Ron Laden | 09/03/2021 17:18:25 |
![]() 2320 forum posts 452 photos | Any recommendations for Dremel type cutting discs that have reasonable life and are good value for money. The ones I have at the moment cut well but their size reduces faster than what they are cutting. Around 25 - 30mm would be good though not critical, dont have to be genuine Dremel as long as they do the job. Ron |
bernard towers | 09/03/2021 17:20:48 |
1221 forum posts 161 photos | Drexel are the only ones that do the job |
Jeff Dayman | 09/03/2021 18:17:46 |
2356 forum posts 47 photos | There are two types (at least) of Dremel cutting discs. The 1" dia ones with the small screw retaining them do a great job but as you say Ron they wear fast. However the second type are 1 1/2" dia and fit on Dremel's E Z Lock mandrel. The metal cutting ones are fibre mesh reinforced and last much longer. One drawback though is that they wobble a tiny bit on the mandrel and are thicker than the smaller disks, so the cut width is larger. Link below shows these at a Canadian retailer's website. I am sure you can get them in UK at a Dremel distributor. https://www.canadiantire.ca/en/pdp/dremel-ezlock-grinding-disc-0543976p.html?rrec=true#spc The next step up is the 1 mm thick cut disks for 4 1/2" angle grinders. You can do some serious damage fast with one of those! |
Martin Kyte | 09/03/2021 18:18:20 |
![]() 3445 forum posts 62 photos | You could switch to diamond discs. regards Martin |
BC Prof | 09/03/2021 18:23:51 |
182 forum posts 1 photos | I use the small 1" diameter discs. The trick is not to push them very hard . They are after all grinding the material away. I used one disc to cut the length of a 3" Burrell chimney made from 1.2mm sheet steel and still had some left at the end ( small some !) Brian |
colin hawes | 09/03/2021 18:36:02 |
570 forum posts 18 photos | You need to use the highest speed and a light cut so the motor doesn't slow down too much. I have used various makes to cut nuts and exhaust U bolts under cars where there is no room for an angle grinder. Colin |
HOWARDT | 09/03/2021 20:02:33 |
1081 forum posts 39 photos | I use the Dremel ezlock and have no trouble with wobble and they have a good life if not pressed hard. The smaller discs are brittle and I find they break before they wear, ok for cutting small diameters. |
Martin Dilly 2 | 09/03/2021 23:55:33 |
50 forum posts 7 photos | Try the dental technician suppliers. They have a vast range of disks and all sorts of handy cutters and burrs. |
Ron Laden | 10/03/2021 07:05:20 |
![]() 2320 forum posts 452 photos | Thanks guys I have ordered the Dremel speedclick mandrel and 5 discs I will see how I get on with those. Ron |
Nicholas Farr | 10/03/2021 07:36:59 |
![]() 3988 forum posts 1799 photos | Hi, these Cutting Discs or these More Cutting Discs may interest you. (not sure if Amazon links are allowed though) Regards Nick. |
Nick Clarke 3 | 10/03/2021 09:51:24 |
![]() 1607 forum posts 69 photos | Hi Ron - I appreciate you have one solution but I bought a pack of 85 of the ordinary disks from a high street tool and machinery dealer at about 10p a disk - They do wear down and can break, but they are cheap enough for me to cope with that. |
Ron Laden | 10/03/2021 10:07:58 |
![]() 2320 forum posts 452 photos | Thanks guys, Nick the ones I have are probably similar to your pack of 85 they came as part of a set I bought years ago but had not tried them until yesterday. I ran at 30,000 rpm and I am not heavy handed but I reduced the disc by more than half its diameter in reducing the length of thread on 8 x 6BA screws. I guess as part of a set they are probably the bottom end of quality but didn't quite expect them to be that bad. I will see what the Dremel ones perform like and report back. |
Ron Laden | 13/03/2021 08:00:17 |
![]() 2320 forum posts 452 photos | The Dremel Speedclick mandrel and discs arrived and a quick test proved them to be very good, much better than what I have been using. A bit of an acid test more than what I would do with small discs but I cut through a 10mm round piece of EN8 and the disc reduced by just 0.6 mm, more than happy with that. |
Nick Wheeler | 13/03/2021 09:23:44 |
1227 forum posts 101 photos | You can get reinforced similar to the Speedclic ones, but without the proprietary fitting. They last almost as long, but are a lot cheaper. I find that Dremels are one of those tools that seem like a good idea, but are not much use in practice. Especially if you're using them on steel. |
