6 inch bench grinder
Ian Skeldon 217/07/2021 20:04:28
543 forum posts
54 photos
Hi,
I seek your advice please. I own a reasonable 6 inch bench grinder, I now want to grind/profile some tungsten tools and I know that the standard aluminium oxide wheel wont work. I think I read somewhere that I need a green wheel?
Thank you,
Ian
Michael Gilligan17/07/2021 20:31:49
23121 forum posts
1360 photos
Green Grit wheels are Silicon Carbide … a hard abrasive with sharp corners
See Wikipedia: **LINK**
https://en.wikipedia.org/wiki/Silicon_carbide#Abrasive_and_cutting_tools
But I’m not entirely convinced that Silicon Carbide itself [although often green-ish] is itself as green as some of the wheels.
dont know
Bill Davies 217/07/2021 20:55:45
357 forum posts
13 photos
It seems that it comes in two colours:
Black and green silicon carbide
The Wikipedia article mentions multiple colours, sometimes due to impurities. My recollection from long ago was that the wheels I used in industry were always green. This was for brazed carbide cutting tools, before inserts were common or perhaps available.
Bill
not done it yet17/07/2021 21:13:00
7517 forum posts
20 photos
I have two large(ish) ‘green grit’ wheels. One, purchased at HIS in Inverness, is very green in colour, while the other (more recently) from ArcEuroTrade is definitely much darker in colour - certainly not green, as I see it.
The first was bought for a bench grinder (20mm bore) and the second for my surface grinder (any standard size to 1 1/4&rdquo.
David George 118/07/2021 16:13:35
2110 forum posts
565 photos
Hi Ian what shape are you grinding as green grit wheels are fairly soft to keep the wheel cutting. I rough out with a green grit 150 grit wheel and finnish with a diamond wheel. Are they turning tools or milling cutters with a form on. When grinding the rough form I may have to re-dress the wheel a few times if I am making a for instance a radius tool and it is a bit dusty.
David
Ian Skeldon 218/07/2021 20:56:21
543 forum posts
54 photos
Hi,
Thanks for the help so far.
DG1, My intention is to grind a relief angle on the cutting edge of a large carbide insert, for some reason it comes without any clearance angle? This may work well in a large industrial lathe but not so well in my lathe hence the desire to alter it slightly.
I was thinking that maybe a diamond wheel would be the best route but wanted to see what the general opinion was first as they tend to be pretty expensive.
Thanks to all for suggestions,
Ian
David George 118/07/2021 23:00:28
2110 forum posts
565 photos
This is my diamond wheel grinder with adjustable table to angle diferent cutters.
David
Ian Skeldon 219/07/2021 09:28:34
543 forum posts
54 photos
Hi David,
Is that a specific grinding machine with the diamond wheel intended to be fitted? I am not sure that a similar wheel would fit onto my simple bench grinder but I will check out the dimensions, many thanks for your help.
Ian
