Mick Netting | 11/04/2021 10:34:30 |
6 forum posts | A friend of mine has an old Faircut lathe which has not been run for many years. The lathe is driven by a 1/6 HP single phase Batwin motor. This motor (type DN5A) has a handle at the non drive end which moves the brush position. The motor nameplate indicates a speed of 800/2000 RPM. I cannot understand whether moving the brush position can (if at all) change the speed of the motor ? Thanks Mick |
not done it yet | 11/04/2021 13:43:55 |
7517 forum posts 20 photos | It most certainly does. My honey extractor has a motor of that type. The control on that has such a range that it is able to reverse the motor, too. |
Paul Kemp | 11/04/2021 13:46:50 |
798 forum posts 27 photos | Not sure moving the position of the brushes would do it but maybe adding / subtracting brushes might? Say a dynamic way of changing a 2 pole motor to a 4 pole by engaging additional brushes? I know next to sod all about motors so this is purely off the wall speculation! Paul. |
John Haine | 11/04/2021 13:57:53 |
5563 forum posts 322 photos | If it has brushes and is an AC motor it will be a "universal" type. I doubt it was original equipment but was added by a previous owner. Frankly it would be kindest to give the motor a decent burial and fit a small single phase induction motor if your friend intends to use the lathe. |
Mick Netting | 11/04/2021 14:05:11 |
6 forum posts | Thanks for the replies. I’m reluctant to power up the motor in case I damage it, will check the connections next week and post some photos of anything interesting. cheers Mick |
Lee Rogers | 11/04/2021 14:08:07 |
![]() 203 forum posts | Sorry to say that I think John Haine has hit the nail on the head . also even though it's a small lathe 1/6 hp is a bit on the light side . I'be looking at 1/4 hp minimum but I'd go for 1/2 hp if I have a choice , simply because the motor would be more versatile if it was moved on in the future.
Paul Kemp | 11/04/2021 14:08:36 |
798 forum posts 27 photos | Mick, In the interests of gaining knowledge it would be great to see some pictures of how it works if you end up taking it apart! Paul. |
john fletcher 1 | 11/04/2021 14:11:35 |
893 forum posts | Its a repulsion type motor, which has an armature, similar ,but not the same as a DC motor has. It's old, it will have some cotton insulation which will be fragile by now, so dry it out in the airing cupboard . On some motors the brushes are shorted together when running and often there is a mark position for reverse running. John |
Dave Halford | 11/04/2021 18:04:22 |
2536 forum posts 24 photos | I have a brushed 1915 motor that reverses by rotating the brush carrier in a curved slot It's 1/4hp and as big as a modern 2hp. Birmingham Science Museum had one on display when it was in Newhall St. Edited By Dave Halford on 11/04/2021 18:06:55 |
Mick Netting | 21/04/2021 14:14:15 |
6 forum posts | Hello All, Thanks to all who responded to my request for information. To confirm it is a single phase repulsion motor with the brushes shorted together. By varying the brush position the motor speed can be varied from standstill to 2000 RPM. Now another request does anyone know where we can obtain a manual for the Faircut lathe which the motor drives ? will attempt to attach some photos. Mick |
Brian Morehen | 21/04/2021 19:11:07 |
![]() 191 forum posts 11 photos | THe lever on my motor when moved reverses the motor on my Faircut Lathe No known linfo seems to exist on Faircut Lathes ... Lathes Uk has a considerable amount of info worth a look at this web site Your Lathe looks like the Junior from the photo more photos will give more info. Good Luck Bee,M |
Mick Netting | 21/04/2021 20:10:45 |
6 forum posts | Thanks Brian, Yes I forgot to mention in my post, when the lever is in the centre position the motor stops and reverses direction. Mick |
