new chap from wakefield saying hi
drum maker | 29/12/2020 00:55:01 |
27 forum posts 3 photos | hello, |
David George 1 | 29/12/2020 07:45:52 |
![]() 2110 forum posts 565 photos | Hi welcome to the forum. There are loads of information and helpful people on here who can give ideas on how to solve problems etc. Perhaps you can give information as well. David |
Brian H | 29/12/2020 09:31:22 |
![]() 2312 forum posts 112 photos | Hello and welcome Mr. Drum Maker. I doubt that there are many other drum makers on here but as you seem to want to set up a small metal working facility that is of no consequence. If you have any questions there will be people on here willing to give advice and help. Brian |
Chris Evans 6 | 29/12/2020 09:45:24 |
![]() 2156 forum posts | Welcome along, if you can post a picture of a typical part you would like to make. I am curious having never been the slightest bit musical. |
drum maker | 29/12/2020 11:54:23 |
27 forum posts 3 photos | Thanks for the warm welcome guys, its very much appreciated. Gareth Posted by David George 1 on 29/12/2020 07:45:52: Hi welcome to the forum. There are loads of information and helpful people on here who can give ideas on how to solve problems etc. Perhaps you can give information as well. David i have already been raiding that info for a while, the amount of times i have been searching for something & this forum pops up via Google is staggering, i felt i better join in, hopefully i can contribute in the future, though some of my current methods & workaround's may horrify the real engineers Posted by Brian H on 29/12/2020 09:31:22: Hello and welcome Mr. Drum Maker. I doubt that there are many other drum makers on here but as you seem to want to set up a small metal working facility that is of no consequence. If you have any questions there will be people on here willing to give advice and help. Brian I'd be staggered if there was even one Brian, we are a very rare breed, less than a hand full of us do it for a job in the UK, few hobby part timers, but we would not fill a minibus, i know most of the serious hobby & all the pro guys. |
drum maker | 29/12/2020 12:07:33 |
27 forum posts 3 photos | Posted by Chris Evans 6 on 29/12/2020 09:45:24:
thanks Chris, I’m not sure there will be a typical part, or should i say, typical parts I can get, its the non typical parts that are an issue, pre 50’s and rock & roll which brought mass production to my industry, drums were very much made individually and not exact copies of the previous, and not built by grabbing components from an inventory, but making each one as they went along the job. Most of my actual specific job machines are modified & repurposed from other machines... I buy machinery & parts like crazy. even if they look like they might be uses full for something & sit on the shelf for years... often the biggest issue is connecting all the things together, I need custom connectors, plates, spacers, even simple riser washers that I just can't quite get in the right height or diameter etc. I will make sure i throw some pics up to give you an idea |
Howard Lewis | 29/12/2020 12:22:46 |
7227 forum posts 21 photos | Welcome! If you come across a problem, someone on here will be able to advise. With a lathe you will be able to make your own bespoke shaft couplings. When you choose a lathe, if you haven't already got one, my suggestion would be one a little larger than you think. otherwise you will suffer the frustration of ma job that needs turning but is too big for the lathe. You can do small work on a big lathe, but not the other way round!. Not that I am suggesting a 21" swing machine, but probably 7 to 10" possibly?. (Unlikely that you would want to turn drums from the solid! ) My guess is that eventually you will want to cut threads, both Left and Right hand. In the smaller sizes, you should be able to obtain Taps and Dies from folk such as Tracy Tools, or The tap and Die Company. Having said that,the facility to screwcut will be invaluable, one day. So a lathe with a leadscrew, and changewheels, or even a Norton gearbox, will be essential. HTH Howard |
Georgineer | 29/12/2020 12:40:25 |
652 forum posts 33 photos | Welcome Gareth, Until the twentieth century (and actually well into it) a lot of parts you describe would have been made by hand, and a lot of brass turning was done freehand much like turning wood, so you are actually communing with the ancestors when you do hand work. It can definitely be quicker to do it by machine, though. It might be worth clarifying Howard's lathe size suggestion - he is talking about 'swing', which is the diameter of work that can be turned, and is a common way of describing lathes in the US. In the UK it is more common to talk about 'centre height' which is the radius of work that can be turned. So a UK 3½" lathe is the same as a US 7" lathe, for example. George B. |
Harry Wilkes | 29/12/2020 13:36:24 |
![]() 1613 forum posts 72 photos | Welcome to the forum H |
Steviegtr | 29/12/2020 13:50:45 |
![]() 2668 forum posts 352 photos | Welcome Gareth. I hope you get all the machinery to fit in with your new man cave. Steve. |
drum maker | 29/12/2020 17:58:52 |
27 forum posts 3 photos | Posted by Howard Lewis on 29/12/2020 12:22:46:
Welcome! If you come across a problem, someone on here will be able to advise. With a lathe you will be able to make your own bespoke shaft couplings. When you choose a lathe, if you haven't already got one, my suggestion would be one a little larger than you think. otherwise you will suffer the frustration of ma job that needs turning but is too big for the lathe. You can do small work on a big lathe, but not the other way round!. Not that I am suggesting a 21" swing machine, but probably 7 to 10" possibly?. (Unlikely that you would want to turn drums from the solid! ) My guess is that eventually you will want to cut threads, both Left and Right hand. In the smaller sizes, you should be able to obtain Taps and Dies from folk such as Tracy Tools, or The tap and Die Company. Having said that,the facility to screwcut will be invaluable, one day. So a lathe with a leadscrew, and changewheels, or even a Norton gearbox, will be essential. HTH Howard thanks Howard, info noted on lathe sizes, its the same theory with wood working tools such as band saws, always get as big as you can.. i will be limited by space in the cave but also access to it which is down some stairs (its in my cellar) but i will get as big as i can dismantle & move in.... |
drum maker | 29/12/2020 18:06:16 |
27 forum posts 3 photos | Posted by Georgineer on 29/12/2020 12:40:25:
Welcome Gareth, Until the twentieth century (and actually well into it) a lot of parts you describe would have been made by hand, and a lot of brass turning was done freehand much like turning wood, so you are actually communing with the ancestors when you do hand work. It can definitely be quicker to do it by machine, though. It might be worth clarifying Howard's lathe size suggestion - he is talking about 'swing', which is the diameter of work that can be turned, and is a common way of describing lathes in the US. In the UK it is more common to talk about 'centre height' which is the radius of work that can be turned. So a UK 3½" lathe is the same as a US 7" lathe, for example. George B. George, i love that thinking... I make my wood shells mixing very modern & very traditional methods, but when it comes to period pieces i even re saw my own veneers from solid stock, to make sure i can match the older wood stock thickness & construction formats not available now.... "communing with the ancestors" is a glorious way of putting it. |
drum maker | 29/12/2020 18:06:42 |
27 forum posts 3 photos | Posted by Harry Wilkes on 29/12/2020 13:36:24:
Welcome to the forum H thanks Harry. |
drum maker | 29/12/2020 18:16:15 |
27 forum posts 3 photos | Posted by Steviegtr on 29/12/2020 13:50:45:
Welcome Gareth. I hope you get all the machinery to fit in with your new man cave. Steve. thanks Steve, buying machinery & tooling has never been a problem for me... holding off buying too much is the issue.... so I'm sure i will acquire things quite easily once i know enough about what to buy... |
Howard Lewis | 30/12/2020 17:04:43 |
7227 forum posts 21 photos | If you think getting things up or down stairs is a problem, not long ago, someone, in Germany I think, posted video of craning his model traction engine out of his basement. He did have the advantage of the steps being outside. But you wouldn't put your fingers between the wheels and the door frame as it was pushed to the bottom of the steps. If it is any consolation, a mini lathe can be handled by one man (Just! I am 82! ) and two men can move a Myford Ml7 without dismantling anything. Unwieldy, but can be lifted ans carried. If in ANY doubt, get help! Dropping a machine will damage you as well as the machine, physically and financially. Don't dismantle unless absolutely imperative, in case you cannot realign things afterwards. My Mill/drill has never been quite the same after it was moved as two pieces! Howard |
