Sieg X3 Tacho
Fitting a rev counter
Clive Hartland22/02/2021 14:55:55
2929 forum posts
41 photos
I wish to fit a rev counter to my X3, has anyone done this?
Source of parts and where to fit the counter.
help please.
Bob n About22/02/2021 15:55:02
60 forum posts
You mean something like this
https://www.instructables.com/An-Easy-and-Cheap-RPM-Tachometer-Upgrade-for-the-M/
JasonB22/02/2021 16:12:33
I bought a cheap tacho from e-bay along with a suitable transformer. Stuck the magnet to the spindle just below the gear with araldite and use one of the head top cover hole sto mount the sensor. Readout sits just under the e-stop button's panel.
Clive Hartland22/02/2021 22:29:21
2929 forum posts
41 photos
Thanks Jason and Bob, gives me a starting point. How this has come about is because I am slotting large bronze screwheads and the slotting saw is not happy. So I upped the rpm and it was fine. So I felt I need some reference of the rpm of the cutter.
I will follow this up and see what I can do, Thank you.
not done it yet22/02/2021 23:16:25
7517 forum posts
20 photos
Those chinese kits are simple cheap and easy to fit.
An alternative solution, if only the slitting saw speed wax of interest, might be to buy a cheap hand-held taco as that could be used elsewhere.
Clive Hartland23/02/2021 12:57:18
2929 forum posts
41 photos
My X3 is cogged belt drive, not gears like Jasons. I can do nothing on top as the spindle can go downwards if I need Z drive facility.
I can perhaps place a sensor under the head and have a mark on a collar under the head, I wonder if it will get in the way there?
Perhaps i shall continue to fly by the seat of my pants regarding the cut.
Clivve
JasonB23/02/2021 13:09:15
You could stick the magnet onto the top of the pulley and mount the sensor in a hole drilled into the top cover.
Or do as NDIY suggests just use a hand held one for the odd occasion you want to know the speed.
Ian Hewson23/02/2021 13:26:50
354 forum posts
33 photos
on my sx2 I have a hole drilled in the drawbar cover for the sensor, and the neodium magnet just sticks to the drawbar, no glue.
Ian
Michael Cox 123/02/2021 14:44:05
555 forum posts
27 photos
Clive, I do not know how similar your X3 is to my little X1 mill but I have added a tacho, see:
http://mikesworkshop.weebly.com/mill-tachometer.html
The tacho unit was supplied with a hall efect sensor but the sensor was too large to fit in a convenient place so a made a simple optical reflective sensor which works well using a reflective strip on the spindle.
