William Harvey 1 | 23/10/2021 20:31:55 |
176 forum posts | Hi, I need to make a plate to hold a cylinder head on my lathe. The head will be held on using cylinder head studs. The thread on the end of the stud is 3/8 UNC. I think I have a 3/8 UNC tap but what drill bit should I use? |
Bill Phinn | 23/10/2021 20:44:53 |
1076 forum posts 129 photos | The standard tap drill for 3/8 UNC is 8mm or 5/16. |
david sanderson 3 | 23/10/2021 20:46:13 |
17 forum posts 2 photos | 3/8 19 tpi is pipe thread 3/8 unc is 16 tpi and drill 8.25mm |
SillyOldDuffer | 23/10/2021 20:53:47 |
10668 forum posts 2415 photos | 14.75 doesn't sound right. This tap chart suggests 5/16" which is 7.94mm. I'd round that up to 8mm, or even a bit bigger. (Tap drill sizes given in tables are for a tight fit, which puts a lot of strain on the tap. In home workshops it's common to drill a little bigger than recommended because it makes life easy for the tap in exchange for a moderate reduction in strength. Don't do it if the fastening has to be full-strength.) Dave |
Alain Foote | 23/10/2021 21:53:30 |
69 forum posts 10 photos | 14.75 mm is the tapping size for 3/8” British Standard Pipe Thread which is 19 tpi. As previously mentioned the tapping drill for 3/8” UNC is much smaller at around 5/16”. |
SillyOldDuffer | 24/10/2021 11:08:51 |
10668 forum posts 2415 photos | Posted by Alain Foote on 23/10/2021 21:53:30:
14.75 mm is the tapping size for 3/8” British Standard Pipe Thread which is 19 tpi. As previously mentioned the tapping drill for 3/8” UNC is much smaller at around 5/16”. Ah yes! Watch out for pipe. BSP is weird because 3/8" refers to the inside diameter of the pipe, not the outside diameter. In contrast, fasteners always refer to the outside diameter as in 3/8" UNC, Whitworth, BSF etc, but note that the exact tapping drill size depends on the thread form and pitch too. Although there are formula, the easiest way to find tap drill diameters is to look them up in a table. I recommend buying a copy of Tubal Cain's Model Engineer's Handbook. In addition to the usual tables, the discussion section on %thread engagement is well worth reading. Although I also have heavy references like Machinery's, I usually start with Tubal Cain because he targets small workshop needs so well, often with pertinent advice. Dave
Vic | 24/10/2021 11:21:04 |
3453 forum posts 23 photos | The Workshop Practice book says 8.3 to 8.5 depending on the engagement - 73% to 60%. |
Howard Lewis | 24/10/2021 11:46:53 |
7227 forum posts 21 photos | Zeus Charts give the tapping drill for 3/8 x 16 UNC as:8 mm (BSI Recommended ) or 5/16 as an alternative. If you have not got a set; well worth investing in. Still using mine bought in 1958! . Always a source of reference for threads and many other things, (BA, BSW, BSF, BSP, ANC, ANF, UNF, UNC, Metric Coarse, Metric Fine, Fits, Metal Bending Allowances, Hardness Comparisons, Co ordinates for equally spaced holes, Morse taper dimensions, Mathematical tables. ) Howard |
Tim Stevens | 24/10/2021 11:50:31 |
![]() 1779 forum posts 1 photos | from the Machinery's Screw Thread Book: 3/8 UNC - 99% = 7.6mm, 94% = 7.7mm, 89% = 7.8%, 5/16" = 82%, 8mm = 78%, 8.1mm = 73%, 8.2mm = 68%, 8.3mm = 63%, 21/64" = 61% Cheers, Tim |
William Harvey 1 | 24/10/2021 19:07:05 |
176 forum posts | Thanks everyone for your help. |
William Harvey 1 | 11/12/2021 13:39:07 |
176 forum posts | So i drilled an 8mm hole and this 3/8" Tap just seems way too big??? It's labelled STI3/8 - 16 HSS
Edited By William Harvey 1 on 11/12/2021 13:45:29 |
William Harvey 1 | 11/12/2021 13:44:50 |
176 forum posts | Ah just sussed it, I looked in my small box of taps and found another 3/8 NC 16 tap (left in the pic). This one is much smaller, the other one that starts STI Helicoil Set? |
JasonB | 11/12/2021 13:47:52 |
![]() 25215 forum posts 3105 photos 1 articles | What type of tap is it? taper, second, plug, bottoming, spiral point, spiral flute, form tap |
JasonB | 11/12/2021 13:53:21 |
![]() 25215 forum posts 3105 photos 1 articles | Someone on another forum with the same problem and it looks like he has a helicoil tap, that would need a 9.9mm drill. Can you post a link to the exact tap and a photo in case they are using a generic picture |
SillyOldDuffer | 11/12/2021 15:18:01 |
10668 forum posts 2415 photos | Posted by William Harvey 1 on 11/12/2021 13:44:50:
Ah just sussed it, I looked in my small box of taps and found another 3/8 NC 16 tap (left in the pic). This one is much smaller, the other one that starts STI Helicoil Set? ... You're right - the larger tap cuts a thread to take a wire insert core, and the insert takes a 3/8"-16 screw. STI = Screw Thread Insert. It's "special". Unless you're in North America best not to get entangled with US threads unless you have to, especially inserts. The mixture of Imperial and Metric Threads available in the UK is quite confusing enough. Have you picked up a bargain box of unknown tools? They often contain surprises - stuff bought to do special repairs etc. They may not match your needs, for example I associate inserts with repair work rather than Model Engineering. To keep my non-modelling experimental workshop simple, I majored on metric threads and only buy in BA, Whitworth and UN as required - not often! A modeller might tool up with BA, BS and ME threads for the same reason, and only use metric on special occasions. Do you have a particular hobby direction in mind? (I didn't at first.) If so, might be better build something to a local plan, and buy whatever is needed to do it. Dave
Edited By SillyOldDuffer on 11/12/2021 15:18:20 |
JasonB | 11/12/2021 15:21:26 |
![]() 25215 forum posts 3105 photos 1 articles | Dave he has got a classic Mini and they use UNC threads in the A series engine |
