Brian H | 30/06/2021 14:24:21 |
2312 forum posts 112 photos | I need to make a very small electrical switch; is acrylic (Perspex) suitable for insulation at low voltages i.e. 5v to 9v? Brian |
Michael Gilligan | 30/06/2021 14:33:15 |
23121 forum posts 1360 photos | Very suitable, Brian See list of values, here: **LINK** https://omnexus.specialchem.com/polymer-properties/properties/volume-resistivity … look for PMMA MichaelG. |
Emgee | 30/06/2021 14:33:35 |
2610 forum posts 312 photos | Yes Brian Emgee
JasonB | 30/06/2021 15:16:18 |
25215 forum posts 3105 photos 1 articles | Corian works well too and the colours can look like old Bakelite if it's for the Ford. |
Brian H | 30/06/2021 15:39:48 |
2312 forum posts 112 photos | Many thanks for the answers, I knew that I could rely on this site! Yes Jason, it's for the Ford and I have a colour picture showing that the switch is black and I just happen to have a piece of black Perspex. Brian |
old mart | 30/06/2021 18:53:32 |
4655 forum posts 304 photos | If you have a digital meter, set it to 20 megohms and test that black plastic, it is very unlikely to be a conducting grade, but, being black, it could be antistatic, there is a remote possibility. Edited By old mart on 30/06/2021 18:54:55 |
Brian H | 01/07/2021 08:11:42 |
2312 forum posts 112 photos | Thanks for the info Old Mart, I hadn't considered that, I'll dig out my old Avo. Brian |
Joseph Noci 1 | 01/07/2021 08:36:56 |
1323 forum posts 1431 photos | Posted by old mart on 30/06/2021 18:53:32:
If you have a digital meter, set it to 20 megohms and test that black plastic, it is very unlikely to be a conducting grade, but, being black, it could be antistatic, there is a remote possibility. Edited By old mart on 30/06/2021 18:54:5 An Urban Legend that... If there are any carbon chains in that sort of coloured material, they never are in contact and never form a continuity path in the material below the hundreds of meg-ohms region. Any finger grime on the material will conduct more than the material innards! The same applies to Anti-static bags ( for electronic components, etc) - the pink, black and silver bags that are common in the field have a spec to which compliance is required - clean with alcohol and then distilled water, warm to 35deg C for 1 hour, and resistivity must be such that less than 1nanoamp will flow with 1000VDC applied to two 1cm contacts spaced 20mm apart... So the possibility of conduction in black perspex is not even remote.. - @ 5V you could use a bit of Tomato Box... Joe
Jeff Dayman | 01/07/2021 12:41:34 |
2356 forum posts 47 photos | Hi Joe, Just FYI resin manufacturers do offer many types of conductive injection moulding grades of engineering polymers. Sabic alone offer 211 grades, Link below. Some are very conductive. https://www.sabic.com/en/products/specialties/lnp-compounds/lnp-stat-kon-compound However it is very unlikely you or the OP would find scraps of one of these carbon fibre loaded polymers (or the more recently developed RGO graphene loaded ones) in your local signmaker's shop, hobby store, building supply, or industrial plastic sheet supplier. Many commonly available PMMA and polycarbonate dark colours use chemical dye for colouring them rather than solid pigment, these materials have very low conductivity as you said. On many of Henry Ford's cars until the mid 1920's, wood was used as low voltage switch gear insulator material, and after that, compression moulded thermoset phenolic resins became commonly used, one brand being Bakelite. |
Brian H | 01/07/2021 15:24:12 |
2312 forum posts 112 photos | Just tried my AVO on the black acrylic and there was no reading at all. I also tried the AVO on other items just to make sure that it is working (it is). There is a board on the back of the Ford with ignition connections and that is definitely wood. Here is a link to the slide in the Henry Ford museums website showing the switch in question. https://www.thehenryford.org/collections-and-research/digital-collections/artifact/252049/#slide=gs-212199 Any comments would be welcome. Brian |
JasonB | 01/07/2021 16:14:04 |
25215 forum posts 3105 photos 1 articles | The Perspex should work fine for that, maybe a quick rub with some Scotchbrite to knock off the gloss and it will look like the Bakelite type material. |
Brian H | 01/07/2021 17:46:41 |
2312 forum posts 112 photos | Good idea Jason, I'll do that. Brian |
Michael Cox 1 | 01/07/2021 19:01:36 |
555 forum posts 27 photos | The only problem with acrylic as an insulator is that it has quite a low softening temperature. This makes it usuitable for situations exposed to heat or where the switch may get hot. In these situation phenolic plastics like bakelite , Tufnol and Paxolin are better as they are much more heat resistant. Mike |
