PM research #3a steam engine
Peter Etherington 230/03/2021 18:23:12
26 forum posts
Hi, I`m thinking of building a PM research #3 steam engine. This will be my "first blood" into machining. I have a lathe and mill. Would anyone recommend this as a first engine? Peter
JasonB30/03/2021 20:24:18
It's the American equivalent to the Stuart S50 and reasonably popular over there as a first casting kit engine. You are likely to get more help on this forum with an S50 as people are more familiar with them or have actually built one, different on one of the more US based forums.
I don't know what your preferred system is but the PMR engines are in imperial and will use UNC fasteners so taps and dies required for that which may nor get used much unless you stick with US designs in the future.
Peter Greene31/03/2021 01:59:39
865 forum posts
12 photos
In many cases you can probably use a close metric thread to replace the specified UN thread. The difficulty might be some rods which are 1/8' dia and are end-threaded 5-40 UNC to suit.
Jim Nic31/03/2021 10:11:19
406 forum posts
235 photos
Jason's suggestion of a Stuart Models S50 is a good one. Also a very popular engine with folk starting on the steam engine route has been a Stuart 10V. (I made mine about 10 years ago.) Tee Publishing produce a book titled "Building a Vertical Steam Engine" by Andrew Smith to give some guidance.
What you get in the kit:
How mine turned out:
For some reason it looks a lot brassier in the picture than it is in reality; the flywheel, cylinder and steam chest are polished cast iron. The air connections and pipery are not included in the kit.
Jim
Mick B131/03/2021 12:05:08
2444 forum posts
139 photos
Posted by JasonB on 30/03/2021 20:24:18:
That's fair comment. I built PM's No.7 horizontal twin a while back, and substituted comparably-sized BA hex fasteners for the slotted screws provided with the kit.
Edited By Mick B1 on 31/03/2021 12:05:59
Peter Etherington 231/03/2021 17:52:13
26 forum posts
I think I will go down the route of the Stuart Models S50. Many thanks, Peter
Peter Greene01/04/2021 01:29:21
865 forum posts
12 photos
Posted by Peter Etherington 2 on 31/03/2021 17:52:13:
In that case, Peter, please ignore my PM.
