grimme | 18/04/2021 22:36:17 |
12 forum posts | im in the process of making a 24 stop dividing head thingy, (dont know what theyre are called), its a 5" chuck mounted to revolve on a heavy angle plate to be used vertical or horizontal, behind the chuck is a flange with 24 tapered slots cut into which a tapered stop locates, tapered milling cutters are big bucks so im looking for alternatives to buying one? any ideas?? |
David George 1 | 18/04/2021 22:43:58 |
![]() 2110 forum posts 565 photos | How are you cutting the slots. If you cut them on a dividing head you can rough them out square firstly, then offset the cutter and rotate the plate by a few degrees and cut the first set of side angles. Repeat the operation but opposite offset and angle to complete the angled slots for plunger. David |
Emgee | 18/04/2021 22:52:55 |
2610 forum posts 312 photos | Geoff Consider cutting parallel slots but use a tapered plunger key to index in the slot, even with the tapered slots and key it is best to lock the spindle to mill the part being held. Emgee |
Paul Kemp | 18/04/2021 23:37:07 |
798 forum posts 27 photos | Use a cheap gear cutter? That will give you a nice slot! Grind up a suitable single point tool and 'fly cut'? I think it's a spin indexer by the way. Paul. Edited By Paul Kemp on 18/04/2021 23:40:25 |
Pete Rimmer | 18/04/2021 23:40:56 |
1486 forum posts 105 photos | Posted by geoff rimmer on 18/04/2021 22:36:17:
im in the process of making a 24 stop dividing head thingy, (dont know what theyre are called), its a 5" chuck mounted to revolve on a heavy angle plate to be used vertical or horizontal, behind the chuck is a flange with 24 tapered slots cut into which a tapered stop locates, tapered milling cutters are big bucks so im looking for alternatives to buying one? any ideas?? The plate with the slots is called a masking plate. Used for rapid indexing. |
John Haine | 19/04/2021 07:30:03 |
5563 forum posts 322 photos | Why slots? Drill parallel sides holes and have tapered pin. |
old mart | 19/04/2021 19:19:16 |
4655 forum posts 304 photos | I wanted to make some special tee nuts for the compound on the Smart & Brown model A and a friend of the museum who did cutter grinding put the required taper on the end of a 1/2" four flute endmill. If you have a suitable donor cutter, then a small engineering firm could probably modify one for you cheaper than a special. Emgee's suggestion of parallel slots with a tapered plunger would work very well if the plunger included angle was about 2 degrees. |
