Scribe block repair
Dalboy04/11/2021 16:35:28
1009 forum posts
305 photos
First small simple project to practice on with my new machines. It may not be worth it for the price of the item as it is a second scribe block that I have it came to me with surface rust on it.
It is a Moore & Wright scribe block adjusting arm that fits into the block. I still need to drill and tap a hole for the adjustment screw and also make the screw as well as can be seen in this photo.
As can be seen the original looks in a poor state and the thread for the adjustment screw has stripped
mechman4804/11/2021 17:38:16
2947 forum posts
468 photos
Got to start somewhere; why not with a simple repair job, the first of many no doubt, looks a good finish.
George.
Jeff Dayman04/11/2021 18:05:41
2356 forum posts
47 photos
Nicely done Derek! look good. Ready for the next hundred years of service!
Nigel Graham 204/11/2021 19:24:06
3293 forum posts
112 photos
Yes - I think that would pass M&W's QA department.
Howard Lewis04/11/2021 21:16:13
7227 forum posts
21 photos
Model Engineers don't throw things away!
They repair them, sometimes to better than new!
SillyOldDuffer05/11/2021 14:55:39
10668 forum posts
2415 photos
Derek's version looks better than the original. Is it me, or is the worn out item an alloy casting?
Dalboy05/11/2021 17:02:15
1009 forum posts
305 photos
Posted by SillyOldDuffer on 05/11/2021 14:55:39:
Whatever it is it is light like Ali but easily damaged the rough area on the side I thought was raised but it is not.
I tried to get it finished and assembled today but what with shopping having a new carpet played and a new bed base installed workshop time has been limited. I did try to identify the thread on the thumb screw but could not so I will just make it with the taps and dies that I have a 5/32nd UNF is close as well as a 2BA but neither are the same so a new thumb screw will also need making and a threaded hole in this piece need doing after I have ordered a drill bit for the new thread why can't these things be simple
Tony Pratt 105/11/2021 17:47:04
2319 forum posts
13 photos
Can hardly believe someone made a scribing block arm out of Aluminium let alone M & W as a softish metal is totally unsuitable for this purpose,but there it is. I'm thinking someone has made a replacement in the past?
Tony
Edited By Tony Pratt 1 on 05/11/2021 17:50:31
Journeyman05/11/2021 18:07:42
1257 forum posts
264 photos
Bed and carpet in the workshop, sounds very cosylaugh
Howard Lewis05/11/2021 20:29:22
7227 forum posts
21 photos
If the tread is not BA might it be something like 3/16 BSF?
Would not expect M & W to use something odd like 3 BA or ANF (Unified )thread.
But if you have to make an adjusting screw as well, you ncan use whatever seems most suitable, based on the equipment available.
Dalboy05/11/2021 22:50:49
1009 forum posts
305 photos
Posted by Howard Lewis on 05/11/2021 20:29:22:
Tomorrow I will have a good look with a thread gauge to see what that says. I have UNF and Ba dies to check against but not BSF so I will be making new using the UNF threads.
Dalboy05/11/2021 22:53:34
1009 forum posts
305 photos
Posted by Journeyman on 05/11/2021 18:07:42:
After having a new workshop and a lathe and milling machine I thought it a good swap to have the bed and carpet along with double glazing fitted to keep the wife happy, which also means I can have more workshop timewink
Howard Lewis06/11/2021 15:25:13
7227 forum posts
21 photos
Ooh! A double glazed workshop with carpet and a bed!
Journeyman06/11/2021 18:20:18
1257 forum posts
264 photos
Appeasing the 'Domestic Authorities' is always a sound workshop techniquewink
