Hector Cole | 25/04/2021 12:10:52 |
2 forum posts | I have a ML10 and a milling attachment but cannot see how to attach the miller to the cross slide. Can anyone help here please?
Edited By JasonB on 25/04/2021 12:55:47 |
Dave Halford | 25/04/2021 14:02:43 |
2536 forum posts 24 photos | Motorised or not? Try google milling on ml10 |
Steviegtr | 25/04/2021 14:05:25 |
![]() 2668 forum posts 352 photos | The L plate bolts to the cross slide with T nut & bolts. |
John Haine | 25/04/2021 15:00:51 |
5563 forum posts 322 photos | What do you mean by milling attachment, a vertical slide (which would go on the cross slide, or a separate spindle (which would mount on the bed using the cross slide as a mill table)? |
Steviegtr | 27/04/2021 13:53:38 |
![]() 2668 forum posts 352 photos | Yes Hector i am a little baffled as to the type you have. Try to post pictures if you can. Steve. |
Steviegtr | 27/04/2021 18:39:31 |
![]() 2668 forum posts 352 photos | Hi Hector as promised on P.M here is the item. My Lathe is the Super 7B.I am wondering if your T slots are too narrow. The 2 pins slide into the same slot as the T bolts do. See pics. Hope this helps. I am pretty sure that mine is a genuine Myford item. Never used it as i now have a Milling machine. Steve. |
Hector Cole | 29/04/2021 12:11:07 |
2 forum posts | Hello Steve, Many thanks for all your help. The photos clear up the problem which was ME. I thought that the two tee bolts fitted into two slots on the slide not both into one slot. Talk about being a beginner!!!! Hector. |
Mick B1 | 29/04/2021 13:35:25 |
2444 forum posts 139 photos | I ran a very similar Myford Speed 10 for 15 years and used a similar double-swivel vertical slide. The crossslide on these machines is pretty narrow and support for milling is limited. Check the gibs aren't slack. Lock all slides except the one you're feeding for the cut. If you have a leadscrew clutch, disconnect it and close the halfnuts so you can control depth of cut on the leadscrew handwheel, and lock the saddle for each cut. Cut slow, with sharp tools, and cut light, and you could get a lot of useful service. I still have my Myford vertical slide, but I now use it on a Warco WM250V lathe, which is larger and more substantial. Well, that's my two-penn'orth... |
Steviegtr | 29/04/2021 16:15:58 |
![]() 2668 forum posts 352 photos | Posted by Hector Cole on 29/04/2021 12:11:07:
Hello Steve, Many thanks for all your help. The photos clear up the problem which was ME. I thought that the two tee bolts fitted into two slots on the slide not both into one slot. Talk about being a beginner!!!! Hector. Great stuff. Happy milling. Steve. |
