Shielded or sealed?
Grindstone Cowboy | 30/10/2021 18:57:31 |
1160 forum posts 73 photos | Was recently given a double ended bench grinder which needs new bearings. The existing ones (pretty sure they're original) are metal shielded both sides. Just wondering if there would be any advantage in getting rubber sealed ones instead - the cost difference is neglible. It's an Ajax unit, 750 watt, looks to be from the 60s or 70s. There may also be an issue with the capacitor, but one step at a time... Thanks, Rob |
not done it yet | 30/10/2021 19:37:15 |
7517 forum posts 20 photos | Can’t ell how much work it might have done since new, but how long are you expecting it to last? I would not be surprised if the lube has simply dried out a bit over that period. Go with the bearing supplier’s recommendation - bearing quality is likely a better metric. Running out of balance could be another reason for the bearings to wear. Edited By not done it yet on 30/10/2021 19:38:51 |
AJAX | 30/10/2021 19:54:51 |
433 forum posts 42 photos | I'd like an Ajax unit -- it would go with my forum nickname. Capacitors are easy enough to replace, and if it still has the original one then it's probably about time. |
Howard Lewis | 30/10/2021 21:20:45 |
7227 forum posts 21 photos | Since grinding dust will be flying about, 2RSS would be my choice. More friction, but I'd live with that. Probably bearings worn because they are shielded rather than sealed Howard |
David George 1 | 31/10/2021 07:23:17 |
![]() 2110 forum posts 565 photos | Hi I replaced shielded bearings with rubber shielded bearings on a grinder and the bearings heated up the housing quite a lot. Slight friction of rubber shielding at that speed caused heat. Check with a proper bearing supplier as to correct bearing. Right bearing right place. With metal shielded bearing it is still sound ten plus years later. David |
martin haysom | 31/10/2021 09:29:22 |
![]() 165 forum posts | if the originals lasted 50/60 years i would stick with the same type |
Grindstone Cowboy | 31/10/2021 09:59:13 |
1160 forum posts 73 photos | Thanks everyone for your advice. Good points from David and Martin, you've convinced me to stick with shielded. If they wear out again before I do, I can always replace them again Rob |
