Stuart dynamo rotation
Former Member06/02/2021 17:30:12
1085 forum posts
john fletcher 106/02/2021 17:36:23
893 forum posts
I've never seen a Stuart Dynamo, but if the brushes are angled no as they would chip off the leading edge in reverse. If they are straight, I can't so a problem other than the polarity of the terminals. John
Former Member06/02/2021 17:45:03
1085 forum posts
Thomas Cooksley06/02/2021 17:56:08
55 forum posts
HI, I am not familiar with the Stuart dynamo but you should be able to do it. It depends on the excitation. Reversing the direction will reverse the polarity of the output. You may need to build up the remnant flux in the field coils in the opposite direction to make it work. Tom.
not done it yet07/02/2021 07:10:28
7517 forum posts
20 photos
Dynamos are dynamos. We always ‘flash the field coils’ on vehicle dynamos when changing polarity or fitting a different one.
John Haine07/02/2021 09:30:50
5563 forum posts
322 photos
The spare parts list mentions a magnet which suggests a PM field., in which case it will happily run either way but polarity will reverse.
Former Member07/02/2021 09:37:43
1085 forum posts
SillyOldDuffer07/02/2021 10:22:47
10668 forum posts
2415 photos
Posted by not done it yet on 07/02/2021 07:10:28:
Dynamos are dynamos. ...
I think so too, but some DC motors have offset brushes, which improves efficiency, and running them in reverse damages the brushes. The drawing is exaggerated but if the brushes are offset as shown on the right, don't run in reverse.
Is it likely a Stuart Dynamo is designed to maximise efficiency? Probably not! Never seen a DC motor with offset brushes either, but my experience is tiny. They do exist.
Former Member07/02/2021 10:38:01
1085 forum posts
John Haine07/02/2021 10:46:35
5563 forum posts
322 photos
I thought AC series wound motors can have offset brushes to improve efficiency given the inductance in the windings - and they are not reversible. DC motors uness made for a very specific application may be required to run in either direction so would not have offset brushes. Anyway this is a model dynamo to show off a steam engine, efficiency is hardly likely to be an issue!
Edited By John Haine on 07/02/2021 10:47:02
Michael Gilligan08/02/2021 23:08:51
23121 forum posts
1360 photos
At the risk of inciting semantic outrage ...
The ‘Stuart Dynamo’ is an AC Generator:
https://youtu.be/qOZGZ__3vi8
So the brushes are in contact with slip-rings, and therefore most unlikely to be damaged by reversing the direction of rotation.
Speedy Builder509/02/2021 07:03:26
2878 forum posts
248 photos
Is it a DYNAMO ? A/c current, slip rings - dynamo or alternator ???
Oops, I should have read the previous post from Michael!
Edited By Speedy Builder5 on 09/02/2021 07:05:35
Michael Gilligan09/02/2021 07:42:34
23121 forum posts
1360 photos
My best guess is that the word ‘alternator’ was coined for the emerging Motor Industry, to conveniently distinguish AC dynamos from DC dynamos ... but I don’t know by whom.
Alternating Current Generator
Here’s some more info about the Stuart machine : **LINK**
http://www.stuartturnersteam.com/Machines/Bottone/Bottone.html
Edit: __ I haven’t yet found a freely downloadable copy of Bottone’s little book, but :
https://www.si.edu/object/siris_sil_243390
and
https://www.nature.com/articles/031052a0
UPDATE:
https://ia800205.us.archive.org/26/items/dynamohowmadehow00bottrich/dynamohowmadehow00bottrich.pdf
Edited By Michael Gilligan on 09/02/2021 08:04:35
Michael Gilligan09/02/2021 08:33:35
23121 forum posts
1360 photos
Posted by Michael Gilligan on 09/02/2021 07:42:34:
My best guess is that the word ‘alternator’ was coined for the emerging Motor Industry […]
A bad guess ^^^ it appears: **LINK**
https://en.wikipedia.org/wiki/Alternator#History
JasonB09/02/2021 09:01:53
Posted by Michael Gilligan on 08/02/2021 23:08:51:
Excuse the outrage but Stuarts also made two DC ones, which Dave may have been thinking of as Br had not shown which one he had at the time. One was small and intended to be run from the S50 and 10 series models, the other older one was more like Br's in looks
Michael Gilligan09/02/2021 09:24:04
23121 forum posts
1360 photos
You don’t need to be excused, Jason ... You are a Moderator
‘though I’m not sure why you felt the need to post a link to a page I had already referenced.
Note: The semantic outrage that I risked was that initially expressed by Speedy Builder5
... but of course he then read my post, and got the point.
Edited By Michael Gilligan on 09/02/2021 09:28:53
Former Member09/02/2021 09:25:40
1085 forum posts
noel shelley09/02/2021 12:45:07
2308 forum posts
33 photos
AC can be easily be rectified by fitting a simple bridge rectifier to give DC ! Noel
Former Member09/02/2021 12:54:37
1085 forum posts
SillyOldDuffer09/02/2021 13:24:28
10668 forum posts
2415 photos
Just out of curiosity does it have brushes at all? Is it really a Magneto, i.e. the armature spins a permanent magnet rather than an electromagnet powered by slip rings? The warning about not removing the armature without bridging it suggests a permanent magnet to me. Doesn't matter: Magneto or slip ring alternator, it should generate rotated in either direction.
Etymology is interesting. From the Greek word for force δύναμη. Dynamo appeared in 1882 as a contraction of Dynamo-machine, itself a contraction of Dynamo-electric-machine which dates to 1862.
Current electricity was originally called dynamic electricity and we still call the other sort Static Electricity.
There's nothing in the dictionary to suggest a dynamo produces DC rather than AC, so I guess the distinction between Alternator (AC) and Dynamo (DC) is technical English and came later.
Edited By SillyOldDuffer on 09/02/2021 13:25:55
