Looking for a compact and safe mains lead connector
Michael Gilligan31/08/2021 14:43:08
23121 forum posts
1360 photos
I have a new mains-powered ‘Studio’ flash head which, rather inconveniently, has a fixed mains lead [2-core U.K.]
I propose to cut it short, and add an in-line connector; so that the long lead can be stored separately.
The obvious question is : What connector would our electrical experts recommend ?
SillyOldDuffer31/08/2021 15:06:18
10668 forum posts
2415 photos
I like the IEC 'Kettle' connectors as used on computers. They normally plug into a bulkhead socket but flying males are easily had, this example is wired up as an adaptor:
I don't care for anything more delicate on 240v mains wiring but could be prejudice!
Andrew Entwistle31/08/2021 15:12:54
120 forum posts
218 photos
Hi Michael, my preference is to use a rewireable IEC C14 plug and C13 socket (possibly moulded-on if a standard 13A plug to C13 socket lead is available). It is a shame that there is no similar connector pair for figure of 8 format (IEC C7/C8) that would be more compact and with just the 2-poles that you need.
Andrew.
Michael Gilligan31/08/2021 15:42:10
23121 forum posts
1360 photos
Thanks to you both … but I was really looking for something more compact
Andrew is thinking along the right lines, but I have yet to find anything suitable
The head is labelled E14/75W AC220V 50Hz, and the mains plug has a 5A fuse
… a ‘kettle connector’ would surely be overkill
Frances IoM31/08/2021 15:50:30
1395 forum posts
30 photos
the 2-pin connectors may be found in moulded connection - I have several salvaged from old Sky boxes gleaned from my local amenity site. Interestingly they all use a distinctive round format 13amp plug but with a 5amp fuse..
Not sure re bulkhead fittings as most I have were designed for PCB mounting with the PCB also mounting switches etc
Edited By Frances IoM on 31/08/2021 15:52:13
Grindstone Cowboy31/08/2021 16:02:08
1160 forum posts
73 photos
I'd go for something like this - other colours (and suppliers) are available.
Links to https://cpc.farnell.com/pro-elec/0128-bk/connector-rubber-10a-2-pin-black/dp/PL09471?st=plug%20in%20mains%20adapter
Rob
Oh, and hopefully not teaching anyone to suck eggs, but remember to put the socket on the "live" side of the connection.
Edited By Grindstone Cowboy on 31/08/2021 16:03:26
Robert Atkinson 231/08/2021 16:25:44
1891 forum posts
37 photos
There is not much vailable that is smaller than IEC C14/15 and suitable for inline use.The two pin (IEC C4/5) connectors are not made as inline male.
The only common one is the rubber inline 2 pin connector used for garden tools.
https://uk.farnell.com/pro-elec/0128-or/connector-rubber-10a-2-pin-orange/dp/3472736
or black
https://uk.farnell.com/pro-elec/0128-bk/connector-rubber-10a-2-pin-black/dp/3472734
Theleed used to interconnect these lights would do, but are not re-wireable so you would have to modify them flash to attach one.
https://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Lighting_Fluorescent_Index/Linkable_Flourescent_Fitting/index.html
Robert G8RPI
Edit,
Rob types quicker than me!
Edited By Robert Atkinson 2 on 31/08/2021 16:26:34
Clive Foster31/08/2021 16:47:44
3630 forum posts
128 photos
Screwfix supply the Hylec 1 entry micro plug and socket system. Said to be 14 mm diameter and able to accommodate 1.5 sq mm cables but no current rating given. 400 V rated so pretty safe.
Expensive at nearly £15 a pop.
https://www.screwfix.com/p/hylec-1-entry-dp-micro-plug-socket-connector/345gx#product_additional_details_container
Not keen on the rubber garden tool type two pin connectors. All the ones I've encountered have been a right battle to separate.
DC31k31/08/2021 17:29:46
1186 forum posts
11 photos
Please have a look at Neutrik Powercon True 1 Top as it might do what you want.
http://www.neutrik.co.uk/neutrik/products/powercon/powercon-true1-top/powercon-true1-top-cable-connectors
Robert Atkinson 231/08/2021 18:14:30
1891 forum posts
37 photos
The Hylec looks very good. Not seen those before. A bit long though. It's 10A
https://www.hylec-apl.com/Weatherproof-Waterproof-Connectors-Range/Micro-TeePlug-and-Sockets/THB_381_A2B_L.html
Screwfix don't describe it well and it's listed under cable joiners.
The PowerCons are very good but nearly as big as a C14/15 at more cost.
Michael Gilligan31/08/2021 18:35:32
23121 forum posts
1360 photos
Thanks for the further input yes
Just to show the scale of the problem, here’s a quick snapshot of the unit:
It came crammed into a surprisingly small cardboard box … but there’s no way I would want to use that for storage.
What I was hoping to do is snip the lead at about 9” from the Heyco strain relief, and insert a pluggable [and preferably locking] connecter with a much more flexible mains lead. … then I would be able to store the two separately.
P.S. __ Sorry there’s no fill-in flash on that snapshot !
Michael Gilligan31/08/2021 19:27:06
23121 forum posts
1360 photos
This was the most promising candidate that I found:
**LINK** : https://www.farnell.com/datasheets/3165736.pdf
… but I was hoping for something smaller
Robert Atkinson 231/08/2021 20:30:31
1891 forum posts
37 photos
Those pro-elec connectors are copies of the Bulgin Buccaneer range. They are not approved for use as mains power connectors on hand-held items.
Thee is probably room in the flash to fit one of these
https://uk.farnell.com/schurter/6160-0004/inlet-iec-c8-2571-2-5a/dp/2080477
from the outside. You might have to make a shaped packer for it.
They are cheap, approved for the job and work with standard leds so if you forget yours you have a chance of borrowing something.
A locking cnnector may not be the best idea. Better a plug comming out if someone trips on a lead tahn a flash and tripod crashing down.
Robert G8RPI.
Edited By Robert Atkinson 2 on 31/08/2021 20:31:35
Michael Gilligan31/08/2021 21:11:27
23121 forum posts
1360 photos
Thanks, Robert …
I am hoping to avoid opening the unit; but if nothing more suitable appears, I may end up putting one of those in a little box on the shortened lead.
Ref. __ https://www.farnell.com/datasheets/2108396.pdf
P.S. __ The ‘studio’ in question is my table-top light tent.
Edited By Michael Gilligan on 31/08/2021 21:14:44
DMB31/08/2021 21:20:30
1585 forum posts
Why not hunt around for a bigger box? Goods on Amazon (e.g.,)come in various sizes of boxes.
Maurice Taylor31/08/2021 21:23:06
275 forum posts
39 photos
Hi, Why not do it the easy way ,use a 2 pin garden equipment plug and socket cable joiner.
Maurice
Michael Gilligan31/08/2021 21:29:33
23121 forum posts
1360 photos
Posted by Maurice Taylor on 31/08/2021 21:23:06:
Maurice
Because it’s at least ten times the size and weight that I want
… the whole unit only weighs 800g
Michael Gilligan31/08/2021 21:33:28
23121 forum posts
1360 photos
Posted by DMB on 31/08/2021 21:20:30:
Because I want to store it in a padded bag, with the mains lead and its plug in another.
Michael Gilligan31/08/2021 22:49:32
23121 forum posts
1360 photos
A question for Robert:
If I go the C8 route … Would this 4metre C7 lead be acceptable, with the substitution of a U.K. mains plug ?
**LINK** : https://www.farnell.com/datasheets/2705354.pdf
It’s specified 125V, 7A … They don’t appear to list a 250V, 2.5A version
I would expect the C7 plug should be dual rated, but is the cable ?
Andrew Entwistle01/09/2021 09:12:28
120 forum posts
218 photos
The dielectric strength between the cores at >2kV L-N suggests there is no problem isolating 230V, especially with the additional insulation of the outside sheath. Durability needs to be the same whether 110 or 230. I would have no qualms about using this cable at 230V for a home project, but for a more official application the correct rating would be required - even though I suspect it is just testing and screen printing that makes the difference.
