John Purdy | 25/11/2021 19:58:35 |
![]() 431 forum posts 252 photos | A question for anyone who has built the Stuart beam engine. I've started to work again on the one I acquired part built many years ago. I have just finished the links for the parallel motion and have stated to layout the holes in the 1/2" x 5/8" bar for the con rod. At first glance it appears that the 3/8" wide slot in the top of the rod as drawn is not deep enough to clear the beam when at the top of the stroke. The drawing shows the bottom of the slot as 19/32" below the centre of the 3/16" pivot pin hole, which means that the parallel portion of the slot only extends 13/32" below the pin centre (the bottom of the beam is 3/8" wide ) and looking at the beam when at the top of the stroke the bottom looks to be considerably more than that. So I made up a dummy con rod to check the clearance and the angled piece on the dummy rod just clears the beam at this distance, perhaps slightly less. It looks like the 19/32" dimension should be to the centre of the radius of the semi circle at the bottom of the slot, not the bottom. I have searched the site for any mention of this but found nothing. Am I missing something? |
JasonB | 25/11/2021 20:13:52 |
![]() 25215 forum posts 3105 photos 1 articles | A quick measure of mine put sit somewhere between 5/8" and 21/32" to the bottom of the slot which still comes quite close so I would say 11/16" would be a safe minimum. |
John Purdy | 27/11/2021 01:01:33 |
![]() 431 forum posts 252 photos | Jason |
JasonB | 27/11/2021 07:23:15 |
![]() 25215 forum posts 3105 photos 1 articles | It's too long ago to remember why mine is bigger or whether I had to make another? I did look at the couple of versions of the Victoria drawings that I have and the dimension is different between the two and one is to the bottom of the U the other to ctr line., I now only have the book for the beam drawing which is as you detail but wonder if there are any differences on the actual drawing(s) |
Mick B1 | 27/11/2021 10:34:21 |
2444 forum posts 139 photos | Long time ago for me too, but mine measures about 13/16" to the bottom of the radius. Maybe I was just leaving myself a load of room, and it looks as if I made the fork as a separate component - but I can't see that it has any negative effect. |
John Purdy | 27/11/2021 18:34:41 |
![]() 431 forum posts 252 photos | The parts list I have is dated 1972 so I would think the plans, although not dated, are of the same vintage. The plans show the dimension to the bottom of the slot as 19/32", the same as in Andrew Smith's book (1987 edition ). This is definitely too short and would foul the beam before it reached the top of the stroke. If the 19/32" was to the centre of the U it would probably just clear the beam. I would be curious to know what the current issue of the plans show for this dimension? John |
