Here is a list of all the postings Thomas Gregory 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Free Cutting Mild Steel Flat |
10/12/2021 13:36:49 |
Just what I wanted to hear, thanks. |
10/12/2021 12:37:03 |
I need some 2"1/2 x 1/2 flat mild steel which I need to bore a hole and put a radius on the flat corners (if that makes sense) using the lathe. I see lots of EN3B about but is there anything else that may be suitable? M-Machine sell EN8 and EN32B but searching looks like there's a lot of issues machining these? Edited By Thomas Gregory 1 on 10/12/2021 12:55:47 |
Thread: 80mm ARC Versatile or 73mm Precision 3? |
27/11/2021 22:27:21 |
Thanks all, I do think making an endless vice to fit the Tslots would be a good project. Here's a pic of two vices a chap with the same mill (on the mig forums) made for his, I'm sure he won't mind me posting the photos.
27/11/2021 14:09:28 |
Thanks all, I think I may go for the MSC 2" jobbie for now whilst I'm just playing as I imagine having a smaller vice may have it's uses in the future. I'll decide about a bigger vice once I have a bit more of an idea, the 80mm versatile seems to be a good big vice but I think as John said above alternative clamping arrangements may be an option to look at, especially bigger stuff.
Can someone summarise the pro's and cons to a layman on the clamping types between the precision 2 and 3, rack/hex key vs screw and handle? |
26/11/2021 22:46:13 |
Links to said items 73mm Precision 3 https://www.arceurotrade.co.uk/Catalogue/Workholding/Machine-Vices/Precision-Tool-Vices-Type-3 80mm Versatile https://www.arceurotrade.co.uk/Catalogue/Workholding/Machine-Vices/ARC-Versatile-Milling-Vices-with-swivel-base From what I gather you remove the swivel base and stick it on the shelf.
26/11/2021 22:28:44 |
I post a bit on yacht forums and I fear this might be an equivalent to a "what anchor thread" but I'm new to this and have quickly realised you can't just buy a lathe, you need the rest of the stuff as well. So along with my little Hobbymat MD65 I've bought a BFE to go with it but as a newbie I don't want to make mistakes and forums are a great place to her opinions. Now it seems like I need a vice to go with this little milling machine.... the versatile is a popular vice but I've noticed the Precision 3 on ARCs website which looks a neat unit. 100mm seems a popular choice but I fear it would be little oversized for the machine so 80mm may a bit more sensible, the 73mm precision even more "compact". The versatile may be a good shout with the alternative jaw options, I can't imagine the BFE doing much more than "light work" so for the odd job may be the better option? Thoughts, opinions? I'm all ears. Edited By Thomas Gregory 1 on 26/11/2021 22:30:28 |
Thread: Righthand Tool known as a Left? |
17/11/2021 15:04:41 |
Buying some preground tool was a way to remove a variable from my lurning curve as mentioned by others. I do intend to buy some blanks to have a play with but I thought having a preground set (well a RH one first, then a set) would be easiest for a newbie. |
17/11/2021 12:22:15 |
This was the Soba picture I found. |
17/11/2021 11:48:36 |
I bought a R/H HSS tool from Chronos for my new to me Hobbymat just to get me started, or at least I thought I bought a R/H tool. |
Thread: Best place to find a Hobbymat MD65? |
06/11/2021 20:23:32 |
Thanks both, I've flicked through the manual (printed it off yesterday) but not sat down and had a proper read yet. I don't need to buy the gib, I just saw the knurled screw in the advert and recognised it as something I have in the spares box and wondered what it was for. Can I ask what size tools people normally use, 8mm or 10mm? Edit to say I've sussed what the knurled screw is for. The belt cover retaining screw, through the small hole above the spindle hole in the cover. Edited By Thomas Gregory 1 on 06/11/2021 21:15:25 |
06/11/2021 15:27:44 |
Posted by Bazyle on 05/11/2021 23:41:09:
Screw - do you mean the one above the motor? It is for the perspex chuck guard. The backplate is indeed a backplate. It needs the register to fit on the front flange of the spindle, You need 3 studs to go in the backplate (permanently) that then go through 3 plain holes in the flange and you have to develop the skill of getting a washer and nut on them in the confined gap. Small fingers rule. Sorry the screw in the picture of the ebay advert I've linked to. |
05/11/2021 21:04:22 |
Thanks for the replies. As mentioned, change gears, drill chuck, milling plate, there's the hobbymat vice and dust cover as well. No centres but they're cheap enough to buy, no faceplate or outside jaws for the Bison chuck which is a bit of a pain but I've found some from Gloster Tooling. Can anyone shed any light on the screw in the middle of this photo is for? I've got on in the "box of bits). The advert says gib strip etc but I can't see in the advert what the etc is or where it goes or what its for on my lathe. https://www.ebay.co.uk/itm/Hobbbymat-MD65-cross-slide-gib-strip-etc-/234250063701?mkcid=16&mkevt=1&_trksid=p2349624.m2548.l6249&mkrid=710-127635-2958-0 Also I have this backplate, although the register is internal which makes me think it's not a backplate, maybe an adapter for a front mount 4 jaw chuck (without the holes and register machined on the face yet)? Many Thanks
Tom Edited By Thomas Gregory 1 on 05/11/2021 21:05:03 |
05/11/2021 10:04:31 |
Well I've just picked up a 1985 MD65 from a lovely house with double garage workshop in the Cotswolds. The seller who's clearing his late fathers tools said his father had lots of plans to built things but never actually did much. I think he liked buying tools more than using them!?! Anyhow, he had a new Warco 1022 that had never been upwrapped and a Myford along with other "bits".
Edited By Thomas Gregory 1 on 05/11/2021 10:05:43 |
29/10/2021 10:06:07 |
I had seen the one on H&W advertised on ebay, all be it for £170 more than the website price. Even at the lower price it's still a little more money than I have at the moment (but the slow speed mod is a nice addition to make it worth the extra). It's also a good drive to get there as well. |
28/10/2021 16:15:55 |
HI all, I'm looking for my first lathe/milling machines. I've not got a huge budget so I've been looking at secondhand and I think a Hobbymat may suit my needs. |
