Removing soft solder from brass before silver soldering
Brian H01/01/2021 12:36:26
2312 forum posts
112 photos
I have a small brass part that has been soft soldered to a piece of steel in order to machine it.
I now need to silver solder another piece to it but I believe that the remaining traces of soft solder will blow pits into the brass unless the soft solder is completely removed.
Many years ago at work we had a similar problem and used a chemical to remove any traces of soft solder. The problem is that I cannot remember what we used!
Does anyone know what will do the trick?
Brian Wood01/01/2021 12:55:16
2742 forum posts
39 photos
Hello Brian,
It might be easier altogether to make a new brass part and braze to that, this time using other holding methods for the machining.
JasonB01/01/2021 13:32:37
Filing it off works for me.
Nigel Bennett01/01/2021 13:49:04
500 forum posts
31 photos
Terence Holland wrote in ME about scraping off soft-solder from sweated stay holes in his loco firebox and re-soldering new stays with silver-solder a little while ago in his Barclay articles. It worked for him, too...
So just file it all off and go for it is my advice.
Former Member01/01/2021 14:09:39
1085 forum posts
Howard Lewis01/01/2021 14:50:47
7227 forum posts
21 photos
FWIW Jason and br suggestions get my vote
IanT01/01/2021 15:42:04
2147 forum posts
222 photos
I think filing is now your most likely route forward Brian - but I've been using alternatives (to leaded soft solder) for a while now, namely Super Glue and Shellac. Both are useful but I tend to use Shellac more often, mainly because it's always to hand and I'm afraid my tubes of Super Glue don't seem to have a great shelf-life once opened (I'm probably using the wrong kind?).
However, I have it in mind to experiment with lead-free solder which (I think I've read somewhere) doesn't cause the same problem with Silver brazing as leaded soft solders do. I haven't tried it yet though - although I'm sure a job will come along where I'll want to do so.
If anyone here has already tried lead-free solder for this purpose (and followed it up by silver brazing without further filing or machining) it would be useful to hear.
IanT
old mart01/01/2021 15:51:06
4655 forum posts
304 photos
The pickle that br mentions is useful, as it will highlight any tiny areas of solder missed originally.
Bob Stevenson01/01/2021 16:11:38
579 forum posts
7 photos
I usually heat the part and while the solder is molten I wipe with wire wool to remove as much as possible.
Neil Wyatt02/01/2021 17:14:31
19226 forum posts
749 photos
86 articles
I would only trust mechanical removal myself.
An online search reveals " Dissolution is usually accomplished after hours of using nitric and fluoroboric acids. " - I am really sure I would want to avoid that!
Brian H02/01/2021 17:58:39
2312 forum posts
112 photos
I followed the advice of using mechanical methods and used some silver solder with a slightly lower melting range than normal. Everything worked OK..
I still cannot remember what was used at work but was likely something highly toxic; it would be nice to know though.
We used Woods Metal in a mould to hold jet engine turbine blades in a set position so that a weld repair could be machined back to drawing. So maybe not relevant to brass.
Keith Hale03/01/2021 11:15:27
334 forum posts
Hi Brian.
Check my personal profile. Relevant?
Then see personal message.
Regards Keith
Oldiron03/01/2021 12:08:41
1193 forum posts
59 photos
IanT 01/01/21 " and I'm afraid my tubes of Super Glue don't seem to have a great shelf-life once opened (I'm probably using the wrong kind?). "
Hi Ian. I find that keeping the super glue in the fridge door behind the wifes pickle pots seem to make it last a very long time. Just allow it to warm up a bit before use then straight back in the fridge.
regards
IanT03/01/2021 12:24:50
2147 forum posts
222 photos
Posted by Oldiron on 03/01/2021 12:08:41:
regards
Thank you - I'll try that.
Although I may have to find a cunning way to hide it. My wife has a thing about "non-food" being kept in her fridge - probably dating back to when my son's maggots escaped from their bait-box over-night. It looked and sounded like a scene from a Hammer Horror film when she opened the door (and the screaming started).
He wasn't quickly forgiven and (being his Father) nor was I.
IanT
Tim Stevens03/01/2021 14:36:20
1779 forum posts
Do be sure that the soft solder is ALL removed, if the part is to be subject to significant loads - especially alternating loads. Or anything where a failure will release eg hot steam. For that reason, I concur with the 'start again' suggestion.
Cheers, Tim
Keith Hale03/01/2021 17:10:21
334 forum posts
Hi all
What soft solder is the subject? Lead is poison to the body and silver solder joints.
Lead free solders....?
Another story......?
Keith
Len Morris 217/01/2021 13:45:24
57 forum posts
29 photos
Hi Everybody,
Liquid Mercury will shift lead deposits very quickly. In the old days when gun ownership was possible I used it with great effect to remove lead deposits from barrels and it was standard process with shooters. With sensible precautions it was quite safe. Not sure if if would be possible to do in today's PC world.
Len
Oldiron17/01/2021 13:50:01
1193 forum posts
59 photos
Posted by Len Morris 2 on 17/01/2021 13:45:24:
Hi Everybody,
Len
Can you still buy liquid mercury ?
regards
Oldiron17/01/2021 13:56:09
1193 forum posts
59 photos
Posted by IanT on 03/01/2021 12:24:50:
regards
IanT
Late replying IanT sorry. I am very lucky that my wife is a mechanical engineer and is into steam engines & tractors and fully understands my sometimes strange habits. Like putting a bearing in the freezer or a part in the oven.
regards
Len Morris 218/01/2021 15:23:46
57 forum posts
29 photos
Hi Oldiron,
Yes apparently you can still buy liquid Mercury. It's illegal in the USA but in the UK it's available from a couple of laboratory supply companies. Not cheap at £25 for 100 grams. My small stock has been built up over the years from scrap thermometers, tilt switches etc. Needs careful thought before it's used but looking back, as kids in the 50's we used to roll it about in our hands in amazement, and that was in school labs! As I said, shifts lead deposits a treat.
Len
