universal pillar tool long arm castings
YouraT14/08/2021 17:14:45
83 forum posts
22 photos
Hi.
Does anyone know of a source for, or perhaps have a spare set of, the castings for the longer arm version of the UPT?
Hemingway don't do them, and buying them from Martin Model in the US results in some eye watering costs, mainly due to postage charges.
I've seen a build somewhere which fabricated some using cast pipe fittings, but I thought maybe finding a more local source of the castings might be an easier route....
Thanks,
Youra.
DiogenesII14/08/2021 17:38:18
859 forum posts
268 photos
Reeves?
YouraT14/08/2021 19:05:08
83 forum posts
22 photos
Posted by DiogenesII on 14/08/2021 17:38:18:
Reeves?
Sadly not....
Michael Gilligan14/08/2021 19:12:05
23121 forum posts
1360 photos
If you are thinking of building a 6” throat version …
Why not adapt a bench-top pillar drill ?
It could be much cheaper, and significantly stiffer.
Edited By Michael Gilligan on 14/08/2021 19:38:28
Robert Butler14/08/2021 19:14:34
511 forum posts
6 photos
This article appeared in MEW, don't know where, don't no when but it did.
Robert Butler
Mike Poole14/08/2021 19:33:28
3676 forum posts
82 photos
Cast iron square bar could be a substitute, depending on how much trouble you want to go to is could pass for a casting after much work
YouraT14/08/2021 23:07:51
83 forum posts
22 photos
Posted by Michael Gilligan on 14/08/2021 19:12:05:
I've already built and use the standard version, just occasionally need slightly more reach....
YouraT14/08/2021 23:17:59
83 forum posts
22 photos
Posted by Mike Poole on 14/08/2021 19:33:28:
Mike,
That's actually a smashing idea in this situation, don't really need it to pass for a casting, but might turn away some of the excess between the two ends.
Michael Gilligan14/08/2021 23:28:51
23121 forum posts
1360 photos
Posted by YouraT on 14/08/2021 23:07:51:
Aha … I didn’t know that ^^^
Nick Wheeler15/08/2021 09:41:51
1227 forum posts
101 photos
Why would you make a homemade workshop tool look like a casting??
Alan Hopwood15/08/2021 10:29:22
42 forum posts
When I've made a slightly larger version at work, I've made the column from 30mm en8 and the arms from 1&1/2 X 2 inch steel bar. Mind you, I work in agriculture and the old saying is "near enough for farm work".
bernard towers15/08/2021 20:58:18
1221 forum posts
161 photos
Sorry but I thought that the idea behind GHTs Upt was the fact that it was for model makers. If you want bigger use a run of the mill drilling machine, it will also have a decent size column.
Roger Best15/08/2021 21:11:11
406 forum posts
56 photos
Posted by Nicholas Wheeler 1 on 15/08/2021 09:41:51:
Easy answer - to make it look prettier.
Before you choke please remember that beauty is in the eye of the beholder. laugh
YouraT16/08/2021 13:47:04
83 forum posts
22 photos
Posted by bernard towers on 15/08/2021 20:58:18:
Well, I don't need enormous rigidity - I'm a clockmaker and use mine for bushing and staking purposes, so little in any side forces during use.
Making the arms pretty is a secondary concern, although them not being actively painful to look at is of course a plus
Using a nicely made and finished tool is always more of a pleasure than using a poorly finished one...
Y.
Martin Kyte16/08/2021 14:49:51
3445 forum posts
62 photos
You could always make a cranked column. Couple of bits of PGMS and some 1 1/4 by 3/4" bar. Bore holes to suit the column, Loctite the whole to together and saw away the waste. Bit like a gap bed lathe. You only need to accomodate clockplates as you say and that way you can use all the fittings from your existing pillar tool.
How about that for thinking outside the box.
regards Martin
YouraT16/08/2021 15:56:28
83 forum posts
22 photos
Posted by Martin Kyte on 16/08/2021 14:49:51:
regards Martin
Martin
Genius idea!
I even have a bed like that for my little 8mm Boley watchmaker's lathe - maintaining of alignment is effectively built in, and it avoids having to make any more of those fiddly little clamping handles!
Youra.
