ML7
john brown 1730/01/2021 18:01:05
135 forum posts
Hi all , with regard to the ml7 cross slide nut mine is showing signs of in need of a new one ,but it seem imperial ones are out of stock apart from the super 7 and l take it they would not fit ,now has anyone made one before ,yes l know l would have to buy a tap when l no what the thread size is,or do l wait untill they are back in stock ?,will be led by you experts.
john
Steviegtr30/01/2021 22:56:31
2668 forum posts
352 photos
Are you sure it is the nut. My super 7 had quite a bit of play which i wrongly assumed was wear in the nut. Once i had re-bushed the handwheel carriage support, the play went away.
Steve.
not done it yet31/01/2021 07:47:12
7517 forum posts
20 photos
New nut? Why not repair the one you have? Easily done, although a bit tight if single pointing the thread.
john brown 1731/01/2021 08:45:45
135 forum posts
Will have a better look later at the bushing steve and se if it could be that good point
john
Andrew Moyes 131/01/2021 08:49:12
158 forum posts
22 photos
My Super 7 has a 1/2" x 10tpi RH Acme thread on the cross slide. I believe the ML7 may be 3/8" X 10tpi. Tracy Tools sell 3/8", 7/16" and 1/2" taps of that form and pitch.
john brown 1731/01/2021 12:49:43
135 forum posts
Well it seems steve was on the money the bushing is well worn ,and putting in the screw in to the nut there seems not to be any lash on that ,but did find the nut was loose as well ,so that was not helping matters,so will re bush the housing and go from there ,well l am at it will re bush the carrage handle.
john
V8Eng31/01/2021 13:32:46
1826 forum posts
arceurotrade (advert near top right on this page) do a modification kit for the ML7 cross slide handle which makes  operating it much better.
There is some machining required to fit the parts so I’ve linked to the details here:-
Arc ML7 Mods
Edited By V8Eng on 31/01/2021 13:33:53
john brown 1731/01/2021 15:43:01
135 forum posts
Thanks v8eng ,yes did se that mod ,but for now its going to be a quick fix bush job as the mod kit is out of stock,but think l will order one when back in.
john
Steviegtr31/01/2021 16:14:11
2668 forum posts
352 photos
Posted by john brown 17 on 31/01/2021 12:49:43:
john
John this is how i did it.
Steve.
Myford 7 re bushing
john brown 1731/01/2021 17:35:51
135 forum posts
Steve very good video ,very clear to follow ,thanks.
john
Phil H131/01/2021 18:54:09
467 forum posts
60 photos
The arc conversion looks nice but it says that it won't work on a Super 7 lathe. Does anybody know of a Super 7 equivalent modification?
