Clay Jones | 12/02/2021 17:51:54 | ||
37 forum posts 1 photos | This ME hobby being highly addictive I’ve decided to treat myself to a new mill and have on back order a WM16B from Warco. Even though it’s a few more weeks yet I’ve decided to spend this weekend preparing an area of bench in my workshop to receive it. It would be really helpful to know the overall depth of the mill less the Y Axis wheel as this can overhang the edge of the bench. The PDF catalogue states 600mm so I guess the question is what is the depth of the wheel to dictate bench depth with a nats whisker back of mill to wall operation. Space is a bit tight and a snug fit would be ideal. Hopefully someone has the same mill. Thanks Clay | ||
Oldiron | 12/02/2021 17:57:50 | ||
1193 forum posts 59 photos | Took these dims out of a Google search. IHIH regards
Edited By Oldiron on 12/02/2021 18:00:04 | ||
Clay Jones | 12/02/2021 18:00:38 | ||
37 forum posts 1 photos | Ah yes I see that but I think the error in 200 depth is wrong as the PDF brochure states 600, thanks for looking mind. | ||
Nigel Graham 2 | 12/02/2021 18:03:08 | ||
3293 forum posts 112 photos | Don't forget the total width the machine needs - start at table length + travel + hand-wheels, as a rough guide. Milling-machines take a lot more room than you might think! Watch too for overhead room, depending on the machine type. I am not familiar with the WM16B but some, such as my Myford VMC with its hinged pulley cover, or those with a big upwardly-pointing motor, need appreciable headroom. | ||
Clay Jones | 12/02/2021 18:13:50 | ||
37 forum posts 1 photos | Thanks Nigel, travel width and height is no problem it’s just depth. From what I understand there is nothing at the back to cause a problem, may be wrong. It may well be I’m over thinking this but depth less front wheel dim would be handy. | ||
BC Prof | 12/02/2021 18:50:46 | ||
182 forum posts 1 photos | Back to front of tray ( or even front to back ) is 520mm . Handle sticks ou a further 100mm to the end of then handle
Brian | ||
Clay Jones | 12/02/2021 18:54:36 | ||
37 forum posts 1 photos | Your a gent Brian thank you. | ||
Stuart Smith 5 | 12/02/2021 19:02:40 | ||
349 forum posts 61 photos | I have my Warco WM16 on a wooden bench 550mm deep. The chip tray is 50mm from the wall and is 480mm deep. This is about as close as you can put it to the wall so that you can turn the column handle without your knuckles hitting the wall. The y axis handle protrudes about 100mm in front of the chip tray. The mill x axis table is 700mm wide and 930mm wide across the x axis handles plus you need extra space each side for the x axis travel. (About 200mm each side). Hope this info is useful. Stuart | ||
Clay Jones | 12/02/2021 19:42:21 | ||
37 forum posts 1 photos | Brilliant thanks Stuart
Roger Best | 19/02/2021 23:35:41 | ||
![]() 406 forum posts 56 photos | Yo Clay - welcome to the 16B club There are a few errors in the Warco website, I found one of them the hard way - the chip tray dimensions are the wrong way round, you need 520mm depth to fully support the tray, 500 is fine, mine is even less and the base of the machine is fully supported. The distance of the Z-axis wheel to the wall is OK, I will be putting some slippy plastic on the rough wall nevertheless. The machine is not as high as the maximum height listed, so I didn't have to move my lights. My brain is failing - please use the link under my name to see the pictures. Other wise here is my thread:
Edited By Roger Best on 19/02/2021 23:39:45 | ||
Steviegtr | 19/02/2021 23:59:42 | ||
![]() 2668 forum posts 352 photos | I bet you are excited. Wait till you have to sweep the floor. + her indoors keeps saying where is all this metal coming from that is stuck in the carpet. HA HA. Good luck with your new machine. Steve. | ||
Clay Jones | 20/02/2021 05:31:34 | ||
37 forum posts 1 photos | Hi Roger, thanks for the link to your thread, very useful, and interesting solution to your install issues. Fortunate in having a heavy duty table lift as like most years in the building game my back, like most isn’t as good as it was. I’m very lucky to have a decent workshop but it’s nicely fitted for joinery and half my issues were in miserly freeing of space for this addictive new hobby that is model engineering. Finally committed to giving myself more space so no longer an issue, although careful saw dust cleaning and protection may be required. Hi Steve, yes I’m like a kid at Christmas and just had an Email to say shipment has landed and early March is looking good. Just checked out your videos, looks like we’re kindred spirits on the car front. Gave the bikes up after one too many scary moments. Ride safe fella.
Edited By Clay Jones on 20/02/2021 05:56:20 | ||
Clive Foster | 20/02/2021 09:07:56 | ||
3630 forum posts 128 photos | Clay If you install the machine with the Y-axis handle overhanging the bench look into replacing the standard handwheel with one having a folding handle. In cramped spaces the standard fixed style tend to be needy and keep prodding you for attention! I shoved one of the big square column bench mills into grossly inadequate space. Fitting folding handle wheels made the difference between "think thin" and "learn to operate the feed with your tummy". The ones I found were also maybe 1/2" slimmer when mounted. Every little helped. I think mine came from RS but there are plenty of suppliers. Put the standard ones back on when I sold the mill so I may still have them if you want to try one. Clive | ||
Clay Jones | 20/02/2021 17:22:33 | ||
37 forum posts 1 photos | Thanks for that Clive great idea. Just finished stripping out the corner of shelving and fitting electrics so I’m sure there should be plenty of space now. 1.4w x 720 deep and 1m high. Edited By Clay Jones on 20/02/2021 17:22:59 | ||
Roger Best | 20/02/2021 23:22:49 | ||
![]() 406 forum posts 56 photos | That looks the business. |
