Ady1 | 08/06/2021 09:36:08 |
![]() 6137 forum posts 893 photos | I've never come across proper Drummond change gears until recently and they are absolutely massive compared to the Myford gears I have been using over the last 10 years About 50% thicker than myford ones they look more like the gears out of a gearbox from a car and have a very solid run-all-day industrial look about them
Lee Rogers | 08/06/2021 10:22:49 |
![]() 203 forum posts | The small Drummond lathes (apart fron the Roundbed) were military spec industrial lathes . The Myford ML 1,2,3,4, series were all hobby machines built to a price. The Myford M Type being the exception because it was a Drummond design. The M Type is built like a brick s/h compared to an ML7 and the cost of manufacturing the M was what prompted the introduction of the more more versatile but built to a price ML7. |
geoff walker 1 | 08/06/2021 12:55:15 |
521 forum posts 217 photos | I've never come across proper Drummond change gears until recently and they are absolutely massive compared to the Myford gears I have been using over the last 10 years Ady, in 10 years you've never seen genuine drummond gears? Unusual to buy and own a drummond with no standard gears? There are usually a few in tow. Totally agree with Lee's comments. The Myford/drummond M type has 3 faults, 1 and 2 the spindle and tailstock barrel are too small, the spindle bore is too small and both have 1 morse tapers and 3 the rack feed with the single gear is operates the "wrong way". (CR*P) The last one is easy to remedy but 1 and 2 requires some serious engineering. Other than that it beats the ml7 hands down, but of course that is not reflected in second hand lathe prices
old mart | 08/06/2021 18:02:20 |
4655 forum posts 304 photos | When I was looking for changewheels for the Smart & Brown model A lathe, I bought a single Myford one to see if they were similar, as they are relatively easy to get hold of. Unfortunately, a 127 tooth Myford gear would have been much too large in diameter to fit. The S&B gears are very fine pitch, visually similar compared to a Myford gear as the Myford compares to the Drummond. I have replaced all of the S&B change wheels with MOD1 metric pitch wheels as they are easy to get hold of, and also because I got hold of a 125-127 MOD1 gear cheaply which was for some Chinese lathe. Changewheels do not have much power going through them, so there is no need for them to be huge. |
Pete Rimmer | 08/06/2021 19:03:51 |
1486 forum posts 105 photos | Drummond gear teeth are that big because if they were any smaller they'd lose teeth. They come from an era before advances in cast iron metallurgy made it as versatile as it is today. I'm not saying they couldn't do it for higher-end machines etc but I think that the £5 lathe budget stretched to more iron but not more technology. It's common to see busted teeth on lathes of this era, these days not so much. |
Lee Rogers | 09/06/2021 18:40:40 |
![]() 203 forum posts | Something to remember is that if your compounding gears you can mix them up . I have a 16t gear that is smaller than the smallest Drummond 20t , I match it to a gear of the same dp that is compounded with a Drummond gear, great for a fine feed.
Martin Kyte | 09/06/2021 19:14:11 |
![]() 3445 forum posts 62 photos | Are they not different pressure angles ? I thought Drummond was 14.5 degrees and Myford 20. regards Martin |
Ronald P | 02/01/2022 16:55:22 |
1 forum posts | Some more details on pressure angles: https://www.sciencedirect.com/topics/engineering/pressure-angle Looks like 20 degrees is more 'modern' and 14.5 is more relegated to replacement parts. |
Nigel Graham 2 | 03/01/2022 00:27:33 |
3293 forum posts 112 photos | Indeed - be careful not to mix Drummond and Myford change-wheels. Basically, they won't! I don't pretend to unsertdnad the trigonometry of gear design but do know from various reputable sources as well as simple logic that even if the DPs match, gears of different pressure-angles will not mesh properly. |
Andy Ash | 03/01/2022 02:32:12 |
159 forum posts 36 photos | "The Myford ML 1,2,3,4, series were all hobby machines built to a price." The ML1,2,3,4 must have been military spec too. Mine has an RAF "War Department" plate on it! I would never claim that the ML1,2,3,4 were high quality lathes, mind you. I think the Ministry of Supply would buy anything in those desperate days. |
John Haine | 03/01/2022 09:19:10 |
5563 forum posts 322 photos | Posted by Martin Kyte on 09/06/2021 19:14:11:
Are they not different pressure angles ? I thought Drummond was 14.5 degrees and Myford 20. regards Martin According to the myford Ltd website all their lathes are 14.5 degrees Pa. |
Michael Gilligan | 03/01/2022 09:25:10 |
![]() 23121 forum posts 1360 photos | Posted by Nigel Graham 2 on 03/01/2022 00:27:33:
[…] I don't pretend to unsertdnad the trigonometry of gear design but […] . You might get something from this 2017 thread, Nigel : **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=125474 … it includes some good animations. MichaelG. |
David Davies 8 | 03/01/2022 09:37:09 |
![]() 202 forum posts 1 photos | I believe that the Drummond gears are 14DP whereas the Myford 7 series ones are 20DP. As Lee stated above you can compound gears of different DP on the same shafts and indeed take advantage of the reduced diameter of higher DP gears if the banjo is of limited size. The above is shown clearly in Martin Cleeve's book 'Screwcutting in the lathe' on page 44, where he used a 30 DP 127T 'translation' gear for cutting a metric thread on his imperial lathe. HTH Dave Edited By David Davies 8 on 03/01/2022 09:37:52 |
John Haine | 03/01/2022 10:30:10 |
5563 forum posts 322 photos | Myford say that they are all 14.5 degree across their range. Would make sense for stockholding, plus it locks their customers into Myford spares when most commercial gears are made to 20 degrees. Helps to explain why their accessories are so ridiculously expensive. Edited By John Haine on 03/01/2022 10:31:57 |
not done it yet | 03/01/2022 11:21:39 |
7517 forum posts 20 photos | I would think that most machines made in the ‘40/‘50s (and likely all machines pre-WWII?) would have used 14 1/2 PA. Little point in Myford having a mix of otherwise interchangeable gears on their inventory/spares list. One could imagine the mixtures of gears fitted by the un-knowing hobbyists. My lathe make, that was produced in three guises from the 1940s, are all 14 1/2 degree PA, even though the DP was changed during the times of production (until the early ‘70s). |
