Bo'sun | 29/01/2021 09:46:06 |
754 forum posts 2 photos | Good morning, I've been sorting through some acquired taps and dies and came across a die with the engraving "3/8 x 26 BRASS", made by LAL ltd England. It's a conventional round split steel die. Too fine for BSF or UNF. Any suggestions what it's for? |
JasonB | 29/01/2021 09:51:40 |
![]() 25215 forum posts 3105 photos 1 articles | Brass thread is a standard thread form. originally used on brass tube wher ethe wall thickness was too thin for a coarse thread. Edited By JasonB on 29/01/2021 09:52:36 |
DC31k | 29/01/2021 09:52:15 |
1186 forum posts 11 photos | Please have a read of these threads: https://www.model-engineer.co.uk/forums/postings.asp?th=170639 https://www.model-engineer.co.uk/forums/postings.asp?th=170798 |
Bo'sun | 29/01/2021 10:38:36 |
754 forum posts 2 photos | Thank you, Any idea what sort of things would they have been used for? |
Chris Evans 6 | 29/01/2021 10:52:00 |
![]() 2156 forum posts | Posted by Bo'sun on 29/01/2021 10:38:36:
Thank you, Any idea what sort of things would they have been used for? Light fittings and some plumbing items. |
Nicholas Farr | 29/01/2021 11:04:05 |
![]() 3988 forum posts 1799 photos | Hi Bo'sun, I guess you can use them for anything you like, but as Chris has said, light fittings are typical. Regards Nick. |
noel shelley | 29/01/2021 11:50:13 |
2308 forum posts 33 photos | A thread system that used 26 tpi for all diameters. Thin walled brass tube, hence the name. A common thread in light fittings now is 10mmX 1.0 Noel |
Howard Lewis | 30/01/2021 19:58:35 |
7227 forum posts 21 photos | As a footnote, if needed, BSB is a Whit form thread, of 55 degrees. 1/4 BSF happens to coincide by also being 26 tpi. Cycle Thread (CEI ) also standardises on 26 tpi but is 60 degree form. It does not coincide with any UNF or UNEF size.. Howard |
Bo'sun | 31/01/2021 09:37:43 |
754 forum posts 2 photos | Thank you Howard. |
Peter Jones 20 | 03/02/2021 16:12:19 |
![]() 63 forum posts 9 photos | All the information was available in the free 'handbook' pages published in the 90's in MEW. I still have mine and reference it more frequently than I probably should to make comments on You Tube |
