Member postings for Peter Etherington 2
Here is a list of all the postings Peter Etherington 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: thread sealant
18/09/2021 18:58:00
many thanks
18/09/2021 18:20:58
Can Loctite 638 be used to seal a thread on a vertical boiler water gauge fitting.(boiler bush to fitting) Many thanks, Peter
Thread: How concentrated should I make a citric acid pickle ?
26/08/2021 17:56:44
Cup alloys suggest a mix of 20g of salts to 1 litre of water
Thread: PM research #3a steam engine
31/03/2021 17:52:13
I think I will go down the route of the Stuart Models S50. Many thanks, Peter
30/03/2021 18:23:12
Hi, I`m thinking of building a PM research #3 steam engine. This will be my "first blood" into machining. I have a lathe and mill. Would anyone recommend this as a first engine? Peter
Thread: what size vice for mill
29/10/2020 15:05:33
The reason im going for the er32 collet chuck is that I want one for my lathe, so two for the price of one.
26/10/2020 09:29:04
All part of the excitement
25/10/2020 19:07:16
Already on list with ER32 collet chuck, 123 blocks, angle block etc, also thinking of adding DRO. Peter
25/10/2020 17:49:39
The 3 inch radial from Arc, it is not as big as the 3 inch Versatile from the same supplier
25/10/2020 09:33:09
Thanks Jason, I will go for the 3" with it only being a small mill and i`m only building small scale steam loco`s (16mm) It`s man thing I think, always wanting something bigger smiley Peter
23/10/2020 18:25:42
Ta
Thread: riveting
23/10/2020 12:42:20
thanks john
23/10/2020 10:38:40
Thanks guys, Peter
Thread: riveting
23/10/2020 10:37:58
Thanks very much. Peter
22/10/2020 19:41:51
1/16 brass rivets to sandwich very thin stainless and thin aluminium
Edited By Peter Etherington 2 on 22/10/2020 19:44:10
22/10/2020 19:34:04
Just bought a mini mill XJ12-300 and the table size is 460 x 112mm, what would be the biggest vice I could reasonable put on it. Many thanks, Peter
Thread: riveting
22/10/2020 18:42:25
Just wondering if I could use one of those cheap 1/2 ton arbor presses to set rivets in some thin plate. Peter
Thread: interest renewed
19/10/2020 18:28:31
Just a quick update, I have taken the bull by the horns and bought a Amadeal XJ12-300 mill, just the right size for me and to get it in my workshop had a major sort out. Happy days. Peter
Thread: joining metals
30/09/2020 17:06:14
Thanks very much for all the interesting information, Peter
29/09/2020 18:32:22
Thanks John
