advise please Warco WM 250 gear Bush
warco wm 250v
Daniel White29/10/2021 14:03:54
3 forum posts
Hi, unfortunately I've broken my lathe, nothing serious just broken one of the key sleves on the gears. I've spoken to warco and they are not getting any for at least 10 weeks. Anyone know anywhere else that might have some, or someone got a load of spares that might like to sell one. Many thanks for your help
Dan
JohnF29/10/2021 14:25:32
1243 forum posts
202 photos
Hi I’m not familiar with those machines but I presume you mean the keyed bush used on change wheel gears ? If so it’s quit possible that other suppliers of similar machines may have the same part? Chester, Engineers Toolroom, Amadeal etc
Or just make one !
Edited By JohnF on 29/10/2021 14:26:08
Jimmeh29/10/2021 14:53:56
27 forum posts
12 photos
Afternoon Dan. Are you able to post a picture of the component in question? I've converted my 250vf to have an electronic leadscrew so I no longer need the change wheels and spacers.
Edited By JasonB on 29/10/2021 16:54:19
JasonB29/10/2021 15:19:42
Dan, I can't speak for the 250 as I have a 280 but have you looked in the toolbox as mine had a spare in there plus an extra spacer.
If you don't have a spare then you could turn up a round sleeve and just drill through the pair of gears for a pin rather than trying to form the integral key., it would do as a stop gap to give you feeds unless you are intending to do a lot of screw cutting of various pitches until the new one arrives.
I assume its the sintered one on the right
John Haine29/10/2021 15:39:09
5563 forum posts
322 photos
Or possibly file a keyway and have a separate key?
Howard Lewis29/10/2021 15:55:10
7227 forum posts
21 photos
Hugh at AMADEAL has responded to your other post on this subject, saying that he has them in stock!
So contact him.
Might be worth laying a spare or two while you are about it.
Since they are a stock item, you are not alone in your troubles.
Dalboy29/10/2021 16:33:05
1009 forum posts
305 photos
They also come with the 250v as I found them in the tool box that came with mine
Posted by JasonB on 29/10/2021 15:19:42:
Edited By Derek Lane on 29/10/2021 16:34:07
bernard towers29/10/2021 21:19:35
1221 forum posts
161 photos
You really ought to be able to make one in the time it-takes to fire up the pc. Turn the tube ,slot it ,silversolder key in fit it and carry on playing
Nick Wheeler29/10/2021 22:02:39
1227 forum posts
101 photos
Posted by bernard towers on 29/10/2021 21:19:35:
That's my plan for the slightly butchered ones on my lathe. Although I'll only solder the keys if Loctite doesn't work.
I've already made new studs out of an old aircraft bolt that are a much better fit.
