john fletcher 1 | 26/12/2020 16:48:59 |
893 forum posts | My mill is R8 and I have been giver a cutter and on the stem part of the R8 some one has engraved TCMT 2 (1.5 ) 7-UM 4025 P25 K 20. The cutter has two damaged triangular cutter. I have been looking to buy replacement but can't find any thing with those details. Will some one please point me in the right direction. Not urgent and will the cost give me heart problems. John Happy new year to all.. |
DC31k | 26/12/2020 17:06:51 |
1186 forum posts 11 photos | The insert designation is using the ANSI (American) system. Inserts sold here use the ISO system. There is a very useful chart here that has both languages on it: http://www.carbidedepot.com/formulas-insert-d.htm With inserts, the importance of the information conveyed decreases considerably the further to the right that you read. Some of what is shown on your cutter is likely a manufacturer-specific grade of carbide. For buying replacements, start at the left and get the basic shape. Then, for your chosen manufacturer, look at their literature and choose one of their offerings to suit the material being cut. |
old mart | 26/12/2020 18:02:44 |
4655 forum posts 304 photos | TCMT 110204 is the size, you can check the diameter of yours. Just imagine a circle fitting within the triangle, if it is 11mm then the size is right. The thickness is 2.38mm. TCMT 110304 is 3.18mm thick. Lots on ebay. P25 is a common grade for steel. Edited By old mart on 26/12/2020 18:03:22 Edited By old mart on 26/12/2020 18:06:59 |
Chris Evans 6 | 26/12/2020 20:35:01 |
![]() 2156 forum posts | I may have some TPUN inserts that would possibly fit, they are a turning tip but a quick touch on a diamond wheel and they work well for milling. I will look tomorrow and if I have any I will let you know and post for the cost of posting. |
Dave Halford | 26/12/2020 21:00:02 |
2536 forum posts 24 photos | This guy sells older style carbide off cheaper than most. |
DC31k | 26/12/2020 21:11:12 |
1186 forum posts 11 photos | Posted by Chris Evans 6 on 26/12/2020 20:35:01:
I may have some TPUN inserts that would possibly fit, they are a turning tip but a quick touch on a diamond wheel and they work well for milling. I will look tomorrow and if I have any I will let you know and post for the cost of posting. When you post them to him, how will you send him the hole in the middle of the insert, that he needs for securing it? The second 'T' in his TCMT is quite important... |
Chris Evans 6 | 27/12/2020 10:04:15 |
![]() 2156 forum posts | Posted by DC31k on 26/12/2020 21:11:12:
I may have some TPUN inserts that would possibly fit, they are a turning tip but a quick touch on a diamond wheel and they work well for milling. I will look tomorrow and if I have any I will let you know and post for the cost of posting. When you post them to him, how will you send him the hole in the middle of the insert, that he needs for securing it? The second 'T' in his TCMT is quite important... I was just looking at the insert size, I did not know the code refered to a hole. Guess I can't help but will still look in my box of unused inserts in case I have something suitable. |
Martin W | 27/12/2020 11:19:20 |
940 forum posts 30 photos | John. Message sent re inserts. Martin |
john fletcher 1 | 27/12/2020 12:04:42 |
893 forum posts | Many thank to all who responded to my request for information/help. The tool has just two triangular shaped tips with a recessed hole for the security screw. The existing tip is 2.5mm thick, the sweep is 25mm and from the base to the apex of the triangle it is 8.68mm What I don't want to do is buy some tips which I am unable to use. Having looked on the net there is just so much information of which I don't understand. John Happy new year to all. |
Steviegtr | 27/12/2020 13:18:33 |
![]() 2668 forum posts 352 photos | Posted by john fletcher 1 on 27/12/2020 12:04:42:
Many thank to all who responded to my request for information/help. The tool has just two triangular shaped tips with a recessed hole for the security screw. The existing tip is 2.5mm thick, the sweep is 25mm and from the base to the apex of the triangle it is 8.68mm What I don't want to do is buy some tips which I am unable to use. Having looked on the net there is just so much information of which I don't understand. John Happy new year to all. John why not try to post a picture of the inserts with a ruler beside it. It may give members a better idea. Steve. |
old mart | 27/12/2020 15:01:10 |
4655 forum posts 304 photos | https://www.iscar.com/eCatalog/Item.aspx?cat=5504887&fnum=530&mapp=IS&GFSTYP=M&srch=1My inscribed circle in the third post was wrong, yours should be about 1/4" (6.35mm) diameter. The sides should measure just over 11mm. These TCMT 110204 are common. Edited By old mart on 27/12/2020 15:09:51 |
