Michael Callaghan | 25/10/2021 18:40:45 |
173 forum posts 7 photos | Hi, I have an old warco milling machine with the belt drive. Can anyone please give me the speeds of the mill in each belt position. Thanks |
DiogenesII | 25/10/2021 18:56:29 |
859 forum posts 268 photos | The big one, with 12 speeds on three pulleys? ..the Major gives:
Dave Halford | 25/10/2021 19:01:16 |
2536 forum posts 24 photos | Then there's the Minor and the Economy and didn't they do one or two with only two pullies. My crystal balls batteries have gone flat. |
DiogenesII | 25/10/2021 19:31:27 |
859 forum posts 268 photos | ..innit.. TBH, you'd be better to get a cheapy chinese tachometer of the internet and do a quick rating in any case, I doubt the spec's have remained static over time, and as Dave points out, it might be one of several different models. |
Russell Eberhardt | 25/10/2021 19:36:54 |
![]() 2785 forum posts 87 photos | Posted by Dave Halford on 25/10/2021 19:01:16:
Then there's the Minor and the Economy and didn't they do one or two with only two pullies. Yes, my ZX-15 has two four step pulleys. Now much better with inverter drive. Russell Edited By Russell Eberhardt on 25/10/2021 19:38:36 |
Glyn Davies | 25/10/2021 20:51:08 |
146 forum posts 56 photos | On my 2017 VMC, this is the speed sticker on the belt guard: This is the pulley arrangement: This is the speed table I constructed having measured each speed with a tacho: |
Howard Lewis | 26/10/2021 22:02:40 |
7227 forum posts 21 photos | The Warco Economy has four sheaves on motor, Intermediate and Quill pulleys These are supposed to give speeds, on 50Hz Single Phase mains of: 90,170, 200, 250, 280, 360, 600,700, 950, 1290, 1590, 2150 rpm Howard |
David Caunt | 27/10/2021 00:04:00 |
![]() 110 forum posts 40 photos | Posted by Glyn Davies on 25/10/2021 20:51:08:
On my 2017 VMC, this is the speed sticker on the belt guard: This is the pulley arrangement: This is the speed table I constructed having measured each speed with a tacho: As the highest speed is correct it might be you are suffering from belt slip at the other combinations. |
Michael Callaghan | 27/10/2021 09:34:39 |
173 forum posts 7 photos | Thanks to you all. |
Howard Lewis | 27/10/2021 11:53:38 |
7227 forum posts 21 photos | My Economy shredded the primary belt within 6 months of occasional use. Realigning the motor with the intermediate pulley (Straight edge over the two pulleys ) has meant that the new A30 belt, like the original,secondary, has survived over 20 years of use. Howard |
