Belt lacing clips
Paul Lousick13/08/2021 08:49:59
2276 forum posts
801 photos
I am making a governor for my traction engine which uses a 20mm [or 3/4"]  wide x 2mm thick flat belt from a pulley on the crankshaft.
I need to find a supplier of small quantities of belt lacing clips to join the ends of the belt. Cannot use a continuous belt as it has to be removable.
Lots for sale on ebay for larger sizes and in USA but in large quantities and exorbitant postage.
Anyone recommend a supplier ?
Paul
Edited By Paul Lousick on 13/08/2021 08:53:13
roy entwistle13/08/2021 08:52:23
1716 forum posts
Would heavy duty staples do ?
Roy
Paul Lousick13/08/2021 09:02:37
2276 forum posts
801 photos
Similar to staples but it is a power transmission belt and is stronger and joined together
JasonB13/08/2021 09:10:44
LSM the model traction engine people do it by the 50mm length along with governor and flywheel belting. Page 44 of cat
Paul Lousick13/08/2021 09:54:33
2276 forum posts
801 photos
Thanks Jason,
My engine drawings, castings, etc. are from LSM.
Paul
old mart13/08/2021 15:06:23
4655 forum posts
304 photos
The Smart & Brown model A uses a 25mm x 3mm thick belt with a join in it sucessfully, I believe the belt and joining parts came from Lathes UK. I'm not sure if a 2mm thick belt can be joined mechanically, though.
Martin Connelly13/08/2021 16:15:40
2549 forum posts
235 photos
It is usually called alligator fastener or alligator lacing if you want to search for it. I think the manufacturer is Balata or that may be a trade name.
Martin C
Pete Rimmer14/08/2021 18:06:54
1486 forum posts
105 photos
Clipper lacing is another. I have a Clipper lacer which is intended for use in vice jaws. Don't have any clips though.
bernard towers14/08/2021 21:38:10
1221 forum posts
161 photos
Lathes .co .uk have a belt supplier.
John Reese16/08/2021 20:59:27
1071 forum posts
+1 on clipper lacing. It is probably the most compact of all the metallic lacing products. It does require a tool for installation The simplest tool is used with a bench vise.
