boring bar
david sanderson 323/02/2021 14:58:13
17 forum posts
img_0202.jpgimg_0204.jpghi all does anybody recognise this small boring bar its made by HOYBIDE and is 6mm in diameter I'm trying to find inserts for it but haven't had any luck they are tiny img_0204.jpg
ega23/02/2021 15:04:39
2805 forum posts
219 photos
I have a bar which may be similar; it's marked:
BBPW-508R 702
Might this lead you to the tip type?
PS NB mine is 8mm in diameter but the tip is indeed tiny. So, possibly "506R"?
Edited By ega on 23/02/2021 15:05:37
Edited By ega on 23/02/2021 15:06:24
Michael Horner23/02/2021 16:08:25
229 forum posts
63 photos
H David
Look up trigon inserts. WCMX0301-SMALL BORING-BAR CARBIDE INSERTS -SUMITOMO.QTY5.
And see if they look similar.
I thought mine were triangular and by chance came across the above and realised they weren't!
Cheers Michael.
old mart23/02/2021 16:13:00
4655 forum posts
304 photos
I have looked for Hoybide without much success. The only likely looking candidates for your inserts all have proprietry codes which is no help at all if the original Hoybide information is missing. The shape is a combination of T and W type inserts which means that no common inserts will fit.
Unless somebody on the forum already has that H6 FR boring bar and knows the insert code, I fear you will be unlucky.
Emgee23/02/2021 16:39:15
2610 forum posts
312 photos
David
Have the used cutting corners just been ground off or is that the true shape ?
Emgee
ega23/02/2021 16:57:48
2805 forum posts
219 photos
Here's a photo of an unused tip for the Sumitomo bar I referenced above:
The squares are 1/10" in size.
david sanderson 323/02/2021 17:27:10
17 forum posts
thanks everyone will keep looking
Robert Butler23/02/2021 18:46:47
511 forum posts
6 photos
Ring Jenny J B Cutting Tools she will probably know exactly what you want, a very helpful lady.
Robert Butler
Steviegtr23/02/2021 18:51:35
2668 forum posts
352 photos
Would a triangle insert fit in that pocket.
Steve.
DC31k23/02/2021 19:06:36
1186 forum posts
11 photos
Posted by Robert Butler on 23/02/2021 18:46:47:
And he could be helpful to her if he does what Mr ega suggests and finds information on the bar.
A Google search for 'BBPW-508R' produces a myriad of useful results including insert codes.
e.g. https://id.c.misumi-ec.com/book/SED1_ENG_T01/pdf/0289.pdf
Meunier23/02/2021 20:42:57
448 forum posts
8 photos
Last year purchased some Hoybide tips, the vendor informed me that Hoybide has been integrated into the 'Total Carbide' group.
DaveD
Edited By Meunier on 23/02/2021 20:43:22
Having said that, memory was stirred, as part of the purchase came several cutting tools, including one -
Komet boring bar "BOO 35310", 70mm long, major dia 7.98mm on round portion, across flat 7.47mm, reduced portion with one drill-type flute 6.38mm. I couldn't find such a small torx key but a spare tip overlaid coincided and measured 6.06mm in digital caliper jaws (like measuring 50p coin only with six sides )
The box of tips marked Hoybide Ltd 'PD05 200802 SW/P25M'
HTH
DaveD
Edited By Meunier on 23/02/2021 21:23:41
ega23/02/2021 22:53:59
2805 forum posts
219 photos
DC31k:
Thanks for the very helpful link. It looks as though my inserts are WB 0601.
david sanderson 3:
I wonder whether this tip would fit your Hoybide bar. I could send you a worn insert from my Sumitomi bar for comparison if you are still struggling.
david sanderson 324/02/2021 08:56:27
17 forum posts
after reading all the posts and following your links I'm thinking the insert is WBMT thanks to all
old mart24/02/2021 15:33:55
4655 forum posts
304 photos
When you find a source of inserts, compare the price against the £15 that a bar and 10 inserts would cost on line.
