Governor drive belt
Garry Coles03/09/2021 11:09:41
121 forum posts
100 photos
Hi, Has anybody got some ideas on how to join a governor drive belt. Mine is made of leather and is only 6 mm wide. I will have to join mine in place as it goes around the crankshaft as normal. I have tried to stitch mine but that is very tricky and not very good.
Garry
mark costello 103/09/2021 20:51:05
800 forum posts
16 photos
Skived and endless would work.
Skiving a Bando type belt would work also.
Dave Halford04/09/2021 10:02:38
2536 forum posts
24 photos
here maybe
Jasons link to LSM lists a 1/2" belt, the joiner might work. Might be worth a call at least.
Roderick Jenkins04/09/2021 14:21:06
2376 forum posts
800 photos
The drive belt for the fan on my Farm Boy is made from 1.8 mm O ring material joined with a simple butt join glued with a generic cyanoacrelate (super glue). I've been very pleasantly surprised how robust the belt is, so a simple glued butt join may well be worth a try.
HTH,
Rod
steamdave04/09/2021 16:16:49
526 forum posts
45 photos
Posted by Roderick Jenkins on 04/09/2021 14:21:06:
HTH,
Rod
It is interesting to learn that 'super glue' is flexible and lasting enough for a drive belt. If asked, I would have thought that Evostik type glue would have been the choice for this type of job.
The Emerald Isle
JasonB04/09/2021 16:27:43
You can also get flexible "superglues" such as Loctite's "black max" that has some rubber in it and may be better for a scarf type joint in the flat belt
Garry Coles04/09/2021 17:24:18
121 forum posts
100 photos
OK, thanks, will try some of the glues mentioned. I was just a bit concerned that the glues would be a bit stiff to go around the governor pulley because it's only 1/2 in diameter.
Garry
Roderick Jenkins04/09/2021 20:57:04
2376 forum posts
800 photos
Posted by Garry Coles on 04/09/2021 17:24:18:
Garry
Which is why I went for the butt join rather than a scarf (as well as being easier cool) though I guess that leather might tend to wick a thin glue which would tend to stiffen up the joint area. A gel type glue might be better.
Rod
roy entwistle05/09/2021 09:37:27
1716 forum posts
Rod It's a leather belt 6mm wide so presumably flat. Difficult to butt join
Roy
