc, and cross reference to current specification numbers. Something like these maybe? ***Link*** (uses old EN numbers, analysis and use) ***Link*** (compares various standards) ***Link*** (machinability)
Thor
Edited By Thor 🇳🇴 on 10/12/2021 16:21:26 |
Bo'sun | 10/12/2021 16:55:49 |
754 forum posts 2 photos | Thank you Thor, That's just the sort of thing I had in mind. Just need to get my head around the "% machinability index".
Vic | 10/12/2021 17:49:13 |
3453 forum posts 23 photos | Is there a machinability index for common stainless steels? Good links by the way Thor. |
Thor 🇳🇴 | 10/12/2021 18:01:49 |
![]() 1766 forum posts 46 photos | Posted by Vic on 10/12/2021 17:49:13:
Is there a machinability index for common stainless steels? Good links by the way Thor. A few links, I have only tried the austenitic stainless steels and 303 is easier to machine than 316: Thor |
