Carriage stop/dial gauge mount.
Might be usefull?
Bo'sun06/01/2021 10:30:44
754 forum posts
Morning All,
While looking on a well known auction site for a S/H Mitutoyo lever type indicator, I came across several of these for various lathes (including: Warco, Boxford, Harrison, Emco & Harrison). While they are made for dial gauge fitment, I'm sure they can be adapted to make a carriage stop. Not sure how they get around the differing vee angles that we experience. Yes, we can make our own, but for £25.00, and someone who hasn't got a mill (yet), it might be useful.
Not sure what it's made of, but I'm guessing it's aluminium.
"WARCO 240 & 250 Lathe Dial Indicator Gauge DTI Holder Clamp Mount DRO"
Sorry, but "cut & paste" doesn't seem to work for me.
SillyOldDuffer06/01/2021 11:40:21
10668 forum posts
2415 photos
Posted by Bo'sun on 06/01/2021 10:30:44:...
Can't help with the clamp, but browsers refusing to cut and paste with the mouse is a common security precaution. It's not a feature peculiar to this forum.
Problem is naughty hackers can write web scripts capable of imitating your computer's mouse cut, copy and paste commands. Thus they can paste their material on to your machine, or copy data from your computer back to base. The technique also works on any website you happen to be connected to, like your bank account.
The risk is prevented by blocking mouse commands. Then cut, paste, and copy must be applied from the keyboard (ctrl-x = cut , ctrl-c = copy, ctrl-v = paste) Keyboard commands are safer because they're applied by people rather than a script downloaded silently from the internet.
You might wonder what sort of website does this? Possibly reputable sites who have been hacked. This is most likely to happen to websites with lax security - not kept up to date etc. (Some site owners are naive about security and/or unwilling to spend money on it! Most common source though is dodgy sites - beware if you're into porn, illegal gambling, trolling, extreme politics, gossip, off-colour humour or anything else shady.
Bo'sun06/01/2021 11:45:38
754 forum posts
Thanks Dave, but most of that has gone completely over my head, but I think I get your drift. Not into any of those things you mentioned at the end.
Tony Pratt 106/01/2021 12:05:35
2319 forum posts
13 photos
It's 3D printed plastic.
Tony
Henry Brown06/01/2021 12:13:22
618 forum posts
122 photos
My machine allowed me to cut and paste it ok. I had a look and downloaded an image - I might try to draw one in CAD to 3D print. Here a picture of one:
IanT06/01/2021 12:50:21
2147 forum posts
222 photos
Posted by Henry Brown on 06/01/2021 12:13:22:
And if you did Henry - I might try to print one!
IanT
Brian H06/01/2021 12:56:53
2312 forum posts
112 photos
Many thanks Henry, that looks very useful. If they are cheap enough I may buy one; otherwise it'll be a nice little workshop project.
Clive Brown 106/01/2021 13:36:42
1050 forum posts
56 photos
Couple of thoughts on the ebay items; I have a Boxford micrometer saddle stop, it's a fairly substantial chunk of metal which is clamped firmly to the lathe bed. It has to be so because the saddle can gve it quite a clunk at times,
I'm constantly moving it along the bed to suit the job in hand. The clamping mechanism needs to be robust and hard wearing.
The printed items, to me, don't look as if they'd be too rigid. OK for pressure from a DTI perhaps but not as a physical stop.
Henry Brown06/01/2021 13:53:05
618 forum posts
122 photos
Posted by IanT on 06/01/2021 12:50:21:
IanT
LOL, my 3D CAD skills are very limited as are my 3D printing skills Ian, don't hold your breath! I did manage to draw up a small box for my tool tips (to go with the Multifix holders I downloaded from Thingiverse) to print yesterday...
Danni Burns26/05/2021 12:54:39
69 forum posts
42 photos
Hi all
Did anyone get any further with this?
I know Im polishing a turd, but I would be interested in buying or making one of these for CL500M
It woudl be good to find 50mm long reach clocks also. I can find 2"
cheers
Howard Lewis26/05/2021 16:06:29
7227 forum posts
21 photos
I made a clamp to mount onto the bed of my BL12-24, so that a Micrometer barrel could be mounted. It is used, when nrequired as a Saddle stop.
The mic is extended by the required travel and the stop clamped to the bed wsith bthe micrometer spindle against the Saddle. The Mic is then nretracted to the Zero position. AS the Saddle mapproaches the stop, power feed is disconnected, and the Saddle brought to the stop by hand feed.
In this way no mdamage is done, and the stop is not moved from it's position.
For a lathe with a dovetail bed, (Myford ML1,2, 3 ,4 , Clarke CL430 or CL500M ) a different form of mounting arrangement is required..
I'll try to put a picture into an album.
DC31k26/05/2021 16:57:59
1186 forum posts
11 photos
Posted by Danni Burns on 26/05/2021 12:54:39:
It would be good to find 50mm long reach clocks also. I can find 2".
Last time I went looking, Chronos (or maybe Linear Tools, their sister company) were sources for both languages of these.
You could always use a more standard 1" or 25mm travel indicator and a suitable 1" or 25mm spacer/gauge block/packer.
Howard Lewis26/05/2021 17:18:05
7227 forum posts
21 photos
The longest plunger clocks that Arc Euro do in Metric is 0.01 mm x 30 mm travel. Otherwise, they have a 0.001" 2" travel imperial.one.
Range is important if using as a measuring instrument, rather than bringing a workpiece back to a Zero deflection condition.
For this, you are unlikely to need a long travel, and possibly the units don't really matter, since you are looking for Zero, or absolutely minimal divergence.
To measure long distances, you could use gauge blocks and a short travel clock, since you are only interested in stopping once the distance has been traveled, accurately.
(This is how distances are measured on Jig Borers!, or with Height Gauges and Height Micrometers. )
Nigel McBurney 126/05/2021 19:10:11
1101 forum posts
dial gauges do not like soluble and other oils and the holder is usaually in direct llne with the chuck.Ok if only used wth dry cutting materials eg brass.A micrometer stop is better.
Danni Burns26/05/2021 20:28:30
69 forum posts
42 photos
Thanks guys
I am just drawing now for Clarke bed. Im also in touch with the ebay manufacturer to have one made thereafter.
DC31K - Its not a bad idea as that would get me up and running without further expense (if I can find a spacer thingymabob), but Id still be limited to just that 1" or what ever (Im sure mine are not even that).
I have seen metric 50mm on ebay somewhere. I think its from Italy. Best part of £100 I think.
Nigel, Agreed clocks are delicate things so will need to be careful. Maybe I have found a use for my Lockdown condom stash. Obviously, dont try this guys if the mrs is partial to a nosey. I didnt know what a mic stop was until I googled. Looks like a plan also, BUT I still need the clamp.
Howard, Thanks again. Ive just seen the clamp pic. So thats a Mic stop - looks a belter. What Mic is required (special or internal)?
So I need to make sure mine is diverse enough to hold both.
Thats enough optioneering from me for one day. I think we've all deserved a glass of red.
cheers
DC31k27/05/2021 08:01:12
1186 forum posts
11 photos
If you are going to have one 3D printed, consider incorporating a slot and clamping screw so you could then add a 'rain deflector' made of clear perspex, which would assist with the issue pointed out by Nigel above.
https://www.linear-tools.com/product/2-dial-indicator-linear-code-dg-2s/
https://www.linear-tools.com/product/50mm-dial-indicator-linear-code-dg-50m/
Danni Burns27/05/2021 09:50:47
69 forum posts
42 photos
DC31k - It's a good idea. But I'm sure sure of the type of fixing you mean (slot and clamping screw)? Can you please clarify (what and where it would fit) on below.
BTW there is a 2" on eBay now, by Chronos for £39.99 and a USED for £34; but I want 50mm.
Cheers
Danni Burns27/05/2021 13:02:32
69 forum posts
42 photos
I thought this was brilliant.
Edited By Danni Burns on 27/05/2021 13:06:22
Howard Lewis28/05/2021 09:53:15
7227 forum posts
21 photos
Have just posted a photo of the Micrometer saddle Stop that I made for my BL12-24 (Will fit a Taiwanese lathe such as the Warco BH600, 900 or Chester Craftsman ) into an Album, if anyone is interested.
There is also another Album showing a Saddle Stop made for a Myford ML4, but suitably upscaled can be used on any lathe with a dovetail bed. Adding a Micrometer barrel, or DTI should not be too difficult a modification to make.
Danni Burns28/05/2021 15:48:57
69 forum posts
42 photos
Hi Guys
Below are my findings from Clarke CL500M
Ive even had a bash at designing a clamp with Splash-guard holding thingy (top hole of the Greyed out image).
Its tight down there, and that guard (see pink marker) will have to be cut down.
If anyone fancies printing me one, give me a shout, I'll gladly work with you to resolve any design issues.
cheers
