Any information greatly appreciated. 2
Knock-Wood20/01/2021 19:23:22
5 forum posts
4 photos
Hopefully somebody can tell me something about this?
Oldiron20/01/2021 19:45:05
1193 forum posts
59 photos
Looks like a Mercer 108/401 comparator stand. Used in a test lab or toolroom. It is a very heavy piece of kit and very stable.  Could also be a CE Johansen item as they were almost identical.
regards
Edited By Oldiron on 20/01/2021 19:47:23
Kiwi Bloke21/01/2021 08:31:10
912 forum posts
I have one, but don't remember noticing a maker's name. To elaborate Oldiron's post, if uncertainty persists, the small dia. rod, lying adjacent to the corner of the base casting, fits into the clamp already fitted on the vertical rod. A dial indicator is clamped onto the small-dia. rod. It's a very high quality, and rigid, stand, for use primarily on a surface plate. Horribly expensive new!
Bo'sun21/01/2021 09:37:46
754 forum posts
Another vote for a comparator stand. For inspection room use rather than production. Production comparators would have the reference surface incorporated into the instrument. The name Sigma seems to ring a bell.
Dr_GMJN21/01/2021 17:12:21
1602 forum posts
The arm and fine adjust clamp look very similar to my Eclipse stand. Perhaps they were a standard item?
It's rock solid, but a bit bulky and heavy to use, particularly the magnet button which takes some effort to push in.
Howard Lewis21/01/2021 18:32:15
7227 forum posts
21 photos
The Eclipse stand has, from memory, a 5/16 BSF tapping for the standard pillar. The heavier one shown is a later addition. A good upgrade.
But the OP's equipment looks to be of industrial quality, and good solid kit to have. It may well have from a Standards Room or a Toolroom. so is likely to have been misused.
A good acquisition.
peak421/01/2021 18:41:13
2207 forum posts
210 photos
If you look up something like "cast iron indicator stand" in your favourite search engine, you will come across images such as this one
https://innovative-measurement-technology.co.uk/products/hand-workshop-tools/control-rulers-squares-and-stands/stands/column-dial-indicator-holders/art-250-dial-indicator-holder-with-moveable-column/
Which should give some idea of its use.
I have something similar, again with no makers marks at all.
Mine has a nice black crackle paint finish; I assume mine is US/UK as the column is 13/16" and the cross arm is 1/2", rather than either being metric.
The other obvious difference in mine is the top slot; yours and the one I linked to are T slots, whereas mine is dovetailed.
Mine came without the cross bar and accessories, so the plan is for a length of ½" silver steel and a holder for the end to take my various clocks.
Bill
Dr_GMJN21/01/2021 19:55:21
1602 forum posts
Posted by Howard Lewis on 21/01/2021 18:32:15:
A good acquisition.
When you say "Industrial Quality" - mine's got "Turbine Dept Sept 69" stamped on it, so I think it was used in a factory somewhere. Once clamped, it's going nowhere...
I'd think if the O/P's stand was used as you suggest, it would have been looked after far better than a shop floor item.
Nicholas Farr21/01/2021 20:38:43
3988 forum posts
1799 photos
Hi, here's a photo of the Mercer 108/421 that I have. Looks a little different than the O/P's one.
Regards Nick.
Edited By Nicholas Farr on 21/01/2021 20:40:35
John Reese21/01/2021 22:32:23
1071 forum posts
I have one similar to the first one shown. It was made by Brown & Sharpe. It does not have the fine adjustment screw. Most of the time it just sits quietly in its box.
peak422/01/2021 22:37:29
2207 forum posts
210 photos
Not the best of photos, I forgot to do it before it went dark.
Anyone know what make mine is please, just out of curiosity really.
Almost certainly UK/US as the sizes are imperial, ½" hole for the cross bar, so this shock absorber spindle is just too loose. 13/16" for the column.
The base is 6"x 2¾" x 1 ¾"
Thanks
Bill
Edited By peak4 on 22/01/2021 22:38:55
old mart23/01/2021 15:14:00
4655 forum posts
304 photos
We have one of the base castings at the museum, I had an idea what it was, but have never seen the whole thing. Our one has a tee slot rather than a vee. To make ours more useful, I milled the rads at the base square so it could be clamped down to the mill bed. I also drilled three holes through the slot to use bolts to hold it down. We already have some tee nuts which fit, I cannot remember what size they are.
Oldiron23/01/2021 16:24:54
1193 forum posts
59 photos
Posted by old mart on 23/01/2021 15:14:00:
Possibly a Starrett 665JZ indicator stand.
regards
Oldiron23/01/2021 16:31:00
1193 forum posts
59 photos
Posted by Nicholas Farr on 21/01/2021 20:38:43:
Regards Nick.
Nice box Nicholas. Have you got the platen that goes with the base for comparison measurements? I have one some where but not sure where at the minute.
regards
Nicholas Farr23/01/2021 16:42:37
3988 forum posts
1799 photos
Hi Oldiron, all you see is all I have, it was take it or it goes it the skip, where I used to works years ago.
Regards Nick.
Oldiron23/01/2021 17:04:39
1193 forum posts
59 photos
Posted by Nicholas Farr on 23/01/2021 16:42:37:
Regards Nick.
Nice to have though as is. I only use mine on my surface plate as an indicator stand as it is nice and heavy
regards
