Andrew Tinsley | 09/12/2021 14:31:19 |
1817 forum posts 2 photos | I am looking for a graduating tool. Hemingway do two kits. One is the Radford design and the other is the Fallows's design at half the price. They both seem to have more or less the same specifications as regards graduating.. Can anyone comment as to why I should pay twice as much for the Radford design? I shall be using such a tool on a fairly infrequent basis, so maybe the beefier engineering of the Radford tool will be overkill? Come to that, is there any other design that is available? I have not got the energy to design one myself! Regards, Andrew.
Dave Halford | 09/12/2021 15:04:10 |
2536 forum posts 24 photos | It's only the price of castings against bar stock. |
Baz | 09/12/2021 15:06:58 |
1033 forum posts 2 photos | I made the Hemmingway Fallows design quite a few years ago and although it has only been used half a dozen times it does all that is needed. I don’t know of any other designs available. |
Andrew Tinsley | 09/12/2021 15:39:29 |
1817 forum posts 2 photos | Thanks gentlemen. I suspected that there was little difference between the two designs in terms of performance. Andrew. |
Dave Morgan 1 | 09/12/2021 16:31:22 |
11 forum posts 7 photos | Hi Andrew, Harold Hall has a design in his Workshop Practice book on Dividing No 37, ISBN 1- http://homews.co.uk/page315.html Dave |
derek hall 1 | 09/12/2021 16:55:38 |
322 forum posts | Hi made the cheaper one, the Fallows design, and for the amount of graduating it does it's fine. Regards Derek |
ega | 09/12/2021 17:33:42 |
2805 forum posts 219 photos | Whichever design you go for, it is vital that the stroke be free of side play. |
Nick Wheeler | 09/12/2021 17:38:23 |
1227 forum posts 101 photos | For the amount it would get used, I would put the time and work into a 4 position carriage stop and mark the lines with a scriber in the tool post. |
Chris Crew | 09/12/2021 21:14:46 |
![]() 418 forum posts 15 photos | I made the Radford graduating tool and the Radford head-stock dividing attachment (later revised by GHT) to go with it. It is very effective and a good exercise in rack and pinion cutting and ball turning. BTW, if you decide to make the head-stock attachment use the GHT calculations for the worm as there is a small error in Radford's specifications. No castings are required for either device. |
Andrew Tinsley | 09/12/2021 21:55:52 |
1817 forum posts 2 photos | Thanks everyone, Looks as if I shall go for the Fallow's design, Andrew. Edited By Andrew Tinsley on 09/12/2021 21:56:47 |
